Ethernet Products
4873 Discussions
Why took auto-negotiation with Intel network adapters much longer as with Realtek network adapters?
spla
I have a request for auto-negotiation.
Problem: Intel Ethernet take too long to auto-negotiate.
Short explanation:
At the Gigabit switch and at the computer auto-negotiation is switched on.
Two different RJ45 inserts are possible for the wall socket in the office.
Wall socket with one port that uses all eight wires of the cat7 cable = 1x 1000 MBit.
Or wall socket with two ports, each using four wires of the cat7 cable = 2x 100 MBit.
Everything is fine with the Gigabit connection.
But at a 100 MBit connection the following problem occurs:
Computer with Intel network adapter needs 19 seconds until a network connection is established.
Computer with Realtek network adapter needs only 4 seconds.
Due to the long waiting time, start scripts for Windows are not executed.
Detailed explanation:
In our corporate network we have either a full Gigabit connection or a split Gigabit connection which becomes two 100 MBit connections.
Depending on which insert is in the wall socket, the complete wires of the cat7 cable (1x 1000 MBit) or half each (2x 100 Mbit) are used.
Now we had to find out that auto-negotiation for computers with Intel network connections takes much longer to negotiate than for computers with Realtek network connections.
These problems only occur with split network sockets, i.e. at 100 MBit. With Gigabit everything is fine.
If a computer with an Intel port is connected to a 100 MBit port, it takes about 19 seconds after booting under Win10 until the red X disappears from the network icon at the bottom right of the login screen and a connection is displayed.
The Realtek connection takes only 4 seconds.
The driver settings for all adapters are set to default, as far as I could see the network adapter options are identical for the comparable settings.
Tested devices:
OS: Win10 X64 Pro
(All devices have been reinstalled)
Switch: HP A5120 Series Switch JE068A
HP ProBook 650 G2
Intel(R) Ethernet Connection I219-V
Version 12.17.10.6
(Even the latest version from 2019 has been tested 12.18.8.9)
Toshiba Tecra R950-194
Intel(R) 82579V Gigabit Network Connection
Version 12.15.31.4
The Realtek network port is located on an ASUS B85M-E motherboard.
Realtek PCIe GBE Family Controller
Version 10.3.723.2015
The problems also occur with other devices, which I cannot name at the moment, but always the same. Realtek much faster than Intel.
The whole thing causes problems when executing start scripts which are executed before Windows logon. Due to the long reaction time they are not executed with Intel connections.
As soon as you set the value in the network driver to 100 Duplex it works without problems.
However, this cannot remain permanently set due to the number of devices and constant office changes. Auto-negotiation must remain.
It is not due to old or too long cables.
The whole thing is very strange and presents us with big problems.
Do you have any idea why?
Thank you
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for posting in Intel Ethernet Communities. Please provide the System Support Utility log. This will allow us to check your Adapter details and configuration. Please refer to the steps below: 1- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- 2- Open SSU.exe 3- Mark the box "Everything" and then click "Scan". 4- When finished scanning, click "Next". 5- Click on "Save" and attach the file to a post. Let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
spla
Hello Crisselle C,
here are the SSU files attached.
One from the Notebook with Intel Ethernet and one from the PC with Realtek Ethernet.
Thanks and regards.
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for the reply. We will check the gathered information and we will update you as soon as possible. Let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for waiting on our update. Just to double check if the link speed of I219 and the switch are configured to the same setting, please ensure both are set to 100mbps speed or both at auto-negotiation mode. You mentioned that the problem also occur with other devices, may we know if those devices also uses Intel Ethernet Connection? Let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
spla
Hello Crisselle C,
all switch ports and device ports are set to auto-negotiation.
The same problems with:
Version 12.15.31.4
HP ProDesk 600 G1
Intel(R) Ethernet Connection I217-LM
12.12.80.1920
HP ProDesk 600 G2
Intel(R) Ethernet Connection I219-LM
12.13.17.4
HP ElitePro 820 G3
12.18.8.9
On Win7 x64 and Win10 x64.
I don't know why the Realtek driver architecture negotiate in our case quicker, recognise the 100 Mbit connection faster.
At first we thougt it has to do with the HP motherboards. Compared to MSI, GIGABYTE or ASUS motherboards, HP offers only the most necessary settings. Do not make a good impression.
But the same problem appeared on a Toshiba device. After that I noticed all of this HP and Toshiba devices have one thing in common Intel Ethernet.
Other PCs in our company with MSI, GIGABYTE, ASUS motherboards have Realtek Ethernet and work fine.
The problem, the most are HP devices.
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for the reply. While we're checking on this, may we know if you tried to check with HP if they have newer driver version that could be of help? Let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, May we know if you were able to check with HP if they have newer driver available? May we also know if you have tried to compare the settings set on your Realtek with Intel? Let us know if you have any other questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Please let us know if you need further assistance for this matter. If you have other questions, please do not hesitate to ask. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
spla
Hello Criselle C,
I dont think you can help in this case.
The most things you ask, are things I already answered in my first post.
It seems this problem is to special to find a solution on this way.
Thanks for your help and time.
Best regards
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for the reply. We apologize for any inconvenience this might have caused. I managed to check on HP website and found the latest i219-V driver available is 12.17.10.7 dated Jul 3, 2018, have you tried using this driver version already? As I can see the driver version in the SSU log is 12.17.10.6. This would be helpful for us to further investigate and have you tried checking with HP* if they have any similar issue you've encountered. https://support.hp.com/us-en/drivers/selfservice/hp-probook-650-g2-notebook-pc/8430739 (This link will bring you to a third party website, owned and operated by an independent party over which Intel has no control. Intel is not responsible for information outside of the Intel Web site.) Rest assured that we are still checking on this and update you once there is any finding. Thank you for your time on this matter Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, Thank you for waiting on our update. After comparing the SSU log of Intel I219-V and Realtek, please try turning off the "Wait for link" and "ULP" parameters in the Advanced properties of I219-V. If you have additional questions, please let me know. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, I hope the recommendations above are useful to you. Please let me know if you have additional questions. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
Mike_Intel
Hello 3000021172281.5514663223918699E12, We just want to check if tried our last recommendation and what is the outcome? Please let me know if you have additional questions. Best regards, Michael L. Intel Customer Support Under Contract to Intel Corporation
Caguicla_Intel
Hello 3000021172281.5514663223918699E12, We hope that turning off the "Wait for link" and "ULP" parameters help fixed the issue, we appreciate if you can share the result in case you have tried this out. We understand that this is an Ethernet controller that's embedded with HP system. For OEM on-board Ethernet controller, it would be best if you can get in touch with HP for further support since they have customized drivers and software to enable or alter features on your system. They are in best position where you can seek assistance so you don’t lose features or customizations of the Ethernet controller. Please visit this link for Support Options for Intel® Ethernet Controllers https://www.intel.com/content/www/us/en/support/articles/000006628/network-and-i-o/ethernet-products.html?wapkw=oem+network Looking forward to hear from you. Best regards, Crisselle C Intel Customer Support Under Contract to Intel Corporation
