Ethernet Products
5821 Discussions
Win10 for 82574l NIC does not allow to install drivers from Intel.
AndreyN
I have a computer with an Asus P8B WS motherboard (BIOS updated to the latest version 2401 from 2019/06/14) and a Huawei S1720-52GWR-PWR-4X-E switch. The motherboard has two Intel 82574L Gigabit network controllers. Windows 7 Professional 64 bit was previously installed. I configured teaming on the computer (using the Intel ® Advanced Network Services utility) and LACP on the switch (using the web interface) to increase the speed of network access. Everything worked for several years. Then I launched the Microsoft Media Creation Tool and updated the operating system to Windows 10. Intel Teaming doesn't work on the Windows 10 Pro operating system, so the aggregated interface has disappeared from the control Panel. I'm trying to do what it says here-https://www.intel.com/content/www/us/en/support/articles/000032008/network-and-i-o/ethernet-products.html –an error message POPs up during installation: allegedly, I don't have intel network adapters in my system. As a result, I can't aggregate network controllers again.
Mike_Intel
Hello AndreyN,
First of all, we apologize for the delay in our response.
We are now done with the system upgrade and we are glad to continue assisting you.
Can you try the steps on this link:
https://www.intel.com/content/www/us/en/support/articles/000031823/network-and-i-o/ethernet-products.html
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello AndreyN,
I just want to check if you try our last recommendations.
Michael L.
txsetanta
Hi
I'd like to jump onto this since I have come across similar issue. Unfortunately no of the available for download drivers for 82574L are working with WIndows 10.
For some reason installation wizard is convinced that installed with microsoft  interface driver  is Intel I-217M  and not 82574L. Manual installation attempt also failed due to unable to find matching driver.
However as work around I was able successfully install driver dedicated for 82579LM, but latest 26.0 driver pack doesn't seams to be containing valid driver for 82574L
Mike_Intel
Hello AndreyN,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you.
Michael L.
