Ethernet Products
Intel® Ethernet products and technologies
4263 Discussions
Windows 10 1809 LTSC NIC Teaming
MajorTMan
Can someone suggest a product to provide NIC teaming in Windows 10 1809 LTSC? Hardware/software solution?
Mike_Intel
Hello MajorTMan,
We have a guide on how to create teaming in Microsoft Windows® 10 1809 using our latest Intel® Ethernet Software 23.5.
https://www.intel.com/content/www/xa/en/support/articles/000031823/network-and-i-o/ethernet-products.html
If you are looking for an Ethernet card or if you want to purchase an Ethernet card that will work for the steps above.
On that same link, just click on "Show All" under Related Products and you should see the compatible products for the steps.
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello MajorTMan,
Michael L.
MajorTMan
Michael,
Thanks for the direction.  I am in the process of giving this a go for our application.
Tom
Mike_Intel
Hello MajorTMan,
Thank you for the quick update. I just want to check when can you try the steps for me to know when to make a follow up?
Michael L.
MajorTMan
Hi Michael,
I have an order in for a HP 2-Port 381T from my reseller that has the supported chipset. I should be getting it this week or next. I should have a chance to try the software next week or the following. If I have any issues I will repost to this thread.
Thanks again,
Tom
Mike_Intel
Hello MajorTMan,
Thank you for the update and we will look forward to hearing from you after trying our last recommendations.
Michael L.
Mike_Intel
Hello MajorTMan,
I just want to check if you tried our last recommendation.
Michael L.
MajorTMan
Hi Michael,
So I installed the PROWinx64.exe with just the integrated NIC's to look at the software. It installed ok, it even recognize and installed drivers for the integrated NIC's (HPE Ethernet 1 Gb 2-port 368i Adapters). I did get an Unhandled error loading the Config Utility. So at this point I'm not sure if its due to the OS or the NIC's. My next steps are to see about enabling the (JIT) debugger as noted in the details. I also want to install the (HP 2-port 381T Adapter) as well. Any additional suggestions are welcome.
Mike_Intel
Hello MajorTMan,
I am happy that using the latest software works. And for the HPE cards that is still having issue, I suggest that you contact HP for the latest and appropriate driver for these cards. They should have a driver tailored for this cards.
Michael L.
MajorTMan
Michael,
I confirmed the system has the most latest drivers from the vendor. I will continue with my plan to test with add-in NIC's and will report findings.
Mike_Intel
Hello MajorTMan,
Thank you for the update. Kindly tell us when do you plan to test the network cards for me to know when to make another follow up.
Michael L.
MajorTMan
Hi Michael,
Due to office rotations, I won't get back to this until this coming Wednesday 9/16. I will post an update then.
Mike_Intel
Hello MajorTMan,
Thank you for the reply If that is the case, I will wait for your another update on Wednesday and will send another follow up on Thursday if I did not get a reply from you.
Michael L.
MajorTMan
Hi Michael,
So good news. I installed the supported adapter we purchase and PROSet Config Util is no longer erroring out. It seems the unhandled error occurs when it can't find any supported adapters. As shown in the attachments, it now identifies the supported adapters as well as the unsupported. My next steps are to team the supported adapters and continue testing.
Thanks again.
Mike_Intel
Hello MajorTMan,
I am happy to hear that. You may not continue to create a team and test the connection.
Just tell us if you still need further assistance.
Michael L.
MajorTMan
Hi Michael,
Great news, I was successful in creating the teamed NIC's with PROSet. Thanks again for your help and prompt correspondence.
