Ethernet Products
5776 Discussions
Windows 10 Insider Preview(Dev Channel) Build-20175 , the same problem of nic teaming
ryosan
About Windows 10 Insider Preview(Dev Channel) Build-20175 ,
Using product is "Intel Ethernet Converged Network Adapter X550-T2" ,
Using driver is "Intel Network Adapter Driver for Windows 10 Version: 25.1.1" ,
The nic teaming function does not work. As with the previous issue, after setting the nic teaming function, the network adapter set in the team will be disabled.
Mike_Intel
Hello ryosan,
First of all, we apologize for the delay in our response.
We are now done with the system upgrade and we are glad to continue assisting you.
For us to further check the issue, please provide the following details.
  1. Can you share the link where you downloaded your driver?
  2. Are you using on-board network card?
  3. What is the model of your board or system?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
Mike_Intel
Hello ryosan,
I just want to make a follow up on the information that I requested below for me to assist you.
Michael L.
ryosan
Hello
> 1.Can you share the link where you downloaded your driver?
https://downloadcenter.intel.com/ja/download/29727/Ethernet-Windows-10-
> 2.Are you using on-board network card?
Yes, my system's network cards are below
("No.1 and No.2" are on-board network cards)
No.1 : Intel(R) I211 Gigabit Network Connection
No.2 : Intel(R) I211 Gigabit Network Connection #2
No.3 : Intel(R) Ethernet Converged Network Adapter X550-T2
No.4 : Intel(R) Ethernet Converged Network Adapter X550-T2 #2
No.5 : Intel(R) PRO/1000 PT Dual Port Server Adapter
No.6 : Intel(R) PRO/1000 PT Dual Port Server Adapter #2
> 3.What is the model of your board or system?
ASRock X399 Taichi
https://www.asrock.com/MB/AMD/X399%20Taichi/index.asp
ryosan
Hello
Both "Windows 10 Insider Preview (Dev Channel)" and "Intel Network Adapter Driver for Windows 10" have been upgraded.
The upgraded version will be as follows:
-Windows 10 Pro x64(64-bit) Edition Version 2004 Insider Preview(Dev Channel) OS-Build 20197.1000
-Intel Network Adapter Driver for Windows 10 Version 25.2 x64(64-bit) Edition (PROWinx64.exe)
https://downloadcenter.intel.com/en/download/25016/Ethernet-Windows-10-
Regarding "Intel Network Adapter Driver for Windows 10", uninstall the old version and then install the new version.
After the version upgrade, I tested Teaming again, but the result was NG.
Teaming settings are as follows:
-Primary Adapter: Intel(R) Ethernet Converged Network Adapter X550-T2
-Secondary Adapter: Intel(R) Ethernet Converged Network Adapter X550-T2 #2
-Teaming Name: X550-LAG
-Teaming Type: Static Link Aggregation
The Teaming Adapter "X550-LAG" will be created, but it will be disabled and unusable.
Also, Remove Team of Teaming Adapter does not work properly and hangs up.
Therefore, the method to delete the created Teaming Adapter is to uninstall the Intel Network Adapter Driver for Windows 10.
The specs of the computer that tested Teaming are as follows:
-Motherboard: ASRock X399 Taichi
-CPU: AMD Ryzen Threadripper 2920X
-Network cards("No.1 and No.2" are on-board network cards):
No.1: Intel(R) I211 Gigabit Network Connection
No.2: Intel(R) I211 Gigabit Network Connection #2
No.3: Intel(R) Ethernet Converged Network Adapter X550-T2
No.4: Intel(R) Ethernet Converged Network Adapter X550-T2 #2
No.5: Intel(R) PRO/1000 PT Dual Port Server Adapter
No.6: Intel(R) PRO/1000 PT Dual Port Server Adapter #2
Mike_Intel
Hello ryosan,
Thank you for the update. The driver that you are using is not the latest. I have here the latest driver so
kindly try this first and check if this will fix the issue.
https://downloadcenter.intel.com/ja/download/25016/Ethernet-Intel-Network-Adapter-Driver-for-Windows-10?v=t
Michael L.
ryosan
Hello
Already, I am using latest(Ver-25.2) driver.
And the result is NG.
See the post on ‎08-23-2020 07:14 AM.
The following drivers I showed in this post
And the following driver you indicated
Points to the same latest version 25.2 with a different URL.
Mike_Intel
Hello ryosan,
Thank you for the clarification. Since you are using the latest driver which suppose to fix the teaming issue, let me gather the following details.
  1. Can you send a picture of your X550-T2 focusing on the markings on both sides of the card.
  2. Please share some screenshot of the problem.
Thank you.
Michael L.
Mike_Intel
Hello ryosan,
I just want to make a follow up on the information that we requested below:
Thank you.
Michael L.
Mike_Intel
Hello ryosan,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you.
Michael L.
