Ethernet Products
4864 Discussions
Windows 10 Intel Ethernet Connecton I218-V Issue
MBeni10
So I'm having an issue where every few seconds to sometimes a few minutes my PC stops detecting the ethernet cable just for a second, and then the internet returns. I tried swapping cables and it still doesn't work. I also tried a network reset, as well as reinstalling the LAN drivers, and still nothing works. I noticed this event in the Event Viewer
The network interface "Intel(R) Ethernet Connection (2) I218-V" has begun resetting. There will be a momentary disruption in network connectivity while the hardware resets. Reason: The network driver detected that its hardware has stopped responding to commands. This network interface has reset 14 time(s) since it was last initialized.
Please help
Mike_Intel
Hello MBeni10,
For us to further check the issue, kindly generate the SSU.
Please download the System Support Utility from the link below, and attach a log file for us to investigate this issue.
1- Download from https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
2- Open SSU.exe
3- Mark the box "Everything" and then click "Scan".
4- When finished scanning, click "Next".
5- Click on "Save" and attach the file to a post.
If you have questions, please let us know.
I will make a follow up after 3 working days.
Michael L.
Intel Customer Support Technicians
A Contingent Worker at Intel
Mike_Intel
Hello MBeni10,
I just want to make a follow up on the SSU that I requested. Please follow the guide below and send it to us for us to check this issue.
2- Open SSU.exe
Michael L.
Mike_Intel
Hello MBeni10,
I am sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Michael L.
