Ethernet Products
4936 Discussions
Windows 10 NIC Teaming with dual i210AT
BCoch2
I recently converted a freeNAS server to a Windows 10 x64 Pro box which has a Supermicro MOBO with onboard dual i210AT adapters. I had no problem configuring aggregation in freeBSD, but have been stumped on how to do the same in Windows 10. After searching various forums, etc, I see that in some cases there is a "Teaming" tab which appears in the Properties window of the controller. Unfortunately, that tab is not there when I attempt the same.
The current driver for both controllers is shown to be: 12.15.184.0 dated 3/29/2017
Any assistance is appreciated.
Hi Popster,
Thank you for posting your inquiry here. Can you share where did you download the driver and what is the Windows 10 version you have?
Have you tried installing the driver version from Intel?
https://downloadcenter.intel.com/download/25016/Intel-Network-Adapter-Driver-for-Windows-10?product=64400
Please noted also that " Intel ANS is only supported on the Windows 10 Anniversary Update* (Windows 10 Version 1607, build 10.0.14393) branch, and may not be supported on future versions.
wb
Hi Popster,
wb
BCoch2
Those drivers did the trick. The devices are working as they should. Many thanks!
PS. I had d/l the drivers from the device manager>network adapter>update driver. Software version is 1607 OS Buid: 14393.1066
Hi Popster,
Glad to know the driver work for you. Thank you for sharing the information and update.
Rgds,
wb
