Ethernet Products
5736 Discussions
Windows Blue Screen caused by e1000325.sys
LHou1
I had a tool suffered BSoD issue recently. I used Windbg to analyze crash dump file. Windbg pointed out issue probaly caused by e1000325.sys (intel NIC driver), but I don't understand the detail message from Windbg. Could someone teach me how to read analysis result of windbg ?
* Bugcheck Analysis *
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high. This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00ffdff9, memory referenced
Arg2: 000000ff, IRQL
Arg3: 00000001, value 0 = read operation, 1 = write operation
Arg4: ffdff983, address which referenced memory
Debugging Details:
WRITE_ADDRESS: 00ffdff9
CURRENT_IRQL: ff
FAULTING_IP:
+2702faf00e2dfc4
ffdff983 ff80f9dfff00 inc dword ptr [eax+0FFDFF9h]
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
PROCESS_NAME: Idle
TRAP_FRAME: 805500f0 -- (.trap 0xffffffff805500f0)
ErrCode = 00000002
eax=00000000 ebx=80010031 ecx=ffdff980 edx=80010031 esi=badb0d00 edi=806f372a
eip=ffdff983 esp=80550164 ebp=ffdff980 iopl=0 nv up di ng nz ac po cy
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010093
ffdff983 ff80f9dfff00 inc dword ptr [eax+0FFDFF9h] ds:0023:00ffdff9=????????
Resetting default scope
LAST_CONTROL_TRANSFER: from ffdff983 to 804e187f
STACK_TEXT:
805500f0 ffdff983 badb0d00 80010031 86329394 nt!KiTrap0E+0x233
WARNING: Frame IP not in any known module. Following frames may be wrong.
80550160 806f372a badb0d00 80010031 86329380 0xffdff983
80550174 f73a26a0 86329008 804da6ed 00000202 hal!HalProcessorIdle+0x2
8055017c 804da6ed 00000202 804da6f6 00000000 e1000325+0x6a0
80550184 804da6f6 00000000 f746ef2e 860f4930 nt!KeSynchronizeExecution+0x17
8055018c f746ef2e 860f4930 f73a2694 80010031 nt!KeSynchronizeExecution+0x20
805501ac 804dbbd4 80558e80 80558c20 ffdff000 NDIS!ndisMDpcX+0x62
805501d0 804dbb37 00000000 0000000e 00000000 nt!KiRetireDpcList+0x46
805501d4 00000000 0000000e 00000000 00000000 nt!KiIdleLoop+0x10
STACK_COMMAND: kb
FOLLOWUP_IP:
e1000325+6a0
f73a26a0 c20400 ret 4
SYMBOL_STACK_INDEX: 3
SYMBOL_NAME: e1000325+6a0
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: e1000325
IMAGE_NAME: e1000325.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 4450f0b4
FAILURE_BUCKET_ID: 0xD1_e1000325+6a0
Followup: MachineOwner
SYeo3
Valued Contributor I
Hi Lance0716,
Thank you for contacting Intel.
We'll check on this. Can you please provide the model of your network card?
Sincerely,
Sandy
