Hi everybody,
I am unable to find Network drivers for Intel® I217LM Gigabit Network adapter for Windows Server 2008 Standard (32-bit). I have found the drivers for Windows Server 2008 R2 but that being 64-bit do not work.Kindly help me in sorting out this problem as I am stuck need to install the drivers.
Thanks in advance.
SHOAIB
Unfortunately Microsoft Windows* Server 2008 does not support the Intel(r) Network connection I217-LM. There may be in-box drivers with the operating system installation.
http://www.helpjet.net/getfile/Intel-I217-LM/75de49ed898075c4d841291706b9e4b67d3128be9f094cd77c79836... http://www.helpjet.net/getfile/Intel-I217-LM/75de49ed898075c4d841291706b9e4b67d3128be9f094cd77c79836...
download from there, and unzip the files with 7zip, and then manually install the driver.
FINALLY worked for me with 2008 "r1" (64-bit)
you may have to dig a little more for 32-bit, but should be similar vintage
more to choose from here; http://www.helpjet.net/files-Intel-I217-LM.html http://www.helpjet.net/files-Intel-I217-LM.html
Did you ever find a solution for this? I am having the same issue.
