Ethernet Products
All support for Intel NUC 7 - 13 systems has transitioned to ASUS. Read latest update.
4745 Discussions
Wrong MTU size?
dcrim
Hi, i have a question:
I have windows 10, and when i go to "show network property" , it says Maximum trasmission unit: 1500
my pc is connected with a modem , that is connected to a PPPoE LLC connection, and use MTU = 1492 not 1500
Should i change this setting on my computer? How i have to change it?
Thanks you, and sorry for my bad english
Hello wilvinell0
Thank you for posting in the Intel® community.
  • Please share with us what is the model of your Intel® wired or wireless adapter?
  • What is your system brand and model?
  • Are you having any connectivity issue?
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
dcrim
my internet adapter is intel i-219v
my motherboard is asus maximus x hero
i want just to know if i have to change my network adapter mtu, because my modem works with 1492 mtu and my network adapter is set to an mtu of 1500.
Hi Wilvinell0,
Thank you for posting in Intel Wired Ethernet Communities.
If you are not encountering any connectivity issue, there is no need to change the setting. If you prefer to change, you may try the following command:
1) Use this command to display the interface
netsh int ipv4 show subinterface
2) Then use this command to change the MTU
netsh int ipv4 set subinterface "Local Area Connection" mtu=1492 store=persistent
Hope the above information help.
Whyeb T
Intel Customer Support
Hi Wilvinell0,
Please feel free to update me if the information help and if further assistance needed. Thank you.
Whyeb T
Hi wilvinell0,
Please let us know if you have other query related to Intel® Ethernet Connection I219-V. Thanks.
Vince T.
Hi wilvinell0,
We would also suggest to get in touch with the modem provider for further clarification if it is necessary to adjust the MTU size.
Vince T.
