I have a strange problem occurring with my new server which has the intel x520 network cards. This server runs Ubuntu KVM with virtual machines that collect netflow data- these device are virtual appliances. I noticed within the virtual machine that netflow datagrams. I first suspected resource constraints within KVM however after disabling all of the virtual appliances (except one) the packet drops were still occurring. I am able to determine the packet drops by simply taking a pcap and running it in a script with tshark. Each UDP datagram that contains the netflow data has a sequence number in the application layer header. I then ran a pcap on the host bridge interface and found that the issue is occurring outside the virtual machine. I then did a packet capture on physical interface to rule out that it was caused by the bridge and the issue is occurring there too. I then mirrored the interface to a separate server that has a similar 10gig network card and this device is able to capture each packet.
I suspect this is a network card offload /drive issue however I have not been successful in finding a solution. I tried upgrading the driver from 4.0.1 to 4.3.13 with no difference.
I am running out of options.
I tried disabling
for i in rx tx sg tso ufo gso gro lro; do sudo ethtool -K enp33s0f1 $i off; done
Tried increasing memory allocation to receive memory buffer:
cat /proc/sys/net/core/rmem_default
212992
cat /proc/sys/net/core/rmem_max
212992
and set the values to:
net.core.rmem_default = 16777216
net.core.rmem_max = 16777216
I noticed packets were incrementing the below counters in ethtool -S so i tried the below modprobe command but it did not help.
hw_rsc_aggregated: 4074
hw_rsc_flushed: 1837
modprobe ixgbe InterruptThrottleRate=off
server with issue:
lspci |grep Ethernet
0c:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
0c:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
21:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
21:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
62:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
62:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
63:00.0 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
63:00.1 Ethernet controller: Intel Corporation Ethernet 10G 2P X520 Adapter (rev 01)
I first tried with this below driver version.
version: 4.0.1-kThen upgraded and tried the below driver version.
version: 4.3.13server without issue:
[em621d@shdw01vmh ~]$ lspci |grep Ethernet
0e:00.0 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
0e:00.1 Ethernet controller: Intel Corporation 82599EB 10-Gigabit SFI/SFP+ Network Connection (rev 01)
version: 3.6.7-kTraffic characteristics:
Under 150Mbps
Rate 10k pps
Packet size 1340 - 1372 bytes
ethtool -S enp33s0f1
NIC statistics:
rx_packets: 728170
tx_packets: 8
rx_bytes: 1007244560
tx_bytes: 648
rx_errors: 0
tx_errors: 0
rx_dropped: 0
tx_dropped: 0
multicast: 254
collisions: 0
rx_over_errors: 0
rx_crc_errors: 0
rx_frame_errors: 0
rx_fifo_errors: 0
rx_missed_errors: 0
tx_aborted_errors: 0
tx_carrier_errors: 0
tx_fifo_errors: 0
tx_heartbeat_errors: 0
rx_pkts_nic: 728170
tx_pkts_nic: 8
rx_bytes_nic: 1010157240
tx_bytes_nic: 680
lsc_int: 1
tx_busy: 0
non_eop_descs: 0
broadcast: 63
rx_no_buffer_count: 0
tx_timeout_count: 0
tx_restart_queue: 0
rx_long_length_errors: 0
rx_short_length_errors: 0
tx_flow_control_xon: 0
rx_flow_control_xon: 0
tx_flow_control_xoff: 0
rx_flow_control_xoff: 0
rx_csum_offload_errors: 0
alloc_rx_page_failed: 0
alloc_rx_buff_failed: 0
lro_aggregated: 0
lro_flushed: 0
rx_no_dma_resources: 0
hw_rsc_aggregated: 0
hw_rsc_flushed: 0
fdir_match: 0
fdir_miss: 727925
fdir_overflow: 0
fcoe_bad_fccrc: 0
fcoe_last_errors: 0
rx_fcoe_dropped: 0
rx_fcoe_packets: 0
rx_fcoe_dwords: 0
fcoe_noddp: 0
fcoe_noddp_ext_buff: 0
tx_fcoe_packets: 0
tx_fcoe_dwords: 0
os2bmc_rx_by_bmc: 0
os2bmc_tx_by_bmc: 0
os2bmc_tx_by_host: 0
os2bmc_rx_by_host: 0
tx_hwtstamp_timeouts: 0
rx_hwtstamp_cleared: 0
tx_queue_0_packets: 0
tx_queue_0_bytes: 0
tx_queue_0_bp_napi_yield: 0
tx_queue_0_bp_misses: 0
tx_queue_0_bp_cleaned: 0
tx_queue_1_packets: 0
tx_queue_1_bytes: 0
tx_queue_1_bp_napi_yield: 0
tx_queue_1_bp_misses: 0
tx_queue_1_bp_cleaned: 0
tx_queue_2_packets: 0
tx_queue_2_bytes: 0
tx_queue_2_bp_napi_yield: 0
tx_queue_2_bp_misses: 0
tx_queue_2_bp_cleaned: 0
tx_queue_3_packets: 0
tx_queue_3_bytes: 0
tx_queue_3_bp_napi_yield: 0
tx_queue_3_bp_misses: 0
tx_queue_3_bp_cleaned: 0
tx_queue_4_packets: 0
tx_queue_4_bytes: 0
tx_queue_4_bp_napi_yield: 0
tx_queue_4_bp_misses: 0
tx_queue_4_bp_cleaned: 0
tx_queue_5_packets: 0
tx_queue_5_bytes: 0
tx_queue_5_bp_napi_yield: 0
tx_queue_5_bp_misses: 0
tx_queue_5_bp_cleaned: 0
tx_queue_6_packets: 0
tx_queue_6_bytes: 0
tx_queue_6_bp_napi_yield: 0
tx_queue_6_bp_misses: 0
tx_queue_6_bp_cleaned: 0
tx_queue_7_packets: 0
tx_queue_7_bytes: 0
tx_queue_7_bp_napi_yield: 0
tx_queue_7_bp_misses: 0
tx_queue_7_bp_cle...
Hi emueller,
Thank you for the info. We need to check on this.
rgds,
wb
May I ask for any progress regarding this issue?
We have exactly the same issue with X550 nics.
