Ethernet Products
4866 Discussions
X520-DA1 or X520-LR1 with Intel SFP+ extremely slow speed ...
I have two DELL PCs each installed Intel X520-DA1 with SFP+ (FTLX1471D3BCV-IT) and using single mode fiber to connect two PCs directly, on Windows 7 ultimate 64bit the adapter linked as 10Gbps, but when I using iperf to test the transmission speed, it only ran about 2.5Gbps, I change two adapters to X520-LR1 and still the same?!
No matter what I change (configurations, SFP+), the speed still extremely slow,I wonder what could be wrong?!
HI wowhsieh,
Thank you for the post. Will you be getting the same result if attaching the NICs to a switch?
rgds,
wb
Yes, two PCs connected to 10G switch and still the same, the speed always less than 1.5Gbps.
Hi wowhsieh,
Thank you for the clarification. What is the driver version used for both X520-DA1 and X520-LR1?
Please try installing the latest version in case you are not using the latest version.
https://downloadcenter.intel.com/download/18713/Intel-Network-Adapter-Driver-for-Windows-7-?product=39776
Based on the test result. just to clarify whether the X520-DA1 or X520-LR1 connects with OR without using switch in between, the performance will always be slow in iperf ?
Please feel free to update me. Thank you.
rgds,
wb
I download drivers one week ago, but just in case, I download the hyperlink's driver and install again and reboot PCs, still the same?! no matter two PCs linked directly or a 10G switch between two PCs.
The speed always locate at about 1.35Mbps.
Hi Wowhsieh,
Thank you for the clarification. I will further investigate on this then update you.
rgds,
wb
Hi Wowhiseh,
Please help by sharing your iperf testing paramters and the SSU logs.
You can download the Intel SSU at https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility, run the utitlity to generate the log then send to me.
thanks,
wb
iperf 3 parameters:
[Server]
iperf -s
[Client]
iperf -c 192.168.10.1
P.S. had tried different iperf options.
Hi Wowhsieh,
Thank you for the information. I will further check on this.
rgds,
wb
I changed two PC's OS to Ubuntu Desktop 16.04 using default driver and get 10G link state(two PC connect directly), but the iperf speed still only 1.3Gbps?!
Hi Wowhsieh,
Thank you for the updates.
rgds,
wb
Hi Wowhsieh,
Good day. Please try the following:
1) Disable TCP offloading option in the advance property of the adapter
Go to device manager->Network adapter-> right click on the NIC->property->Advance->
Disable the TCP offload option
2) Check if there is "Above 4GB" option in the system BIOS, enable it if there is
3) Try on another PCI-e x8 slot within the same system
4) Check with Dell* support for similar issue or workaround , as we found your network adapter
bearing the partnumber of E66562-003 which is not an Intel retail part
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005612.html
5) You can also run the following iperf command
Host Tx> iperf –c xxx.xxx.xxx.xxx(ip of receiver) –i 5 –w 64K –l 64K –P 8 –t 20
Host Rx> iperf -s
–i 5 ; report display period in unit sec
–w 64K ; TCP window size at unit=kB, by default 8kB.
–l 64K ; traffic payload buffer at unit=kB.
–P 8 ; port# for payload transmitting and receiving.
–t 20 ; Testing duration y default 10 sec.
Hope the above information help.
rdgs,
wb
Hi Wowhsieh,
Any update from the test result? Please feel free to update me. Thank you.
rgds,
wb
Last few weeks we were busy in handling other problem, we will back to this case next week and reply soon, thank you!
Hi Wowhsieh,
Thank you. We will wait for your update.
rgds,
wb
Hi Wowhsieh,
Good day. Have you tried testing the suggestion given? Please feel free to update me.
wb
Sorry, still have no time to test, maybe couple days later, thanks!!
Hi Wowhsieh,
Thank you and this is noted. Hope to hear good news from you.
rgds,
wb
TGrif2
I would like to comment on this post as well. Slightly different setup but same slow results.
Two dell R720s
Two intel branded X520
Windows 2012 R2 Datacenter on both servers
per dell support:
X520 driver: 3.9.58.9101 Network_Driver_FDP8R_WN64_17.5.0_A00
and firware: Network_Firmware_V6TPJ_WN64_17.5.10_A00
I do have the 4g option set in the bios
using branded intel sfps
using avago sfps on cisco side
One Cisco Nexus 9372PXE both servers on same vlan with duplex full and speed 10000 also tried auto negotiate
iperf config:
iperf3 -s
iperf3 -c xx.xx.xx.xx –i 5 –w 64K –l 64K –P 8 –t 20
[ ID] Interval Transfer Bandwidth
[ 4] 0.00-1.00 sec 20.5 MBytes 172 Mbits/sec
[ 4] 1.00-2.01 sec 23.1 MBytes 193 Mbits/sec
[ 4] 2.01-3.00 sec 25.9 MBytes 217 Mbits/sec
[ 4] 3.00-4.00 sec 26.0 MBytes 218 Mbits/sec
[ 4] 4.00-5.00 sec 25.8 MBytes 216 Mbits/sec
[ 4] 5.00-6.01 sec 25.2 MBytes 211 Mbits/sec
[ 4] 6.01-7.00 sec 22.5 MBytes 189 Mbits/sec
[ 4] 7.00-8.00 sec 25.0 MBytes 210 Mbits/sec
[ 4] 8.00-9.00 sec 22.1 MBytes 186 Mbits/sec
[ 4] 9.00-10.00 sec 21.9 MBytes 183 Mbits/sec
[ 4] 0.00-10.00 sec 238 MBytes 200 Mbits/sec sender
[ 4] 0.00-10.00 sec 238 MBytes 199 Mbits/sec receiver
iperf3 -c 10.5.63.40 -P 20 -t 30 -f m -b 0
[ 4] 0.00-30.01 sec 48.8 MBytes 13.6 Mbits/sec sender
[ 4] 0.00-30.01 sec 48.5 MBytes 13.6 Mbits/sec receiver
[ 6] 0.00-30.01 sec 40.1 MBytes 11.2 Mbits/sec sender
[ 6] 0.00-30.01 sec 40.0 MBytes 11.2 Mbits/sec receiver
[ 8] 0.00-30.01 sec 61.1 MBytes 17.1 Mbits/sec sender
[ 8] 0.00-30.01 sec 61.0 MBytes 17.1 Mbits/sec receiver
[ 10] 0.00-30.01 sec 58.1 MBytes 16.2 Mbits/sec sender
[ 10] 0.00-30.01 sec 58.0 MBytes 16.2 Mbits/sec receiver
[ 12] 0.00-30.01 sec 53.9 MBytes 15.1 Mbits/sec sender
[ 12] 0.00-30.01 sec 53.7 MBytes 15.0 Mbits/sec receiver
[ 14] 0.00-30.01 sec 49.1 MBytes 13.7 Mbits/sec sender
[ 14] 0.00-30.01 sec 49.0 MBytes 13.7 Mbits/sec receiver
[ 16] 0.00-30.01 sec 63.6 MBytes 17.8 Mbits/sec sender
[ 16] 0.00-30.01 sec 63.5 MBytes 17.7 Mbits/sec receiver
[ 18] 0.00-30.01 sec 56.2 MBytes 15.7 Mbits/sec sender
[ 18] 0.00-30.01 sec 56.1 MBytes 15.7 Mbits/sec receiver
[ 20] 0.00-30.01 sec 43.4 MBytes 12.1 Mbits/sec sender
[ 20] 0.00-30.01 sec 43.2 MBytes 12.1 Mbits/sec receiver
[ 22] 0.00-30.01 sec 50.0 MBytes 14.0 Mbits/sec sender
[ 22] 0.00-30.01 sec 49.9 MBytes 13.9 Mbits/sec receiver
[ 24] 0.00-30.01 sec 55.9 MBytes 15.6 Mbits/sec sender
[ 24] 0.00-30.01 sec 55.7 MBytes 15.6 Mbits/sec receiver
[ 26] 0.00-30.01 sec 48.2 MBytes 13.5 Mbits/sec sender
[ 26] 0.00-30.01 sec 48.1 MBytes 13.5 Mbits/sec receiver
[ 28] 0.00-30.01 sec 43.8 MBytes 12.2 Mbits/sec sender
[ 28] 0.00-30.01 sec 43.6 MBytes 12.2 Mbits/sec receiver
[ 30] 0.00-30.01 sec 60.9 MBytes 17.0 Mbits/sec sender
[ 30] 0.00-30.01 sec 60.7 MBytes 17.0 Mbits/sec receiver
[ 32] 0.00-30.01 sec 48.9 MBytes 13.7 Mbits/sec sender
[ 32] 0.00-30.01 sec 48.7 MBytes 13.6 Mbits/sec receiver
[ 34] 0.00-30.01 sec 47.9 MBytes 13.4 Mbits/sec sender
[ 34] 0.00-30.01 sec 47.8 MBytes 13.4 Mbits/sec receiver
[ 36] 0.00-30.01 sec 54.2 MBytes 15.2 Mbits/sec sender
[ 36] 0.00-30.01 sec 54.1 MBytes 15.1 Mbits/sec receiver
[ 38] 0.00-30.01 sec 56.6 MBytes 15.8 Mbits/sec sender
[ 38] 0.00-30.01 sec 56.4 MBytes 15.8 Mbits/sec receiver
[ 40] 0.00-30.01 sec 50.0 MBytes 14.0 Mbits/sec sender
[ 40] 0.00-30.01 sec 49.8 MBytes 13.9 Mbits/sec receiver
[ 42] 0.00-30.01 sec 49.8 MBytes 13.9 Mbits/sec sender
[ 42] 0.00-30.01 sec 49.6 MBytes 13.9 Mbits/sec receiver
[SUM] 0.00-30.01 sec 1.02 GBytes 291 Mbits/sec sender
[SUM] 0.00-30.01 sec 1.01 GBytes 290 Mbits/sec receiver
iperf Done.
Hi ADOCE3A,
Thank you for the input. I sent a PM to you.
rgds,
wb
