Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
X520-DA2, FreeBSD, rec_len_errs
We have a FreeBSD server in one of our data centers that is accumulating rec_len_errs. Our network team says everything looks okay on the Omni switch to which it is attached. However, something is causing these errors and I have exhausted my bucket of expertise trying to track it down. We have replaced everything my department owns after the switch - Intel SPF+ modules (both sides), fiber jumper (twice), X520-DA2 Network Adapter (once). This server is configured exactly the same as an identical server that is in a different data center. However, that other server is not showing these errors. Here is some relevant information for anyone who wants it:
FreeBSD 11.2-RELEASE-p2
Intel FTLX1471D3BCV-IT 10Gb SFP+ Module
Intel(R) PRO/10GbE PCI-Express Network Driver, Version - 3.2.12-k
# sysctl dev.ix.1 | grep rec_len_errs
dev.ix.1.mac_stats.rec_len_errs: 528161
Let me know if something else needs to be added. I believe this rec_len_errs field is for a receive length error. Is that correct? Does anyone have information on how I can diagnose this on the server side? I have tried tcpdump with various switches but am not seeing anything that suggests whence cometh this error. Thank you.
Gene
Highlighted
Community Manager
Hi Gene,
Thank you for posting in Wired Ethernet Communities.
You've mentioned there's identical server in a different data center that is not showing the error. Please share the configured settings on the X520-DA2. You can share the ethtool -k output of the server w/ error vs server w/out error.
We have driver version 3.2.18 posted in this https://downloadcenter.intel.com/download/14688/Ethernet-Intel-Network-Adapters-Driver-for-PCIe-10-G... link. You may want to check it out.
Vince T.
Intel Customer Support
Highlighted
Vince,
Thank you for the reply. There is no 'ethtool' on FreeBSD, that is a Linux tool. Here is the information I can get for you from FreeBSD:
Server with errors:
# sysctl hw.ix
hw.ix.enable_rss: 1
hw.ix.enable_legacy_tx: 0
hw.ix.enable_fdir: 0
hw.ix.unsupported_sfp: 0
hw.ix.rxd: 2048
hw.ix.txd: 2048
hw.ix.num_queues: 8
hw.ix.enable_msix: 1
hw.ix.advertise_speed: 0
hw.ix.flow_control: 3
hw.ix.tx_process_limit: 256
hw.ix.rx_process_limit: 256
hw.ix.max_interrupt_rate: 31250
hw.ix.enable_aim: 1
# sysctl dev.ix.1
dev.ix.1.mac_stats.tx_frames_1024_1522: 212217345
dev.ix.1.mac_stats.tx_frames_512_1023: 27883088
dev.ix.1.mac_stats.tx_frames_256_511: 1019347
dev.ix.1.mac_stats.tx_frames_128_255: 158582
dev.ix.1.mac_stats.tx_frames_65_127: 84329344
dev.ix.1.mac_stats.tx_frames_64: 62395
dev.ix.1.mac_stats.management_pkts_txd: 0
dev.ix.1.mac_stats.mcast_pkts_txd: 2
dev.ix.1.mac_stats.bcast_pkts_txd: 2
dev.ix.1.mac_stats.good_pkts_txd: 325670101
dev.ix.1.mac_stats.total_pkts_txd: 325670101
dev.ix.1.mac_stats.good_octets_txd: 356914457228
dev.ix.1.mac_stats.checksum_errs: 1030
dev.ix.1.mac_stats.management_pkts_drpd: 0
dev.ix.1.mac_stats.management_pkts_rcvd: 0
dev.ix.1.mac_stats.recv_jabberd: 0
dev.ix.1.mac_stats.recv_oversized: 4
dev.ix.1.mac_stats.recv_fragmented: 0
dev.ix.1.mac_stats.recv_undersized: 0
dev.ix.1.mac_stats.rx_frames_1024_1522: 57388071
dev.ix.1.mac_stats.rx_frames_512_1023: 25136
dev.ix.1.mac_stats.rx_frames_256_511: 39087
dev.ix.1.mac_stats.rx_frames_128_255: 15812
dev.ix.1.mac_stats.rx_frames_65_127: 28078923
dev.ix.1.mac_stats.rx_frames_64: 1259559
dev.ix.1.mac_stats.bcast_pkts_rcvd: 633245
dev.ix.1.mac_stats.mcast_pkts_rcvd: 1374
dev.ix.1.mac_stats.good_pkts_rcvd: 86806588
dev.ix.1.mac_stats.total_pkts_rcvd: 87481597
dev.ix.1.mac_stats.good_octets_rcvd: 89185700980
dev.ix.1.mac_stats.total_octets_rcvd: 89231162404
dev.ix.1.mac_stats.xoff_recvd: 0
dev.ix.1.mac_stats.xoff_txd: 0
dev.ix.1.mac_stats.xon_recvd: 0
dev.ix.1.mac_stats.xon_txd: 0
dev.ix.1.mac_stats.rx_missed_packets: 0
dev.ix.1.mac_stats.rec_len_errs: 563723
dev.ix.1.mac_stats.remote_faults: 3
dev.ix.1.mac_stats.local_faults: 6
dev.ix.1.mac_stats.short_discards: 0
dev.ix.1.mac_stats.byte_errs: 0
dev.ix.1.mac_stats.ill_errs: 0
dev.ix.1.mac_stats.crc_errs: 0
dev.ix.1.queue7.lro_flushed: 0
dev.ix.1.queue7.lro_queued: 0
dev.ix.1.queue7.rx_discarded: 0
dev.ix.1.queue7.rx_copies: 3571848
dev.ix.1.queue7.rx_bytes: 10195751974
dev.ix.1.queue7.rx_packets: 10157527
dev.ix.1.queue7.rxd_tail: 1494
dev.ix.1.queue7.rxd_head: 1495
dev.ix.1.queue7.br_drops: 0
dev.ix.1.queue7.tx_packets: 39588079
dev.ix.1.queue7.no_desc_avail: 1835985
dev.ix.1.queue7.no_tx_dma_setup: 0
dev.ix.1.queue7.tso_tx: 0
dev.ix.1.queue7.txd_tail: 506
dev.ix.1.queue7.txd_head: 506
dev.ix.1.queue7.irqs: 7268775
dev.ix.1.queue7.interrupt_rate: 35714
dev.ix.1.queue6.lro_flushed: 0
dev.ix.1.queue6.lro_queued: 0
dev.ix.1.queue6.rx_discarded: 0
dev.ix.1.queue6.rx_copies: 2870611
dev.ix.1.queue6.rx_bytes: 10435029610
dev.ix.1.queue6.rx_packets: 9644821
dev.ix.1.queue6.rxd_tail: 788
dev.ix.1.queue6.rxd_head: 789
dev.ix.1.queue6.br_drops: 0
dev.ix.1.queue6.tx_packets: 41895750
dev.ix.1.queue6.no_desc_avail: 0
dev.ix.1.queue6.no_tx_dma_setup: 0
dev.ix.1.queue6.tso_tx: 0
dev.ix.1.queue6.txd_tail: 64
dev.ix.1.queue6.txd_head: 64
dev.ix.1.queue6.irqs: 8601254
dev.ix.1.queue6.interrupt_rate: 29411
dev.ix.1.queue5.lro_flushed: 0
dev.ix.1.queue5.lro_queued: 0
dev.ix.1.queue5.rx_discarded: 0
dev.ix.1.queue5.rx_copies: 3417848
dev.ix.1.queue5.rx_bytes: 9888683630
dev.ix.1.queue5.rx_packets: 9806736
dev.ix.1.queue5.rxd_tail: 911
dev.ix.1.queue5.rxd_head: 912
dev.ix.1.queue5.br_drops: 0
dev.ix.1.queue5.tx_packets: 39585350
dev.ix.1.queue5.no_desc_avail: 1149660
dev.ix.1.queue5.no_tx_dma_setup: 0
dev.ix.1.queue5.tso_tx: 0
dev.ix.1.queue5.txd_tail: 1511
dev.ix.1.queue5.txd_head: 1511
dev.ix.1.queue5.irqs: 6931326
dev.ix.1.queue5.interrupt_rate: 500000
dev.ix.1.queue4.lro_flushed: 0
dev.ix.1.queue4.lro_queued: 0
dev.ix.1.queue4.rx_discarded: 0
dev.ix.1.queue4.rx_copies: 4171931
dev.ix.1.queue4.rx_bytes: 11464040752
dev.ix.1.queue4.rx_packets: 11568882
dev.ix.1.queue4.rxd_tail: 1777
dev.ix.1.queue4.rxd_head: 1778
dev.ix.1.queue4.br_drops: 0
dev.ix.1.queue4.tx_packets: 48718706
dev.ix.1.queue4.no_desc_avail: 53113
dev.ix.1.queue4.no_tx_dma_setup: 0
dev.ix.1.queue4.tso_tx: 0
dev.ix.1.queue4.txd_tail: 1732
dev.ix.1.queue4.txd_head: 1732
dev.ix.1.queue4.irqs: 10741290
dev.ix.1.queue4.interrupt_rate: 500000
dev.ix.1.queue3.lro_flushed: 0
dev.ix.1.queue3.lro_queued: 0
dev.ix.1.queue3.rx_discarded: 0
dev.ix.1.queue3.rx_copies: 3488870
dev.ix.1.queue3.rx_bytes: 10782358002
dev.ix.1.queue3.rx_packets: 10466983
dev.ix.1.queue3.rxd_tail: 1702
dev.ix.1.queue3.rxd_head: 1703
dev.ix.1.queue3.br_drops: 0
dev.ix.1.queue3.tx_packets: 37299621
dev.ix.1.queue3.no_desc_avail: 26160
dev.ix.1.queue3.no_tx_dma_setup: 0
dev.ix.1.queue3.tso_tx: 0
dev.ix.1.queue3.txd_tail: 672
dev.ix.1.queue3.txd_head: 672
dev.ix.1.queue3.irqs: 8362710
dev.ix.1.queue3.interrupt_rate: 500000
dev.ix.1.queue2.lro_flushed: 0
dev.ix.1.queue2.lro_queued: 0
dev.ix.1.queue2.rx_discarded: 0
dev.ix.1.queue2.rx_copies: 3314209
dev.ix.1.queue2.rx_bytes: 13476080887
dev.ix.1.queue2.rx_packets: 12083700
dev.ix.1.queue2.rxd_tail: 499
dev.ix.1.queue2.rxd_head: 500
dev.ix.1.queue2.br_drops: 0
dev.ix.1.queue2.tx_packets: 36066665
dev.ix.1.queue2.no_desc_avail: 225275
dev.ix.1.queue2.no_tx_dma_setup: 0
dev.ix.1.queue2.tso_tx: 0
dev.ix.1.queue2.txd_tail: 1813
dev.ix.1.queue2.txd_head: 1813
dev.ix.1.queue2.irqs: 8956553
dev.ix.1.queue2.interrupt_rate: 71428
dev.ix.1.queue1.lro_flushed: 0
dev.ix.1.queue1.lro_queued: 0
dev.ix.1.queue1.rx_discarded: 0
dev.ix.1.queue1.rx_copies: 3575987
dev.ix.1.queue1.rx_bytes: 9279977915
dev.ix.1.queue1.rx_packets: 9557914
dev.ix.1.queue1.rxd_tail: 1945
dev.ix.1.queue1.rxd_head: 1946
dev.ix.1.queue1.br_drops: 0
dev.ix.1.queue1.tx_packets: 40520...
Highlighted
Vince, et al,
One of our network engineers seems to have tracked down the problem. Here is a copy of his e-mail about it:
I may have found a lead. I found an email on Intel's ixgbe driver mailing list with a very similar situation to the one we're having. They also state they've seen this issue with Alcatel-Lucent Omniswitch 6850 which is in the same switch family as ours.
ixgbe and rx errors: https://sourceforge.net/p/e1000/mailman/message/30759532/
Based on the post it seems to be caused by STP (likely the BPDUs) where the packet length in the header doesn't match the actual packet length. They also indicate that changing from STP/RSTP to MSTP fixes the error.
The email also seems to indicate that you can't capture the errored packets from the switch unless you disable the HLREG.RXLNGTHERREN bit by recompiling the driver. I'm assuming that the Intel NIC drops the NIC before it sends it to the kernel. So the packet capture probably won't reveal the issue unless we had a passive tap or recompiled drivers.
So with that information I think we could probably turn off STP on for VLAN 1254 and that would probably fix the receive length errors. I don't see a reason for having RSTP on the VLAN for the server since it's only connecting with a LAG and doesn't look like it has a vSwitch.
So, it is not actually a problem on the FreeBSD side or with the Intel hardware / driver. My manager and the engineering team have decided to replace that Omniswitch with a newer Cisco model that matches the one to which our other server is attached in the next quarter.
Gene
Highlighted
Community Manager
Hi Gene,
Thank you for sharing the information. Glad to know you've found the solution to your issue.
Feel free to post in this thread if you have other assistance needed.
Vince T.
