Ethernet Products
5821 Discussions
X520-DA2/Nexus5000 and LACP with SLES11SP1 issue
we have a new Dell-Server with an Intel x520-DA2 and want to make a bond with the 2 Interfaces with LACP on a SLES11SP1(64bit) and a Cisco Nexus 5000.
Normally no problem, but with this 10G-Card the ports on Cisco-side remain "Individual". Same ports on the Cisco connect to the same Server with the onboard 1G-Ethernet-Cards works fine.
Some idea ?
Thank you for answer
Heiko
Mark_H_Intel
Hi Heiko,
LACP bonding should be working without a problem Please tell me the details of how the bonding is configured on both ends. Also, please tell me what driver you are using for the the X520-DA2 and send logs showing the failure. I will send you a private message with my email address so that you can send the files directly to me.
Thank you.
Mark H
