Ethernet Products
5717 Discussions
X520-SR2 doesn't work on HP DL380 G6 server?
firstly I installed the X520-SR2 on a hypertown server, it is OK
(Intel(R) Xeon(R) CPU E5440 @ 2.83GHz)
but It failed to initialize when I move it to a HP DL380(Intel(R) Xeon(R) CPU E5540 @ 2.53GHz,
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/15351-15351-3328412-241644-241475-3884082.html http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/15351-15351-3328412-241644-241475-3884082.html )
And it report these errors:
Oct 18 04:23:17 linaspl50 kernel: [ 2325.038363] Intel(R) 10 Gigabit PCI Express Network Driver - version 3.0.12-NAPI Oct 18 04:23:17 linaspl50 kernel: [ 2325.038371] Copyright (c) 1999-2010 Intel Corporation.
Oct 18 04:23:17 linaspl50 kernel: [ 2325.038413] ixgbe 0000:0a:00.0: PCI INT A -> GSI 31 (level, low) -> IRQ 31 Oct 18 04:23:17 linaspl50 kernel: [ 2325.038458] ixgbe 0000:0a:00.0: setting latency timer to 64 Oct 18 04:23:20 linaspl50 kernel: [ 2328.472454] ixgbe: 0000:0a:00.0: ixgbe_probe: failed to load because an unsupported SFP+ module type was detected.
Oct 18 04:23:20 linaspl50 kernel: [ 2328.472457] Reload the driver after installing a supported module.
Oct 18 04:23:20 linaspl50 kernel: [ 2328.472479] ixgbe 0000:0a:00.0: PCI INT A disabled Oct 18 04:23:20 linaspl50 kernel: [ 2328.472499] ixgbe 0000:0a:00.1: PCI INT B -> GSI 39 (level, low) -> IRQ 39 Oct 18 04:23:20 linaspl50 kernel: [ 2328.472529] ixgbe 0000:0a:00.1: setting latency timer to 64 Oct 18 04:23:24 linaspl50 kernel: [ 2331.895676] ixgbe: 0000:0a:00.1: ixgbe_probe: failed to load because an unsupported SFP+ module type was detected.
Oct 18 04:23:24 linaspl50 kernel: [ 2331.895678] Reload the driver after installing a supported module.
Oct 18 04:23:24 linaspl50 kernel: [ 2331.895692] ixgbe 0000:0a:00.1: PCI INT B disabled
I also tried to use YAST(SUSE Linux11+SP1,kernel 2.6.32) to configure the NIC,it said "bus error maybe due to firmware missing." something like that
when I reboot the machine, it shows EEPROM checksum is invalid followed by kernel panic.
Thanks a lot!
anyone can take a look at this article?
https://bugzilla.redhat.com/show_bug.cgi?id=548198 https://bugzilla.redhat.com/show_bug.cgi?id=548198
I got a similar problem with X520-SR2 (SLES11+SP1)
the kernel got panic due to NMI occured.
Mark_H_Intel
Have you found a resolution?
Is the server BIOS up to date?
Are you using the same SFP+ modules that you used in the server where the adapter works OK?
Have you tried the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=14687 3.1.15 driver?
after changing PCI slot,the kernel panic disappear
now it looks run well
