When I use the X520 module on my embedded device,I try to use iperf3 to test speed,but it report “Detected Tx Unit Hang” like:
root@firefly:/# iperf3 -c 192.168.1.100 -p 8000
Connecting to host 192.168.1.100, port 8000
[ 5] local 192.168.1.101 port 41072 connected to 192.168.1.100 port 8000
[ ID] Interval Transfer Bitrate Retr Cwnd
[ 5] 0.00-1.00 sec 1.15 GBytes 9.88 Gbits/sec 0 1.76 MBytes
[ 5] 1.00-2.00 sec 822 MBytes 6.90 Gbits/sec 0 8.74 KBytes
[ 5] 2.00-3.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 5] 3.00-4.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 5] 4.00-5.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 5] 5.00-6.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 5] 6.00-7.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 622.835133] ixgbe 0000:01:00.0 eth2: Detected Tx Unit Hang
[ 622.835133] Tx Queue <7>
[ 622.835133] TDH, TDT <17d>, <1b3>
[ 622.835133] next_to_use <1b3>
[ 622.835133] next_to_clean <17d>
[ 622.835133] tx_buffer_info[next_to_clean]
[ 622.835133] time_stamp <1000133f5>
[ 622.835133] jiffies <100013998>
[ 622.835190] ixgbe 0000:01:00.0 eth2: tx hang 1 detected on queue 7, resetting adapter
[ 622.835318] ixgbe 0000:01:00.0 eth2: Reset adapter
[ 622.868589] ixgbe 0000:01:00.0 eth2: TXDCTL.ENABLE for one or more queues not cleared within the polling period
[ 623.045332] ixgbe 0000:01:00.0 eth2: PCIe transaction pending bit also did not clear.
[ 623.045352] ixgbe 0000:01:00.0: primary disable timed out
[ 623.255035] ixgbe 0000:01:00.0 eth2: detected SFP+: 5
[ 5] 7.00-8.00 sec 0.00 Bytes 0.00 bits/sec 1 8.74 KBytes
[ 5] 8.00-9.00 sec 0.00 Bytes 0.00 bits/sec 0 8.74 KBytes
[ 628.848637] ixgbe 0000:01:00.0 eth2: NIC Link is Up 10 Gbps, Flow Control: RX/TX
[ 631.507021] ixgbe 0000:01:00.0 eth2: Detected Tx Unit HangMy linux kernel version is 6.1, and I use the latest driver: https://www.intel.cn/content/www/cn/zh/download/14302/intel-network-adapter-driver-for-pcie-intel-10-gigabit-ethernet-network-connections-under-linux.html
How to fix it?
what will cause this problem?
Hello lzjie-tchip,
Greetings!!
Thank you for bringing the issue to our attention,
Regarding the issue you encountered with the X520 module on your embedded device while running iperf3 (error: "Detected Tx Unit Hang"), we recommend opening a support case through the Intel® Premier Support (IPS) platform for further assistance.
You can register and open a case at the following link:
https://premiersupport.intel.com
Pujeeth
