Ethernet Products
5355 Discussions
X520 update problem-No config file entry
wartw
How do I update the firmware, this is not an OEM card
root@home:~/Linux_x64# ./nvmupdate64e -i -l
Intel(R) Ethernet NVM Update Tool
NVMUpdate version 1.35.23.3
Copyright (C) 2013 - 2020 Intel Corporation.
Inventory
[00:129:00:00]: Intel(R) Ethernet Server Adapter X520-1
EEPROM inventory started.
Warning: VPD is not valid.
EEPROM inventory finished.
OROM inventory started.
OROM inventory finished.
[00:130:00:00]: Intel(R) 82599 10 Gigabit Dual Port Network Connection
[00:130:00:01]: Intel(R) 82599 10 Gigabit Dual Port Network Connection
Device already inventoried.
Vendor                 : 8086
Device                 : 10FB
Subvendor              : 8086
Subdevice              : 0006
Revision               : 1
LAN MAC                : 001B21BC892F
Alt MAC                : 001B21BC892F
SAN MAC                : 90E2BA86AADA
ETrackId               : 00012B2C
EEPROM Version         : 16.128(10.80)
PBA                    : n/a
VPD status             : Corrupted
VPD size               : 0
EEPROM update          : No config file entry
  checksum             : Valid
OROM update            : No config file entry
  CIVD                 : 1.1197.0
  PXE                  : 2.3.46, checksum Valid
  EFI                  : 5.0.12, checksum None
Vendor                 : 8086
Device                 : 10FB
Subvendor              : 1DCF
Subdevice              : 030A
Revision               : 1
LAN MAC                : 98B78500DF3C
Alt MAC                : 98B785552211
SAN MAC                : E8611FF80D66
ETrackId               : 800006D1
EEPROM Version         : 64.64(40.40)
PBA                    : n/a
VPD status             : Not set
VPD size               : 0
  checksum             : Valid
  CIVD                 : 1.2960.0
  PXE                  : 2.4.45, checksum Valid
  EFI                  : 7.9.5, checksum None
Vendor                 : 8086
Device                 : 10FB
Subvendor              : 1DCF
Subdevice              : 030A
Revision               : 1
LAN MAC                : 98B78500DF3D
Alt MAC                : 98B785552212
SAN MAC                : E8611FF80D67
ETrackId               : 800006D1
PBA                    : n/a
VPD size               : 0
  checksum             : Valid
  CIVD                 : 1.2960.0
IntelSupport
Community Manager
Hello wartw,
Upon checking - it seems that Intel® Ethernet Server Adapter X520 Series does not have an updatable firmware
The product is also already discontinued. Please check here.
Since we are no able to support. We will proceed to close the thread.
If you have any other enquiries, kindly submit a new thread.
Thank you.
Hayat
