Ethernet Products
5736 Discussions
X540 SMBus
RDeBa
I am bringing up a X540-BT2 design and noticed that shortly after reset that the SMBus Clock and Data line are driven low.
The PCIe interface is not being driven - no reference clock.
Is this an issue that has been seen by any other designers?
Hi Rdebacker,
Thank you for posting in Wired Communities. With regards to design of embedded components X540-BT2 (Ethernet controller), you may post your inquiry at our embedded support at https://embedded.communities.intel.com/community/en
Sharon T
