Look on page 6:
https://downloadmirror.intel.com/781293/Release_Notes_28.1.1.pdf
Hi DaveinTN,
Good day.
Regarding the compatibility of Server 2022 with X540-T2 network adapter, you may refer to link below:
You may also want to refer to the release notes documentation available:
https://downloadmirror.intel.com/772066/Release_Notes_28.0_rev_1.2.pdf
Also, you may refer here:
I hope this clarifies your query. If you have any questions regarding this matter, feel free to let us know and we will be happy to assist you.
Sazzy_Intel
Hi DaveinTN,
Good day,
This is related to your enquiries above, I would like to check if the information provided above satisfies your enquiries?
If you have any questions or clarifications, please let me know.
Sazzy_Intel
I may be missing it but I don't see the X540-T2 10gb card specifically called out on any of the documentation listed.
Can I get a simple yes or no?
Does Windows Server 2022 support the older X540-T2 10gb network card?
Dave
Yes, but you can't use the installer. Extract the files and manually point it at the extraction folder. I've used it for three years in a high volume production server.
I picked a card up, which version of the driver did you download and which folder did you point to. The latest driver set I downloaded has several folders.
Dave
Hi DaveIN,
Thank you for your reply.
Referring to below link, unfortunately Windows Server 2022 no longer support X540-T2 10GB netword card.
I will be provide the table for your reference in this email thread for your reference.
Hope this clarifies. If you have any other questions, please let me know.
Sazzy_Intel
Do you have a recommendation on an inexpensive make model of a X540-T2?
Dave
Google X540-T2, ServerSupply usually has them for around $100.
Hi DaveIN,
Good day.
This is related to your enquiries above, I would like to check if the issue has resolved?
Sazzy_Intel
Hi DaveIN,
Good day,
I would like to follow up if you have any questions or clarifications regarding this case.
Feel free to contact us should you need any further assistance, and we will be more than glad to continue assisting you.
Sazzy_Intel
Hi DaveIN,
This is regarding your issue above, since we have not seen an update, if you need any additional information, please submit a new question as this thread will no longer be monitored.
Sazzy_Intel
