Ethernet Products
5821 Discussions
X550 - NVM Update and driver problems. Counterfeit or OEM NIC?
dablub
Hi
I did by a new Intel X550 T2. identification in device manager seem ok with "Intel converges NA X550-T2".
Visually the card seem like any other x550 I had dealt with.
I run into 3 issues:
1. NVM update fails with unsupported - I never had such issues with other x550s
2. With driver 29.3 both ports stop working under Win11 after some hours. System is not reachable. When I login via IPMI I see error Code 43.
Old Windows driver 4.1.219.0 seems to work, at least the last 4 hours no disconnects.
Attached is acreenshot of NVM failedupdate and the SSU file.
thx
Amina_Sadiya
Hello Team,
Greetings from Intel!
Thank you for posting your query in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and want to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved or if you require further assistance? Your prompt response will greatly assist us in diagnosing and resolving the issue as quickly as possible.
We truly appreciate your patience and understanding, and we look forward to hearing from you soon.
Amina
Amina_Sadiya
Hello Team,
Greetings for the day!
We are following up to check if you were able to find the information we requested. Kindly confirm at your earliest convenience, so that we can continue assisting you in resolving this matter.
If we don't hear back from you, we'll assume the issue has been resolved and will proceed to close the case.
Amina
dablub
Hi
It seems it was an OEM card. I know that Intel doesn't support OEM cards but it would be very useful for the nvm update tool to just spit out:
NIC is OEM of BRAND X - not supported by this tool
that would save many ppl a **bleep** ton of trouble
Azeem_Intel
Hello dablub,
Thank you for your response and suggestion. We appreciate your feedback and will pass it along to our internal team. Please let us know if you need any further assistance.
Azeem_Intel
