Hi @huanghonghao,
May I know if the MAC address of the Intel wired network card X550-T1 has been altered at all?
For security reason, the MAC address for X550 is only allowed to update once after you flashed the nvm image.
NVM version 2.0 and above allow for one time change of the mac address from the generic to the specific address, after that the security feature does not allow for additional changes.
The NVMs from 2.00 and higher have a "recovery mode" which will only allow the MAC to be programmed after the FW identifies the MAC is not the default value from the original file.
Once the FW finds a new value it will lock it in Read Only space and it will remain unchanged.
Hope this clarifies your question. Check out this related external discussion as well to find suitable information related to your inquiry:
https://blog.kanbach.org/post/how-to-permanently-change-a-mac-address-using-ethtool/
Please be aware that Intel does not support the modification of MAC addresses using third-party applications.
Please let me know if I can be of any assistance.
BY_Intel
Intel Customer Support
Hello B_Y
Also, I would like to know about the "recovery mode" of NVM. Is it a unique mechanism of X550-T1? Because when I use other models of network cards (such as I350, X710), I will not encounter this situation of being restored
Hi @huanghonghao,
You may refer to this Intel article (https://cdrdv2-public.intel.com/606286/606286_RecoveryMode_AppNote_Rev1.2.pdf) on Recovery Mode for Intel® Ethernet Products.
Kindly provide the following information for us to further check on your query.
1) Please share the PBA of the adapter. You may refer to the link below on where to find the PBA number. Providing photos of the adapter focusing on the markings (white sticker) found on the physical card will be highly appreciated for us to double check on it. The PBA consists 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
2) System Support Utility(SSU) log of your system. This will allow us to check your Adapter details and configuration. This would also help us identify if you are using an OEM or retail version of Intel Ethernet Adapter. Kindly go to https://www.intel.com/content/www/us/en/download/18895/26735/intel-system-support-utility-for-the-linux-operating-system.html? and download the software.
3) Please provide output of ethtool -i
4) May I know the exact command you used to change the MAC.
Looking forward to hearing from you. Thank you.
BY_Intel
Hi @huanghonghao,
I hope this message finds you well. I am just sending a follow up if you have any questions from the previous post. If so, please let us know. Thank you.
BY_Intel
Hi @huanghonghao,
Please be informed that we will now close this request since we haven't received any response from our previous follow ups. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored. Thank you.
BY_Intel
