Hello. Do any of you know where I can get the intel X550-T2 driver version 4.2.6.0 that I can download and install to my Asus ROG Maximus XIII Hero motherboard?
The Driver and Support Assistant keeps trying to install it but fails to do so.
Thanks, Matt
Hello olegeezer,
Greetings!
Below is the latest driver version for the X550-T2 adapter.
Intel® Network Adapter Driver for Windows Server 2025
Pujeeth_Intel
I have Windows 11 Home 64bit. Will the WS2025 4.2.9.0 work with my W11 ??
Thanks, Matt
Hello olegeezer,
Greetings!
Kindly let us know if the NIC card has came with the system or was purchased separately.
Note: If you purchased an OEM-branded system or appliance, please contact your OEM for a software driver version compatible with your specific firmware version.
Using software and firmware versions that have not been validated to work together may impact performance, feature availability, and system stability.
Intel® Network Adapter Driver for Windows Server 2025*
This driver pack support Windows 11 as well.
Pujeeth_Intel
Hello. I have the intel X550-T2 NIC adaptor. Does the 4.2.9.0 work with it on Windows 11 Home 64bit ?
Thanks, Matt
Hello olegeezer,
Greetings!
Kindly share the link from where the driver was downloaded.
Additionally, please let us know if this NIC card came with the system or was purchased separately.
Pujeeth_Intel
Hello. The 4.2.6.0 was downloaded by the Driver and Support Assistant (DSA) but DSA failed to install 4.2.6.0.
So I downloaded from the Intel Download site the 30.0 package. I went into Device Manager to update the X550-T2 drivers. I went into the 30.0 package and selected the PROXGB, then I opened Win64 and selected WS2025 where I located the ixs.inf file that contains the 4.2.6.0 driver. In Device Manager, I could only get to WS2025 and could go no further. But I was able to install the 4.2.6.0 driver.
My intention was to try to install driver 4.2.9.0 that is located in the sxa.inf file. But Device Manager only gets me to the WS2025 and no further. I don't know how to install the 4.2.9.0 driver since I cannot select it in Device Manager.
I tried using CMD prompt but the commands to locate 4.2.9.0 driver I was given do not work . I tried the pnputil command but that command I was given does not work either. Do you know the proper command string for locating the driver 4.2.9.0 ? And the proper command string to use pnputil to install 4.2.9.0 ?? If so, can you send me the proper command strings for locating the driver and commands string for using the pnputil ?
Thanks, Matt
By the way, I bought this intel X550-T2 from the Intel Store on Amazon.
Hello olegeezer,
I wanted to touch base with you regarding the installation of the SXA driver version 4.2.9.0. Just to reconfirm, you are attempting to install this driver on a system running Windows 11, correct? If so, I wanted to clarify that the SXA driver is specifically designed for Windows Server Operating Systems and is not compatible with Windows Client Systems, such as Windows 11.
You can validate this information on the release note Section 1.4, you can go through the release note on the following link: Intel® Ethernet Controller Products Release Notes
Thank you & best Regards,
Ragulan_Intel
Hello olegeezer,
Greetings!
The driver version 4.2.9.0 is compatible with the operating system (WS2025) this can be verified on Intel® Ethernet Product Release Notes.
Pujeeth_Intel
Hello olegeezer,
Greetings!
This is a first follow up, Please feel free to respond to this email at your earliest convenience.
Pujeeth
Hello olegeezer,
Greetings!
This is the second follow-up regarding the reported issue.
Feel free to reply to this email, and we'll be more than happy to assist you further.
Pujeeth_Intel
Hello olegeezer,
Greetings!
The driver version 4.2.9.0 and 4.2.6.0 is compatible with the operating system (WS2025) this can be verified on Intel® Ethernet Product Release Notes.
Pujeeth_Intel
Hello olegeezer,
Greetings!
Pujeeth_Intel
Hello olegeezer,
Greetings!
This is a second follow up, Please feel free to respond to this email at your earliest convenience.
Pujeeth_Intel
