Ethernet Products
5821 Discussions
X550-T2 jumbo frame supported in Win10
WChan5
Dear Sir
The X550-T2 NIC mentioned the maximum jumbo frame is 15.5K, I already verify this feature in Ubuntu Linux by an industrial camera without packet loss.
Are there any updates with the drivers of X550-T2 or any instructions to enable 15.5k jumbo frame in Win10? Thanks.
https://www.intel.sg/content/www/xa/en/products/sku/88209/intel-ethernet-converged-network-adapter-x550t2/specifications.html?countrylabel=Asia%20Pacific
Caguicla_Intel
Hello WChan5,
Before we check your query, kindly provide the following information that would help with the investigation.
1. PBA of the adapter. You may refer to the link below on where to find the PBA number. It consist of 6-3 digit number located at the last part of the serial number. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
2. Current driver used
3. Have you tried checking on the Advanced properties of X550-T2 if you can enable the 15.5k jumbo frame?
We look forward to your reply.
Should there be no response from you, we will follow up after 3 business days.
Crisselle C.
Intel® Customer Support
WChan5
Dear Sir
Thanks for your reply.
Please find the attachment including PBA number, driver I used, and advanced properties of Jumbo Packet.
There has no 15.5k jumbo frame option on the advanced page.
Caguicla_Intel
Hello WChan5,
Thank you for prompt reply.
Please allow us to further check this request with our engineers. We will get back to you as soon as possible but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C.
Intel Customer Support
Caguicla_Intel
Hello WChan5,
Good day!
Please be informed that we are still checking on your request. Rest assured that we will give you an update as soon as we heard from our engineers but no later than 2-3 business days.
Thank you for your kind understanding.
Crisselle C.
Caguicla_Intel
Hello WChan5,
Thank you for the patience on this matter.
Please refer to below information for the update from our engineers. Feel free to let us know if you have additional questions or clarifications.
Question: How to enable 15.5K Jumbo Frame?
Answer: The only way to enable Jumbo Packet is via device properties. In the device properties, there is a Jumbo Packet item in the Advanced tap, and then enable Jumbo Packet by selecting the Jumbo Packet sizes (4088 Bytes and 9014 Bytes) on the drop-down menu.
Important Note: As described in the datasheet, once some other functions are enabled, the maximum packet size of Jumbo Packet is limited to 9.5KB (9014 Byte payload + other information in the Jumbo packet).
The 9014B packet size is usually a common maximum value to MTU(Maximum Transmission Unit) of an Ethernet port, others that are over 9014KB can be considered as Super Jumbo Packet. Performance and latency may be impacted by the increase in MTU.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
hhans
Dear Sir
According to the Jumbo Packet is limited to 9.5KB because some other functions are enabled.
Could you help to provide what are those functions by screenshot to enable 16K jumbo frame, thanks.
Caguicla_Intel
Hello hhans,
Thank you for the reply.
Can you please share the Operating System and Ethernet adapter you used so we can check this as well with our engineers. Are you using the same X550-T2 and Win10 OS on your setup?
Hello WChan5,
Good day!
This is just a follow up to check if you have read our update. If yes, kindly confirm and let us know if you have additional questions and clarifications on this matter.
Looking forward to your replies.
Should there be no response, we will follow up after 3 business days.
Crisselle C.
hhans
Dear Sir
hhans and WChan5 are in the same division of the company.
Please share what are those functions enabled that limited the Jumbo Packet to 9.5KB.
Could you help to provide what are those functions by screenshot to enable 16K jumbo frame in Win10, thanks.
hhans
Caguicla_Intel
Hello hhans,
Appreciate your effort in letting us know that you are from the same company.
Please allow us to further check your follow up question with our engineers. We will get back to you as soon as possible but no later than 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello hhans,
Good day!
Please be informed that we are still checking on your follow up question. Rest assured that we will give you an update as soon as there is any but no later than 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello hhans,
Good day and I hope this message finds you well!
This is just an update to inform you that this request is still escalated to our engineers. Rest assured that we will give you an update as soon as we heard from them but no later than 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello hhans,
Good day!
This is just an update to inform you that this request is still under investigation. Rest assured that we will get back to you as soon as possible but no later than 2-3 business days.
Thank you for your kind patience.
Crisselle C.
hhans
Dear Sir
The request of enabling the 16K jumbo frame on X550-T2  in Win10 is really important for us.
Hans
Caguicla_Intel
Hello Hans,
We highly appreciate your kind understanding on this matter and we sincerely apologize for the delay.
We'd like to inform you that we are still actively working on this issue with our higher level Engineers. We are doing our best to sort this out as soon as possible and rest assured that we will keep you posted then get back to you within 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello Hans,
Good day and I hope you will be having an amazing week!
This request is still escalated to our higher level engineers. Please give us more time to look into this. Rest assured that we will give you an update as soon as we heard from them but not later than 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello Hans,
Good day!
We sincerely apologize for the delay on this matter as we are thoroughly checking on this. Please give us more time to look into this. Rest assured that we will give you an update as soon as there is any findings but not later than 2-3 business days
Crisselle C.
Caguicla_Intel
Hello Hans,
How are you doing?
We'd like to inform you that we are still actively working on this issue with our higher level Engineers. We apologize if this is taking longer and rest assured that we are doing our best to sort this out as soon as possible. We will keep you posted and get back to you no later than 2-3 business days.
Crisselle C.
hhans
Dear Sir
Hans
Caguicla_Intel
Hello Hans,
Good day!
Please accept our sincerest apologies for the delay. Due to complexity of the issue, we need more time with the investigation. We are closely monitoring this case for any update and get back to you no later than 2-3 business days.
Thank you for your kind cooperation.
Crisselle C.
Caguicla_Intel
Hello Hans,
How are you doing? I hope everything is great!
We sincerely apologize for the delay on our update as we tried to look for the information that would help on your inquiry.
We regret to inform you that we do not have information on configuring super jumbo frames. However, you may consider looking for more information from other sites which you can use as reference.
Guidance from CISCO/switch configuration online regarding Super Jumbo Frames.
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-6000-series-switches/24048-148.html
Unfortunately, achieving Super Jumbo frame is not as easy to enable and we believe that limited enterprise class switches can support super jumbo frames. We also recommend to check with your switch manufacturer if it supports jumbo frames.
In case we don't hear from you, we will proceed closing this request. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Crisselle C.
