Ethernet Products
5782 Discussions
X710-BM2 cannot use 1G setting when using SFI interface.
DavidCFWei
X710-BM2 uses SFI interface to connect to external SFP+ (10G)
Can link normally on 10G
But after setting it to Link 1G, the connection will be disconnected.
Even if we refresh "XL710_X710_9p40_SFI_Backplane_MCTP_CFGID7p2_Dual.bin", it cannot be set to 1G
Please help confirm that when X710-BM2 is in SFI interface, can the Link setting be set to 1G?
Devi_Intel
Hello DavidCFWei
Good Day ~
Thank you for posting Ethernet Community. Appreciate you can follow the link below for the drive pack details
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html?wapkw=intel%20ethernet%20controller%20i226-v%20driver%20for%20ubuntu
you also can check the combability details :
https://www.intel.com/content/www/us/en/support/articles/000023708/ethernet-products/700-series-network-adapters-up-to-40gbe.html
We will follow up after 3 business days in case we don't receive a response.
Thank you & Best Regards,
Devi_ Intel
Hayat
Hello DavidCFWei,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
Hayat
Hello DavidFCWei,
Since there are no replies, we will proceed to close the thread.
Please be informed, once the thread is closed it will no longer be monitored by Intel.
Kindly open a new thread if you have further questions.
Hayat
