Ethernet Products
4931 Discussions
X710-DA2 PCIE error
jindotgea36
HI
While operating the server with X710 installed, the following error log occurred. There was no problem with server operation, but the error must be analyzed.
The server is currently closed and no further verification is possible. Why did the following log occur?
kernel: {1}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 0
kernel: {1}[Hardware Error]: It has been corrected by h/w and requires no further action
kernel: {1}[Hardware Error]: event severity: corrected
kernel: {1}[Hardware Error]:  Error 0, type: corrected
kernel: {1}[Hardware Error]:   section_type: PCIe error
kernel: {1}[Hardware Error]:   port_type: 0, PCIe end point
kernel: {1}[Hardware Error]:   version: 3.0
kernel: {1}[Hardware Error]:   command: 0x0546, status: 0x0010
kernel: {1}[Hardware Error]:   device_id: 0000:d8:00.0
kernel: {1}[Hardware Error]:   slot: 0
kernel: {1}[Hardware Error]:   secondary_bus: 0x00
kernel: {1}[Hardware Error]:   vendor_id: 0x8086, device_id: 0x1572
kernel: {1}[Hardware Error]:   class_code: 000002
kernel: {1}[Hardware Error]:  Error 1, type: corrected
kernel: {1}[Hardware Error]:   device_id: 0000:d8:00.1
Mike_Intel
Hello jindotgea36,
For us to further check the issue, please provide the following details.
  1. Where did you see this error? Is it an OS log or your server system's hardware log?
  2. What is the brand and model of your system?
  3. How many PCIe cards are installed in the machine?
  4. Can you provide some pictures focusing on the markings of your X710-DA2 on both sides of the card?
  5. What are the troubleshooting steps that you tried so far?
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel® Customer Support
Mike_Intel
Hello jindotgea36,
I hope you are having a good day. We just want to make a follow up on the information requested below:
Michael L.
Mike_Intel
Hello jindotgea36,
I am just sending another follow up on the information that I requested.
If you need further assistance, please post a new question.
Thank you.
Michael L.
