Ethernet Products
5770 Discussions
X710-DA2 with i40e driver : PTP over UDP
VolCoM
I can read from : https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/xl710-10-40-controller-spec-update.pdf https://www.intel.com/content/dam/www/public/us/en/documents/specification-updates/xl710-10-40-controller-spec-update.pd… that :
Starting from NVM image revision 5.05, the 710-series device does not process IEEE 1588 (TimeSync) PTP packets in the UDP payload. It only processes PTP packets using the Layer 2 packet format.
Starting in NVM 6.01, this is supported.
So the Firmware of the NIC apparently supports it since the start of 2018.
I have been able to find in the changelog of the i40e driver from end 2016 :
changelog for i40e-1.5.25
* De-feature L3 (UDP) PTP frame detection and timestamping on XL710 devices.
Support for L2 PTP frame detection and timestamping remains.
But I can't find a recent driver changelog that says that the feature is back in the driver.
Is the feature back in the driver or not yet ?
Thank you.
Hi VolCoM,
Thank you for posting in Wired Communities. I will further check on this then update you.
Sharon T
VolCoM
Found it. It's indeed in the driver. A simple ethtool -T showed the information I was looking for. Thank you !
