Host OS: Ubuntu 16.04 LTS
Hypervisor: Xen 4.6.0
Kernel version: 4.4.0-22-generic
Driver version: i40e-1.5.18
NVM version: 5.02
Guest OS: Windows Server 2012 R2
Guest Driver version: 20.7.1
I'm trying to forward the ports of the card to a guest Windows VM. An example of forwarding just one port:
# echo 1 > /sys/class/net/ens2f0/device/sriov_numvfs
# /sbin/ip link set ens2f0 vf 0 mac 02:00:00:00:00:00
# xl pci-assignable-add 02:02.0
Added to Xen VM .cfg:
pci = ['0000:02:02.0']
All of that works and the VM starts fine and sees the card. Xen reports that it added it:
[26326.586765] i40e 0000:02:00.0 ens2f0: adding 68:05:ca:33:0a:59 vid=0
[26326.586774] i40e 0000:02:00.0 ens2f0: adding 68:05:ca:33:0a:59 vid=1
[26326.595995] i40e 0000:02:00.0: Allocating 1 VFs.
[26326.697778] pci 0000:02:02.0: [8086:154c] type 00 class 0x020000
[26326.697973] pci 0000:02:02.0: Max Payload Size set to 256 (was 128, max 2048)
[26329.893582] i40e 0000:02:00.0: Setting MAC 02:00:00:00:00:00 on VF 0
[26329.965339] i40e 0000:02:00.0: Reload the VF driver to make this change effective.
[26366.200750] pciback 0000:02:02.0: seizing device
[26366.200815] pciback 0000:02:02.0: enabling device (0000 -> 0002)
[26472.867101] xen_pciback: vpci: 0000:02:02.0: assign to virtual slot 0
[26472.867643] pciback 0000:02:02.0: registering for 4
I install the drivers and Windows 'see' the card. The problem is the reported state goes into a cycle:
Connected @ 10GB
Connected @ 40GB
Disconnected
When this happens, in dmesg on the host:
[26624.137415] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26635.075640] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26645.903762] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26656.669642] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26667.904191] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26679.013381] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26689.966331] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26701.028906] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26712.372668] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26723.154159] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26733.935320] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26744.685130] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
[26756.075844] i40e 0000:02:00.0: VF 0 failed opcode 11, retval: -10
This same issue happens using the built in kernel i40e and also i40e-1.5.18. Am I doing something wrong?
Thank you for posting your concern in Intel Wired Ethernet communities.
You might need to unload the VF driver from the host OS, kindly refer to page 14 of this article - http://www.intel.com/content/www/us/en/embedded/products/networking/xl710-sr-iov-config-guide-gbe-linux-brief.html
Additional reference related to SR-IOV implementation:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000005722.html
Vince
VF driver already blacklisted:
# cat /lib/modprobe.d/vm-blacklist.conf
# Don't try and use VFs so that we can pass them through
blacklist i40evf
# lsmod | grep i40
i40e 319488 0
vxlan 49152 1 i40e
ptp 20480 2 igb,i40e
I notice that NVM 5.02 has gotten pulled. Could this be an issue caused by 5.02?
The NVM files have been temporarily removed and we will post the updates as soon as we can. For your issue, i'm still checking on it.
Vince
Hi Jailbird, while we're still checking your concern, please share the product label description found of your X710-DA4. This information is visible in the white sticker found on the physical adapter.
Kindly refer to sample label from the link below:
http://www.intel.com/content/www/us/en/support/network-and-i-o/ethernet-products/000007060.html
regards,
Vince
Hi Jailbird, we'd like to follow-up the product label description of your X710-DA4. Thank you.
Vince
The sticker on the front has:
008 5214AD
H58361-002
The sticker on the back has:
INTEL(R) ETHERNET CNA X710-DA4 FH
932576
X710DA4FHBLK
Date of Manufacture
12/2014
Made in Malaysia
Hi Jailbird,
Thank you for the information. we will further check on your inquiry,
rgds,
wb
Hi Jailbird,
Good day. There is a newer i40e driver available at sourceforge.please try install and check:
https://sourceforge.net/projects/e1000/files/i40e%20stable/
Also, could provide the output of the 'ethtool -i' command for the specific XL710 port in question and any kernel logs?
Please update if you have tried the same NIC in a non-virtualized environment running the same guest OS and versions?
wb
HI Jailbird,
Please feel free to update the test result using the driver provided on my previous post
and the additional information.
thanks,
wb
