Ethernet Products
4810 Discussions
X710 Ethernet Adapter not Being Brought Up by IXGBE Driver
KWitt4
Greetings Wired Ethernet,
So I have two X710-DA4 adapters installed into two different servers (different motherboards on each) experiencing the same problem on both bringing up the interfaces.
I'm running SLES 11 SP 3 on both (I believe this issue would exist on RHEL or SLES 11 sp4 as well though, still waiting to verify)
lspci | grep Eth output:
01:00.0 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.1 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.2 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.3 Ethernet controller: Intel Corporation Device 1572 (rev 01)
42:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
The Device 1572 is the X710 DA4 interfaces, but ifconfig -a only show's the on-board 1G I350 interfaces.
I've updated to ixgbe driver 4.1.5 , when I rmmod and insmod ixgbe , dmesg only reports:
[ 101.916366] Disabling lock debugging due to kernel taint
[ 101.918805] Intel(R) 10 Gigabit PCI Express Network Driver - version 4.1.5
[ 101.918809] Copyright (c) 1999-2015 Intel Corporation.
[ 1370.304497] Intel(R) 10 Gigabit PCI Express Network Driver - version 4.1.5
[ 1370.304503] Copyright (c) 1999-2015 Intel Corporation.
I also found two versions of NVM Update Tool (1.24.33.08) and (1.25.20.12)
It shows the following output on both:
Num Description Device-Id B:D Adapter Status
01) Intel(R) I350 Gigabit Network Connecti 8086-1521 66:00 Update not available
02) Intel(R) Ethernet Converged Network Ad 8086-1572 01:00 Access error
I looked at some of the BIOS PCI settings, but I wouldn't know which ones to tune that might hint at what is happening. A verbose look at lspci for those interfaces show that the PCI device is training up at gen3 x8 successfully:
Subsystem: Intel Corporation Device 0001
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at 383ffe800000 (64-bit, prefetchable) [size=8M]
Region 3: Memory at 383fff818000 (64-bit, prefetchable) [size=32K]
Expansion ROM at ab280000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port # 0, Speed 8GT/s, Width x8, ASPM L1, Latency L0 <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 8c-7f-43-ff-ff-ed-e0-00
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 32, Total VFs: 32, Number of VFs: 32, Function Dependency Link: 00
VF offset: 16, stride: 1, Device ID: 154c
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 0000383fff600000 (64-bit, prefetchable)
Region 3: Memory at 0000383fff9a0000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [1d0 v1] # 19
Any help or ideas would be greatly appreciated on next steps or data collection that might be useful.
CARL_W_Intel
The X710 and XL710 use the i40e driver. The IXGBE driver will not recognize the X710/XL710. This should help: https://downloadcenter.intel.com/download/24411/Network-Adapter-Driver-for-PCI-E-40-Gigabit-Network-Connections-under-Linux- Download Network Adapter Driver for PCI-E* 40 Gigabit Network Connections under Linux*
