Greetings Wired Ethernet,
So I have two X710-DA4 adapters installed into two different servers (different motherboards on each) experiencing the same problem on both bringing up the interfaces.
I'm running SLES 11 SP 3 on both (I believe this issue would exist on RHEL or SLES 11 sp4 as well though, still waiting to verify)
lspci | grep Eth output:
01:00.0 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.1 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.2 Ethernet controller: Intel Corporation Device 1572 (rev 01)
01:00.3 Ethernet controller: Intel Corporation Device 1572 (rev 01)
42:00.0 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.1 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.2 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
42:00.3 Ethernet controller: Intel Corporation I350 Gigabit Network Connection (rev 01)
The Device 1572 is the X710 DA4 interfaces, but ifconfig -a only show's the on-board 1G I350 interfaces.
I've updated to ixgbe driver 4.1.5 , when I rmmod and insmod ixgbe , dmesg only reports:
[ 101.916366] Disabling lock debugging due to kernel taint
[ 101.918805] Intel(R) 10 Gigabit PCI Express Network Driver - version 4.1.5
[ 101.918809] Copyright (c) 1999-2015 Intel Corporation.
[ 1370.304497] Intel(R) 10 Gigabit PCI Express Network Driver - version 4.1.5
[ 1370.304503] Copyright (c) 1999-2015 Intel Corporation.
I also found two versions of NVM Update Tool (1.24.33.08) and (1.25.20.12)
It shows the following output on both:
Num Description Device-Id B:D Adapter Status
01) Intel(R) I350 Gigabit Network Connecti 8086-1521 66:00 Update not available
02) Intel(R) Ethernet Converged Network Ad 8086-1572 01:00 Access error
I looked at some of the BIOS PCI settings, but I wouldn't know which ones to tune that might hint at what is happening. A verbose look at lspci for those interfaces show that the PCI device is training up at gen3 x8 successfully:
Subsystem: Intel Corporation Device 0001
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0, Cache Line Size: 64 bytes
Interrupt: pin A routed to IRQ 11
Region 0: Memory at 383ffe800000 (64-bit, prefetchable) [size=8M]
Region 3: Memory at 383fff818000 (64-bit, prefetchable) [size=32K]
Expansion ROM at ab280000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable- Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported-
RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port # 0, Speed 8GT/s, Width x8, ASPM L1, Latency L0 <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- Retrain- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-
LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-, Selectable De-emphasis: -6dB
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 8c-7f-43-ff-ff-ed-e0-00
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 32, Total VFs: 32, Number of VFs: 32, Function Dependency Link: 00
VF offset: 16, stride: 1, Device ID: 154c
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 0000383fff600000 (64-bit, prefetchable)
Region 3: Memory at 0000383fff9a0000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [1d0 v1] # 19
Any help or ideas would be greatly appreciated on next steps or data collection that might be useful.
The X710 and XL710 use the i40e driver. The IXGBE driver will not recognize the X710/XL710. This should help: https://downloadcenter.intel.com/download/24411/Network-Adapter-Driver-for-PCI-E-40-Gigabit-Network-Connections-under-Linux- Download Network Adapter Driver for PCI-E* 40 Gigabit Network Connections under Linux*
