Ethernet Products
5716 Discussions
X710 T2L (for OCP 3.0) second port not getting IP address from DHCP
kevin3456
Driver: 1.18.370
NVM: 9.40
Windows Server 2022
First time installing this NIC into a new server.
1st port (left side) connects to DHCP and our network without issue.
2nd port (right side) does not connect to our network.
  • Moving the cable from the left port to the right port results in Network Connections showing the adapter stuck in "Identifying..."
  • Settings > Network & Internet shows "You're connected to the internet" in red, bold type, and it states: "Unidentified Network, Public Network" (left side states "Network, Public Network")
  • MAC for this port is seen in BIOS, DHCP is Enabled (all settings are identical to port 1)
  • ipconfig/all shows this port is not reaching DHCP.
We're using the same cable plugged into the same patch panel port, can anyone see a reason why the 2nd port of this NIC will not connect to our network, where the 1st port will?
Irwan_Intel
Hello Kevin3456,
Thank you for your posting in Intel Ethernet Communities.
Based on the information you provided, could you please verify if the latest driver was installed? We have the latest released version 29.0
https://www.intel.com/content/www/us/en/download/15084/intel-ethernet-adapter-complete-driver-pack.html
Additionally, please inspect the second port physically. Ensure there are no bent pins or debris obstructing the connection. You could also try to swap the network cable with a known working one to rule out cable issues.
Irwan_Intel
kevin3456
Hello Irwan,
It looks like the second port on that NIC was defective.
PROset was giving a Cable Link Status: Failed error during a connection test. We acquired a different NIC and updated its driver and firmware, both ports are working.
Kevin
Irwan_Intel
Hello kevin3456,
I’m glad to hear that you acquired a different NIC, and both ports are working. If you're looking for warranty request, please reach out to the link below:
https://supporttickets.intel.com/s/?language=en_US
Irwan_Intel
Irwan_Intel
Hello kevin3456
As we haven't received a response from you, we'll be closing this thread.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Irwan_Intel
