I am trying to get current temperature readings for my NIC which is a X710-T4. Looking at the datasheets I was getting confused as to if this is an enabled feature or not.
Ideally, I'm looking for individual temperatures for each of the ports if possible.
If temperature readings are not possible, I'd also be interested in just checking the PHY Temp Alarm status.
I'm on a Linux x64 system with the following settings:
driver: i40e
version: 2.25.9
firmware-version: 9.50
Thanks, marist
Hello Marist,
Greetings for the day!!
Thank you for posting in the Intel Community. We sincerely apologize for the delay in our response. We have received your concern and would like to assure you that assisting you is our top priority.
Could you kindly let us know if the issue has been resolved, or if you require further assistance from us? Your prompt response will greatly help us in diagnosing and resolving the issue as quickly as possible.
We appreciate your patience and understanding, and we look forward to hearing from you soon.
Kuzhanthai Yesu R
Hello Marist,
This is to follow up on the issue you reported to us.
Could you please confirm if the issue has been resolved or if you still require our assistance? Your timely response will help us diagnose and address the issue more efficiently.
We look forward to hearing from you soon.
Kuzhanthai Yesu R
Hello Marist,
This is the final follow-up regarding the issue you reported to us.
Could you please let us know if the issue has been resolved or if you still need our help? Your prompt response will assist us in diagnosing and addressing the issue more effectively.
If we don't hear back from you soon, we'll assume the issue has been resolved and will proceed to close the case.
Please feel free to respond to this email at your earliest convenience..
Kuzhanthai Yesu R
