Ethernet Products
5707 Discussions
X710 Update not available
AFier
The i40e driver reports:
i40e 0000:04:00.0: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
When I try to update the NVM using NVM Update Utility for Intel (I tried with version 4.42, 4.5 and the latest 5.04), the tool reports 'Update not available'
$lspci -vvv
04:00.0 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GbE SFP+ (rev 01)
Subsystem: Intel Corporation Ethernet 10G 4P X710 Adapter
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- SERR-
Latency: 0
Interrupt: pin A routed to IRQ 32
Region 0: Memory at 9d000000 (64-bit, prefetchable) [size=16M]
Region 3: Memory at 9e018000 (64-bit, prefetchable) [size=32K]
Expansion ROM at 9e100000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
Status: D0 NoSoftRst+ PME-Enable- DSel=8 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+
DevCtl: Report errors: Correctable- Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port # 0, Speed 8GT/s, Width x8, ASPM L1, Exit Latency L0s <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot-
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 65ms to 210ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
Product Name: X710 10GbE Controller
Read-only fields:
[V0] Vendor specific: FFV16.5.0
[PN] Part number: DDJKY
[MN] Manufacture ID: 31 30 32 38
[V1] Vendor specific: DSV1028VPDR.VER2.0
[V3] Vendor specific: DTINIC
[V4] Vendor specific: DCM10010391C521010391C532010391C543010391C514020391C525020391C536020391C547020391C518030391C529030391C53A030391C54B030391C51C040391C52D040391C53E040391C54F040391C5
[V5] Vendor specific: NPY4
[V6] Vendor specific: PMTA
[V7] Vendor specific: NMVIntel Corp
[V8] Vendor specific: L1D0
[RV] Reserved: checksum good, 1 byte(s) reserved
Read/write fields:
[Y1] System specific: CCF1
End
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt+ RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UESvrt: DLP+ SDES+ TLP+ FCP+ CmpltTO+ CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC+ UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
CEMsk: RxErr+ BadTLP+ BadDLLP+ Rollover+ Timeout+ NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn+ ChkCap+ ChkEn+
Capabilities: [140 v1] Device Serial Number 80-17-03-ff-ff-fe-fd-3c
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [1d0 v1] # 19
Kernel driver in use: i40e
Hi adrianf0,
Thank you for contacting Intel.
We would like to request for your adapter details, please answer below:
1. Serial number:
You can find the serial number on a barcode sticker.
2. results of ethtool -i
We look forward to your reply.
Sincerely,
Sandy
AFier
Hi Sandy,
1. Serial number ( I 2 stickers):
DP/N 0DDJKY MY-0DDJKY-12402-552-00LK-A00
3CFDFE027440 032 1815AD H53934-006
2. ethtool -i
driver: i40e
version: 1.5.16
firmware-version: 4.41 0x80001869 0.0.0
bus-info: 0000:05:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Adrian
Hi Adrian,
Thank you for your information.
Your adapter is an OEM (original equipment manufacturer) unit. Base on the part number, it is used on Dell* systems. Please try to update the card using the firmware bundle from Dell*:
http://www.dell.com/support/home/us/en/04/Drivers/DriversDetails?driverId=8028X
*This link will take you off of the Intel website. Intel does not control the content of the destination website.
Hope this is helpful.
Sincerely,
Sandy
AFier
It worked. Thank you.
Hi Adrian,
Glad to know that it worked. Thank you for the updates. Have a nice day!
Sincerely,
Sandy
