Ethernet Products
5742 Discussions
X710 - eeprom check failed - Tx/Rx traffic disabled
NNira1
Hello, I am using following Ethernet controller on one of our systems, and once in a while I run into following error after bootup, resulting in the port not sending/receiving packets.
2016-12-13T01:06:55.499000+00:00 kernel: i40e 0000:20:00.3: eeprom check failed (-2), Tx/Rx traffic disabled
Following is the current version we use (which is quite old; we are in process of upgrading). But does anyone know if this is a known issue and may be fixed in an upgraded driver and/or NVM?
System# lspci -s 0000:20:00.3
20:00.3 Ethernet controller: Intel Corporation Ethernet Controller X710 for 10GBASE-T (rev 01)
System# ethtool -i eth1
driver: i40e
version: 1.3.47
firmware-version: 4.43 0x80001c3f 1.1018.0
bus-info: 0000:20:00.3
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
System#
Thank you very much!
Hi JayN,
Thank you for posting your query in Wired Ethernet Communities.
we have an updated firmware version 5 for X710 Network adapter. However, since your X710
is integrated to your system. I'd suggest to contact system manufacturer for the available
update.
regards,
Vince
Hi JayN,
I'd like to check if you still need assistance regarding X710.
regards,
Vince
NNira1
Hello Vince, We will be upgrading the firmware, and will let you know if further assistance is needed.
Thank you very much for your response.
Thanks JayN for the update, please post your result once available.
regards,
Vince
