I have a VM using SRIOV interfaces based on X710 interfaces. This VM is connected to a physical router through the VF.
I would like to enable vlan tagging on the VM.
I can ping the physical router from the VM if I'm not using VLAN tagging on the interface.
When I add VLAN tagging on the interface (on the VM and on the physical router), the network connectivity is broken.
The physical router correctly receives the packets/frames from the VM.
The VM receives the packets/frames but without a VLAN tag, it seems that the VLAN tag has been stripped.
Here are some informations on my setup:
[root@SLI-SRV3 sysadmin]# ethtool -i eth1
driver: i40e
version: 1.6.27-k
firmware-version: 6.00 0x800034e6 18.3.6
expansion-rom-version:
bus-info: 0000:19:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@SLI-SRV3 sysadmin]# ip link show eth1
3: eth1: mtu 1500 qdisc mq portid 246e967eaabe state UP mode DEFAULT qlen 1000
link/ether 24:6e:96:7e:aa:be brd ff:ff:ff:ff:ff:ff
vf 0 MAC 52:54:00:5d:6a:60, spoof checking on, link-state auto, trust off
VIRSH network config:
Any idea about what could be the issue ?
Stephane
- Tags:
- GiLAN
Hi Slitkowski,
Thank you for posting in Wired Communities. What is the exact Linux operating system used here? Please try run the SSU utility and send me the log file.
https://downloadcenter.intel.com/download/26735/Intel-System-Support-Utility-for-the-Linux-Operating-System
Sharon T
I'm running a RHEL 7.4.
# uname -a
Linux SLI-SRV3 3.10.0-693.5.2.el7.x86_64 # 1 SMP Fri Oct 13 10:46:25 EDT 2017 x86_64 x86_64 x86_64 GNU/Linux
SSU result is attached.
Hi Slitkowski,
Thank you for the information. Let me further investigate on this.
Sharon T
Hi Slitkowski,
Please be informed I am still investigating on this, will update the post once there is any finding.
Sharon T
Hi Slitkowski,
Please try check on the information regarding VLAN tag stripping in our READMe file at https://downloadmirror.intel.com/24693/eng/readme.txt https://downloadmirror.intel.com/24693/eng/readme.txt (extracted here for your reference). Try turning off the rxvlan and check if it works.
Setting VLAN Tag Stripping
If you have applications that require Virtual Functions (VFs) to receive
packets with VLAN tags, you can disable VLAN tag stripping for the VF. The
Physical Function (PF) processes requests issued from the VF to enable or
disable VLAN tag stripping. Note that if the PF has assigned a VLAN to a VF,
then requests from that VF to set VLAN tag stripping will be ignored.
To enable/disable VLAN tag stripping for a VF, issue the following command
from inside the VM in which you are running the VF:
ethtool -K rxvlan on/off
or alternatively:
ethtool --offload rxvlan on/off
The MAC address shown is from Dell, can you confirm if the NIC is an embedded NIC on the system? or a standalone NIC comes with Dell system?
Please feel free to update me.
Sharon T
I tried, but it does work. VLAN is still stripped:
[root@SLI-SRV3 sysadmin]# ethtool -k eno1
Features for eno1:
rx-checksumming: on
tx-checksumming: on
tx-checksum-ipv4: on
tx-checksum-ip-generic: off [fixed]
tx-checksum-ipv6: on
tx-checksum-fcoe-crc: off [fixed]
tx-checksum-sctp: on
scatter-gather: on
tx-scatter-gather: on
tx-scatter-gather-fraglist: off [fixed]
tcp-segmentation-offload: on
tx-tcp-segmentation: on
tx-tcp-ecn-segmentation: on
tx-tcp6-segmentation: on
tx-tcp-mangleid-segmentation: off
udp-fragmentation-offload: off [fixed]
generic-segmentation-offload: on
generic-receive-offload: on
large-receive-offload: off [fixed]
rx-vlan-offload: off
tx-vlan-offload: on
ntuple-filters: on
receive-hashing: on
highdma: on
rx-vlan-filter: on [fixed]
vlan-challenged: off [fixed]
tx-lockless: off [fixed]
netns-local: off [fixed]
tx-gso-robust: off [fixed]
tx-fcoe-segmentation: off [fixed]
tx-gre-segmentation: on
tx-ipip-segmentation: on
tx-sit-segmentation: on
tx-udp_tnl-segmentation: on
tx-mpls-segmentation: off [fixed]
fcoe-mtu: off [fixed]
tx-nocache-copy: off
loopback: off [fixed]
rx-fcs: off [fixed]
rx-all: off [fixed]
tx-vlan-stag-hw-insert: off [fixed]
rx-vlan-stag-hw-parse: off [fixed]
rx-vlan-stag-filter: off [fixed]
busy-poll: off [fixed]
tx-gre-csum-segmentation: on
tx-udp_tnl-csum-segmentation: on
tx-gso-partial: on
tx-sctp-segmentation: off [fixed]
l2-fwd-offload: off [fixed]
hw-tc-offload: off [fixed]
11:43:12.537863 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype IPv4 (0x0800), length 114: (tos 0x0, ttl 255, id 0, offset 0, flags [none], proto: ICMP (1), length: 100) 66.0.0.5 > 66.0.0.6: ICMP echo request, id 61806, seq 0, length 80
11:43:14.539047 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype IPv4 (0x0800), length 114: (tos 0x0, ttl 255, id 1, offset 0, flags [none], proto: ICMP (1), length: 100) 66.0.0.5 > 66.0.0.6: ICMP echo request, id 61806, seq 1, length 80
11:43:16.540645 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype IPv4 (0x0800), length 114: (tos 0x0, ttl 255, id 2, offset 0, flags [none], proto: ICMP (1), length: 100) 66.0.0.5 > 66.0.0.6: ICMP echo request, id 61806, seq 2, length 80
11:43:18.542226 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype IPv4 (0x0800), length 114: (tos 0x0, ttl 255, id 3, offset 0, flags [none], proto: ICMP (1), length: 100) 66.0.0.5 > 66.0.0.6: ICMP echo request, id 61806, seq 3, length 80
11:43:20.544015 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype IPv4 (0x0800), length 114: (tos 0x0, ttl 255, id 4, offset 0, flags [none], proto: ICMP (1), length: 100) 66.0.0.5 > 66.0.0.6: ICMP echo request, id 61806, seq 4, length 80
I have a PCIE X710 Dual port 10G card and also a combo i350 DP+X710 DP as a LOM card.
Both have the same issue.
I found a way to get the VLAN tag.
I need to set a VLAN on the VF and remove it:
[root@SLI-SRV3 images]# ip link set eno1 vf 1 vlan 10
[root@SLI-SRV3 images]# ip link set eno1 vf 1 vlan 0
15:18:26.214811 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype 802.1Q (0x8100), length 118: vlan 100, p 0, ethertype IPv4, 66.0.0.5 > 66.0.0.6: ICMP echo request, id 24942, seq 27, length 80
15:18:28.216687 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype 802.1Q (0x8100), length 118: vlan 100, p 0, ethertype IPv4, 66.0.0.5 > 66.0.0.6: ICMP echo request, id 24942, seq 28, length 80
15:18:30.218106 In 10:f3:11:1c:f8:ff > 52:54:00:49:82:40, ethertype 802.1Q (0x8100), length 118: vlan 100, p 0, ethertype IPv4, 66.0.0.5 > 66.0.0.6: ICMP echo request, id 24942, seq 29, length 80
It looks like a bug in the driver.
Hi Slitkowski,
Thank you for the update and sharing the information, I am glad the issue is fixed as well. Just to double check for the i40e driver, where did you download the driver from? Thank you.
Sharon T
I consider this as a workaround rather than a fix.
There is no reason to strip the VLAN by default as the "ip link set eno1 vf 1 vlan 0" normally sets back the vf to its default vlan config.
The driver is the one provided by Redhat. I did not change it.
Hi Slitkowski,
Thank you for the information. Let me check in case there is information to share.
Sharon T
Hi Slitkowski,
I have forwarded your feedback to our engineering team. Just would like to double check
if there is switch between the router and the X710 NIC?
Sharon T
No there is no switch, my router that initiates the PING and the server which hosts the VM are connected using a back to back cable.
Hi Slitkowski,
Thank you for the confirmation.
Sharon T
Hi Slitkowski,
Please be informed that we already share your information with our engineering team and they will determine if a driver update is necessary.
Sharon T
