Ethernet Products
4635 Discussions
X722 PCI card firmware
MustafaB
Hi Folks,
I need to upgrade my card to X722.
[root@esxi11:~] lspci | grep 722
0000:06:00.0 Ethernet controller: Intel(R) Ethernet Connection X722 for 10GbE SFP+
0000:06:00.1 Ethernet controller: Intel(R) Ethernet Connection X722 for 10GbE SFP+
The latest 700Series indicate it should contain a x722 bin file but it doesn't not.
All images for 710
ls -l | grep 710 | wc
107
ls -l | grep 722 | wc
0 0 0
I found a download that indicates BP ( zero explanation)
X722_NVMUpdate_v4.10_EFIx64
X722_BNP_SFI_2x10G_P01_NCSI_4p10_80001A76.bin
CURRENT FAMILY: 1.0.0
CONFIG VERSION: 1.14.0
;Update
;For verification of NUP
;BNP SFP+
BEGIN DEVICE
DEVICENAME: X722
VENDOR: 8086
DEVICE: 37D0
NVM IMAGE: X722_BNP_SFI_2x10G_P01_NCSI_4p10_80001A76.bin
SKIP OROM: FALSE
EEPROM MAP: OCP_Configuration.txt
EEPID: 80001A76
REPLACES: 80000ACE 80000D07 80000D2F 80001573
RESET TYPE: REBOOT
END DEVICE
I copy nvmupdaten64e ( it for ESXi tool to a same dir) where the image is.
it detects x522 adapter but it doesn't detect x722
Num Description Ver.(hex) DevId S:B Status
01) Intel(R) Ethernet Connection 1.19(1.13) 15AD 00:003 Update not
X552/X557-AT 10GBASE-T available
Tool execution completed with the following status: Device not found.
Press any key to exit.
I also found this WFP_v4.10_X722_NVMUpdate_EFIx64 but no explanation as well.
AlfredoS_Intel
Hi Mustafa,
Thank you for posting in our Intel® Ethernet Communities Page.
We are sorry to hear about the issue that you are experiencing with your network adapter.
So we would have a better understanding of your issue, please provide the following information:
1. Usually the error that you encounter happens if you update the firmware of a non-authentic Intel retail card. It could be an OEM card which is the reason why you are getting the error. To check this, please provide us pictures of the front, back, and all of the stickers on the actual unit.
2. Kindly provide us the results of this command: ethtool -i ethx where ethx is the Ethernet port.
3. The software only runs on Windows and Linux, so you may need to via the EFI shell.
We look forward to hearing from you. If we do not get your reply, we will follow up after 3 business days.
Alfred S
Intel® Customer Support
MustafaB
Hi Folks,
I validate this card with Intel back in Aug and send the Logo and provide a picture, all card original intel.
I can't run that command in ESXi since it doesn't detect the adapter at all.  Please check the output I posted.
As I pointed out both Linux and Window see adapter,  Both Update utils see adapter and
I update to the latest firmware.
ESXi latest tool doesn't see an adapter.
UEFI BIOS same.
Linux ( Please check careful everything is here)
06:00.1 Ethernet controller: Intel Corporation Ethernet Connection X722 for 10GbE SFP+ (rev 04)
        Subsystem: Intel Corporation Ethernet Network Adapter X722-2
        Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 32 bytes
        Interrupt: pin A routed to IRQ 19
        NUMA node: 0
        Region 0: Memory at 92000000 (64-bit, prefetchable) [size=16M]
        Region 3: Memory at 93808000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at fb280000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
                Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Address: 0000000000000000 Data: 0000
                Masking: 00000000 Pending: 00000000
        Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00001000
        Capabilities: [a0] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
                DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
                        RlxdOrd- ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
                        MaxPayload 256 bytes, MaxReadReq 4096 bytes
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr- TransPend-
                LnkCap: Port #0, Speed 2.5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <64ns, L1 <1us
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
                LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 2.5GT/s (ok), Width x1 (ok)
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range AB, TimeoutDis+, NROPrPrP-, LTR-
                         10BitTagComp-, 10BitTagReq-, OBFF Not Supported, ExtFmt-, EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS-, TPHComp-, ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
                         AtomicOpsCtl: ReqEn-
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
                         EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
        Capabilities: [e0] Vital Product Data
                Product Name: Example VPD
                Read-only fields:
                        [V0] Vendor specific:
                        [RV] Reserved: checksum good, 0 byte(s) reserved
                End
        Capabilities: [100 v2] Advanced Error Reporting
                UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt+ UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr-
                CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [140 v1] Device Serial Number 0c-ca-79-ff-ff-1e-f2-f8
        Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
                ARICap: MFVC- ACS-, Next Function: 0
                ARICtl: MFVC- ACS-, Function Group: 0
        Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
                IOVCap: Migration-, Interrupt Message Number: 000
                IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy-
                IOVSta: Migration-
                Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 01
                VF offset: 79, stride: 1, Device ID: 37cd
                Supported Page Size: 00000553, System Page Size: 00000001
                Region 0: Memory at 0000000093000000 (64-bit, prefetchable)
                Region 3: Memory at 0000000093910000 (64-bit, prefetchable)
                VF Migration: offset: 00000000, BIR: 0
        Capabilities: [1a0 v1] Transaction Processing Hints
                Device specific mode supported
                No steering table available
        Capabilities: [1b0 v1] Access Control Services
                ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
                ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
        Kernel driver in use: i40e
        Kernel modules: i40e
Test
root@ubuntu:/cdrom/intel/25_4/APPS/NVMCHECK/Linux_x64# ./nvmcheck64e /VERIFY /NIC=3
Intel(R) NVM Integrity Verification Tool
Nvmcheck version 1.35.42.07
QV SDK version 2.35.42.01
Copyright(C) 2012 - 2020 Intel Corporation.
NVM module: Option ROM.
NVM Integrity verification PASSED.
NVM module: PE image.
NVM module: PHY PLL 0 Configuration.
NVM module: PHY 0 Configuration.
NVM module: PHY PLL 1 Configuration.
NVM module: PHY 1 Configuration.
NVM module: EMP image.
root@ubuntu:/cdrom/intel/25_4/APPS/NVMCHECK/Linux_x64# ./nvmcheck64e /HEADER /NIC=3
CSS Header:
        -moduleType 0x00000006
        -headerLen 0x000000A1
        -headerVersion 0x00010000
        -moduleID 0x00000000
        -moduleVendor 0x00008086
        -date 0x20130530
        -size 0x0004E000
        -keySize 0x00000040
        -modulusSize 0x00000040
        -exponentSize 0x00000001
        -lad_srev 0x00000000
        -reserved 0x00000000
        -lad_fw_entry_offset 0x0000014C
        -lad_fl_dev_offset 0x00000000
        -reserved:
        0x00000000 0x00000005 0x00000000 0x00000000 0x00000000 0x00000000
        0x00000000 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x0004E000
        -keySize 0x00000040
        -reserved:
        0x00000000 0x00000002 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x00000800
        -keySize 0x00000040
        -reserved:
        0x00000000 0x00000006 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x00000800
        -keySize 0x00000040
        -reserved:
        0x00000000 0x00000007 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x00000800
        -keySize 0x00000040
        -reserved:
        0x00000000 0x00000008 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x00000800
        -keySize 0x00000040
        -reserved:
        0x00000000 0x00000009 0x00000000 0x00000000 0x00000000 0x00000000
CSS Header:
        -date 0x20130530
        -size 0x0004E000
        -keySize 0x00000040
        -lad_srev 0x00000010
        -lad_fw_entry_offset 0x00133000
        -reserved:
        0x00000000 0x00000001 0x00000000 0x00000000 0x00000000 0x00000000
[00:006:00:01]: Intel(R) Ethernet Network Adapter X722-2
        Vendor : 8086
        Device : 37D0
        Subvendor : 8086
        Subdevice : 0002
        Revision : 4
        LAN MAC : F8F21E79CA0D
        Alt MAC : 000000000000
        SAN MAC : FFFFFFFFFFFF
        ETrackId : 8000265A
        SerialNumber : 0CCA79FFFF1EF2F8
        NVM Version : 5.16(5.10)
        PBA : K20564-001
        VPD status : Valid
        VPD size : 25
        NVM update : No config file entry
          checksum : Valid
        OROM update : No config file entry
          CIVD : 1.2829.0
          PXE : 1.1.18, checksum Not Relevant
          ISCSI : 3.1.63, checksum Not Relevant
          EFI : 4.4.12, checksum None
          SMCLP : 3.1.21, checksum Valid
VMware
Latest Native driver loaded
---  1.10.9.0
 Version: 1.10.9.0-1OEM.700.1.0.15525992
 Build Type: release
 License: Intel
 Required name-spaces:
  com.vmware.vmkapi#v2_6_0_0
 Parameters:
  EEE: array of int
    Energy Efficient Ethernet feature (EEE): 0 = disable, 1 = enable, (default = 1)
  MaxRdmaInts: int
    Maximum RDMA Interrupts (default = 16)
  RDMA: array of int
    Enable RDMA support 0 = disable, 1 = enable, (default = 0)
  LLDP: array of int
    Link Layer Discovery Protocol (LLDP) agent: 0 = disable, 1 = enable, (default = 1)
  TxITR: int
    Default TX interrupt interval (0..0xFFF), in microseconds, (default = 100)
  RxITR: int
    Default RX interrupt interval (0..0xFFF), in microseconds (default = 50)
  trust_all_vfs: array of int
    Always set all VFs to trusted mode 0 = disable (default), other = enable
  max_vfs: array of int
    Maximum number of VFs to be enabled (0..128)
  DRSS: array of int
    Enable/disable the DefQueue RSS(default = 0 )
  RSS: array of int
    Enable/disable the NetQueue RSS( default = 1 )
  VMDQ: array of int
    Number of Virtual Machine Device Queues: 0/1 = disable, 2-16 enable (default =8)
The adapter does not detect so I can't even run eth tool nor any tools.
I only see a PCI devices
AlfredoS_Intel
Hi Mustafa,
Thank you providing those information.
Please allow us some time to check on this.
We will get back to you no later than 3 business days from now.
Alfred S
AlfredoS_Intel
Hi Mustafa,
Thank you for waiting for our update.
We are already beginning the preliminary checks on your issue, and we came up with these questions to help us with our investigation:
1. May we know the version of the VMWare ESXI software that you are using
2. Does the systems where these cards are integrated to all have an the same EFI version? You can see the version the moment you boot to the EFI shell?
We look forward to your reply. Should we not get your reply, we will follow up after three business days.
Alfred S
MustafaB
Can you please check the logs ?
All your questions in that log in the same thread.
You asked me for a picture I send you a picture and it has clearly seen in that pic it an Intel PCI card.
Please focus a bit.
Issue number one.  ( Driver issue )
Again please check the Cross-check log.
For vSphere 7.0 Update 1 I test the latest driver posted in Oct 2020.
Version ESXi. 6.5 latest update doesn't detect the card. (used latest driver for i40en)
Version ESXI 6.7 latest update doesn't detect card. (used latest driver for i40en)
Version ESXi 7.0 latest update doesn't t detect the card. (used latest driver for i40en)
Issue two (NVupdate tool)
UEFI  - doesn't detect the card. ( must be fixed)
ESXi - doesn't detect the card. ( must be fixed)
Linux - DOES detect card and firmware updated.
Win - DOES detect card and firmware updated.
AlfredoS_Intel
Hi Mustafab,
Thank you for providing that information.
We are humbly sorry if you felt that we are not checking the logs. We asked that question to confirm. Rest assured, we will closely look at your case and treat it with priority.
We will continue checking this and the information that provided is invaluable to us.
Please allow us some time to check on this. We hope for your understanding regarding this
Alfred S
AlfredoS_Intel
Hi Mustafab,
We have already begun the initial stages of the investigation and our team would like to get specifics on some of the information that you have provided. Please answer the following questions:
1. May we know what specific driver version did you use for each ESXI version that you have tested?
2. Did you download the drivers from this page, https://www.vmware.com/resources/compatibility/detail.php?deviceCategory=io&productid=48643&vcl=true?
3. Did you get any errors when installing the driver?
4. We noticed that your account name on your profile shows VMWare. In line with this, is the card for business use or for personal use?
5. May we know how many cards are affected?
6. Kindly provide the PBA number of the Intel® Ethernet Network Adapter X722-DA2.
7. What is the specific error that you are getting when you run the NVME tool?
Alfred S
Intel Customer Support
AlfredoS_Intel
Hi Mustafab,
We are just following up.
It looks like you need more time to provide the information that we asked.
We will follow up again after 3 business days. Should we not hear from you, our system may automatically close the thread.
Alfred S
AlfredoS_Intel
Hi Mustafab,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers. We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
