Ethernet Products
4865 Discussions
X722DA4FH get temperature
olebenny
Hi there
I have a Super Micro X11SPW-TF motherboard with 2 x X722DA4FH SFP+ running RHEL 8.4/8.5.
I need to read out the temperature from the X722.
Does any utility exist, that will do this ( like lm_sensors ) ??
Or can I do it with a SDK ??
/olebenny
Caguicla_Intel
Hello olebenny,
Before we check your query with our higher level engineers, we hope you don't mind sharing the PBA of the adapter. You may refer to the link below on where to find the PBA number. Providing photos of the adapter focusing on the markings (white sticker) found on the physical card will be highly appreciated for us to double check on it. The PBA consists 6-3 digit number located at the last part of the serial number. We will be sending an email for you to attach the photos of the adapter. Please be reminded not to post the photos on this thread to avoid exposing confidential information. This would help us identify if you are using an Original Equipment Manufacturer(OEM) or retail version of Intel Ethernet Adapter.
Identify Your Intel® Network Adapter Model Using PBA Number
https://www.intel.com/content/www/us/en/support/articles/000007022/network-and-i-o/ethernet-products.html
Awaiting to your reply.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C.
Intel® Customer Support
Caguicla_Intel
Hello olebenny,
Thank you for your swift response via email. Please allow us to further check your request. We will give you an update as soon as possible but no later than 2-3 business days.
Hoping for your kind patience.
Crisselle C.
Achilles_Intel
Hello olebenny,
You may try Ethtool and use the command ethtool -m ethX. ethX in this one is the adapter's device name. This provides the adapter specific information. The current temperature and its voltage.
Let us know if you have further questions or need clarifications. If we do not receive an update from you, we will make sure to reach out after 3 business days.
Thank you and have a nice day.
Achilles M.
Intel Customer Support
olebenny
Hello Achilles
RHEL 8.5 ethtool v5.8
‘ethtool -m ens1f0’ gives following output:
[root@localhost ole]# ethtool -m ens1f0
Cannot get module EEPROM information: Invalid argument
If I query the device with ‘ethtool ens1f0’:
[root@localhost ole]# ethtool  ens1f0
Settings for ens1f0:
               Supported ports: [ FIBRE ]
               Supported link modes:   10000baseT/Full
                                       1000baseX/Full
                                       10000baseSR/Full
                                       10000baseLR/Full
               Supported pause frame use: Symmetric Receive-only
               Supports auto-negotiation: Yes
               Supported FEC modes: Not reported
               Advertised link modes:  10000baseT/Full
                                       1000baseX/Full
                                       10000baseSR/Full
                                       10000baseLR/Full
               Advertised pause frame use: No
               Advertised auto-negotiation: Yes
               Advertised FEC modes: Not reported
               Speed: 10000Mb/s
               Duplex: Full
               Auto-negotiation: off
               Port: FIBRE
               PHYAD: 0
               Transceiver: internal
               Supports Wake-on: d
               Wake-on: d
        Current message level: 0x0000000f (15)
                               drv probe link timer
               Link detected: yes
If I query my Mellanox ConnectX-4 with ‘ethtool -m ens2f0’ it gives:
[root@localhost ole]# ethtool -m ens2f0
               Identifier                                : 0x0d (QSFP+)
               Extended identifier                       : 0x00
               Extended identifier description           : 1.5W max. Power consumption
               Extended identifier description           : No CDR in TX, No CDR in RX
               Extended identifier description           : High Power Class (> 3.5 W) not enabled
               Connector                                 : 0x07 (LC)
               Transceiver codes                         : 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
               Encoding                                  : 0x01 (8B/10B)
               BR, Nominal                               : 10000Mbps
               Rate identifier                           : 0x00
               Length (SMF,km)                           : 10km
               Length (OM3 50um)                         : 0m
               Length (OM2 50um)                         : 0m
               Length (OM1 62.5um)                       : 0m
               Length (Copper or Active cable)           : 0m
               Transmitter technology                    : 0x40 (1310 nm DFB)
               Laser wavelength                          : 1310.000nm
               Laser wavelength tolerance                : 6.500nm
               Vendor name                               : Mellanox
               Vendor OUI                                : 00:02:c9
               Vendor PN                                 : MC2206310-050
               Vendor rev                                : A1
               Vendor SN                                 : GB5021080808
               Date code                                 : 160312
               Revision Compliance                       : SFF-8636 Rev 2.5/2.6/2.7
               Module temperature                        : 32.28 degrees C / 90.11 degrees F
               Module voltage                            : 3.2901 V
               Alarm/warning flags implemented           : Yes
< output cut >
Best regards
Ole
Caguicla_Intel
Hello Ole,
Apologies for the delay on our response.
Please allow us to further check this with our engineers. We will give you an update as soon as possible but no later than 2-3 business days.
Crisselle C.
Caguicla_Intel
Hello Ole,
Thank you for the patience.
We have escalated this query and our engineers and they are requesting for Intel® System Support Utility log from your system. This will allow us to check your Adapter details and configuration. We need to check your current Firmware. We would also like to inform you that you are using an Original Equipment Manufacturer(OEM) Generic version of adapter card. If the Firmware is not updated to latest, you may need assistance from 3rd party manufacturer who owns this adapter. But don't worry as we are doing our best effort support on this request.
Please refer to Help Guide for the Intel® System Support Utility>Intel® System Support Utility Process>Linux* process
https://www.intel.com/content/www/us/en/support/articles/000008563/ethernet-products.html
Crisselle C.
olebenny
Hello Criselle
Please see attached/uploaded file localhost.localdomain.txt.
Kind regards
Ole Benny Hansen
olebenny
Hello Criselle
Please see post in this link:
Intel Ethernet Drivers and Utilities / Thread: [E1000-devel] SFP+ EEPROM readouts fail on X722 (ethtool -m: Invalid argument) (sourceforge.net)
It seems to be a known problem in driver.
Has this been fixed ??
What version of the driver ??
This is final statement for above link:
author
Lihong Yang <lihong.yang@intel.com>
2017-01-30 12:29:32 -0800
committer
Jeff Kirsher <jeffrey.t.kirsher@intel.com>
2017-03-15 01:58:21 -0700
commit
c271dd6c391b535226cf1a81aaad9f33cb5899d3 (patch)
tree
d713ff74140b3054d53ee6961a7b84bfc739e1d7
parent
c0cf70a6fc373570f86c6dc4799d775363b9946e (diff)
download
linux-c271dd6c391b535226cf1a81aaad9f33cb5899d3.tar.gz
i40e: fix ethtool to get EEPROM data from X722 interface
Currently ethtool -e will error out with a X722 interface
as its EEPROM has a scope limit at offset 0x5B9FFF.
This patch fixes the issue by setting the EEPROM length to
the scope limit to avoid NVM read failure beyond that.
Change-ID: I0b7d4dd6c7f2a57cace438af5dffa0f44c229372
Signed-off-by: Lihong Yang <lihong.yang@intel.com>
Tested-by: Andrew Bowers <andrewx.bowers@intel.com>
Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com>
Diffstat
-rw-r--r--
drivers/net/ethernet/intel/i40e/i40e_ethtool.c
5
1 files changed, 5 insertions, 0 deletions
diff --git a/drivers/net/ethernet/intel/i40e/i40e_ethtool.c b/drivers/net/ethernet/intel/i40e/i40e_ethtool.c
index a22e26200bccb..3aefc9e20439b 100644
--- a/drivers/net/ethernet/intel/i40e/i40e_ethtool.c
+++ b/drivers/net/ethernet/intel/i40e/i40e_ethtool.c
@@ -1165,6 +1165,11 @@ static int i40e_get_eeprom_len(struct net_device *netdev)
     struct i40e_hw *hw = &np->vsi->back->hw;
     u32 val;
+#define X722_EEPROM_SCOPE_LIMIT 0x5B9FFF
+    if (hw->mac.type == I40E_MAC_X722) {
+         val = X722_EEPROM_SCOPE_LIMIT + 1;
+         return val;
     val = (rd32(hw, I40E_GLPCI_LBARCTRL)
          & I40E_GLPCI_LBARCTRL_FL_SIZE_MASK)
          >> I40E_GLPCI_LBARCTRL_FL_SIZE_SHIFT;
Hi Jakub,
That commit was for "ethtool -e" and not "ethtool -m".
There was some firmware support required to implement "ethtool -m"
missing in original X722 NVM images that, ttbomk, still was not
present in early 2019.  My situation is similar to Todd's -- we
know a request to add this support has been submitted, but are
not clear if it has been approved, completed, or shipped yet.
- Don
olebenny
Hello Criselle
I finally found the tool, that I looked for:
nvmupdate64e for Linux
nvmupdate64e showed version 4.00 installed and 5.64 available for update.
After updating to V5.64 'ethtool -m ens1f0' works as expected.
ethtool -m ens1f0 output after update to v5.64:
Identifier : 0x03 (SFP)
Extended identifier : 0x04 (GBIC/SFP defined by 2-wire interface ID)
Transceiver codes : 0x20 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00
Transceiver type : 10G Ethernet: 10G Base-LR
Transceiver type : Ethernet: 1000BASE-LX
Encoding : 0x06 (64B/66B)
BR, Nominal : 10300MBd
Rate identifier : 0x04 (8/4/2G Tx Rate_Select only)
Length (SMF) : 10000m
Length (50um) : 0m
Length (62.5um) : 0m
Length (Copper) : 0m
Length (OM3) : 0m
Laser wavelength : 1310nm
Vendor name : FINISAR CORP.
Vendor OUI : 00:90:65
Vendor PN : FTLX1475D3BCV
Vendor rev : A
Option values : 0x00 0x3a
Option : RX_LOS implemented
Option : TX_FAULT implemented
Option : TX_DISABLE implemented
Option : RATE_SELECT implemented
BR margin, max : 0%
BR margin, min : 0%
Vendor SN : N54ADF6
Date code : 210125
Optical diagnostics support : Yes
Laser bias current : 23.900 mA
Laser output power : 0.3474 mW / -4.59 dBm
Receiver signal average optical power : 0.0001 mW / -40.00 dBm
Module temperature : 42.14 degrees C / 107.86 degrees F
Module voltage : 3.3078 V
Laser bias current high alarm : Off
Laser bias current low alarm : Off
Laser bias current high warning : Off
Laser bias current low warning : Off
Laser output power high alarm : Off
Laser output power low alarm : Off
Laser output power high warning : Off
Laser output power low warning : Off
Module temperature high alarm : Off
Module temperature low alarm : Off
Module temperature high warning : Off
Module temperature low warning : Off
Module voltage high alarm : Off
Module voltage low alarm : Off
Module voltage high warning : Off
Module voltage low warning : Off
Laser rx power high alarm : Off
Laser rx power low alarm : On
Laser rx power high warning : Off
Laser rx power low warning : On
Laser bias current high alarm threshold : 70.000 mA
Laser bias current low alarm threshold : 1.000 mA
Laser bias current high warning threshold : 68.000 mA
Laser bias current low warning threshold : 2.000 mA
Laser output power high alarm threshold : 2.2387 mW / 3.50 dBm
Laser output power low alarm threshold : 0.0603 mW / -12.20 dBm
Laser output power high warning threshold : 1.1220 mW / 0.50 dBm
Laser output power low warning threshold : 0.1514 mW / -8.20 dBm
Module temperature high alarm threshold : 75.00 degrees C / 167.00 degrees F
Module temperature low alarm threshold : -5.00 degrees C / 23.00 degrees F
Module temperature high warning threshold : 70.00 degrees C / 158.00 degrees F
Module temperature low warning threshold : 0.00 degrees C / 32.00 degrees F
Module voltage high alarm threshold : 3.6300 V
Module voltage low alarm threshold : 2.9700 V
Module voltage high warning threshold : 3.4650 V
Module voltage low warning threshold : 3.1350 V
Laser rx power high alarm threshold : 2.2387 mW / 3.50 dBm
Laser rx power low alarm threshold : 0.0145 mW / -18.39 dBm
Laser rx power high warning threshold : 1.1220 mW / 0.50 dBm
Laser rx power low warning threshold : 0.0363 mW / -14.40 dBm
Kind regards
Ole
Caguicla_Intel
Hello Ole,
Thank you for the update and we are glad to hear that you are able to update the Firmware of your X722.
Since 'ethtool -m ens1f0' works as expected after updating to V5.64, we'd like to check if you still have questions or additional assistance needed on this request. If you do, feel free to let us know and we will be glad to check on it. Otherwise, please advise if we can now close this thread.
Hoping to hear from you soon.
Should there be no response, we will follow up after 3 business days.
Crisselle C.
Caguicla_Intel
Hello Ole,
Good day!
This is just a follow up to check if you still have questions or clarifications on this request. If you do, please let us know and we will be glad to check on it. Otherwise, please advise if we can now close this thread.
Crisselle C.
olebenny
Hi Crisselle C.
The update fixed it, we are all set.
You may close this incident now.
Best regards
Ole
Caguicla_Intel
Hello Ole,
Thank you for the reply.
We are glad to hear that the update fixed it. Please be informed that we will now close this request as per your advise. Just feel free to post a new question if you may have any other inquiry in the future as this thread will no longer be monitored.
Thank you for choosing Intel and stay safe!
Crisselle C.
