Ethernet Products
4877 Discussions
XL-710 SR-IOV
SThir10
Is it possible to distribute the traffic to different VF's based on tuple values without configuring VLAN or MAC address for individual VF?
Caguicla_Intel
Hello SThir10,
Thank you for the patience on this matter.
Sharing with you the Intel® Ethernet Controller 700 Series: Hash and Flow Director Filters
https://software.intel.com/en-us/articles/intel-ethernet-controller-700-series-hash-and-flow-director-filters
Kindly confirm if this is the information that you needed.
Awaiting to your response.
We will follow up after 3 business days in case we don't hear from you.
Crisselle C
Intel® Customer Support
Caguicla_Intel
Hello SThir10,
Please share the exact model of the XL710 adapter and the intended Operating System used as this would help us in checking your request.
We look forward to hear from you.
We will follow up after 3 business days in case we don't receive a reply.
Crisselle C
Caguicla_Intel
Hello SThir10,
Good day!
Please provide the requested information for us to proceed in checking your request.
Crisselle C
SThir10
Hi Crisselle C,
Pls find the details of the os and the XL710 adapter.
OS: Linux (Centos 7.0)
# uname -r
3.10.0-693.el7.x86_64
#lspci output for the adapter
3b:00.0 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
3b:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
Verbose output from pci config space.
Subsystem: Super Micro Computer Inc Device 084a
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr+ Stepping- SERR+ FastB2B- DisINTx+
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0, Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 180
NUMA node: 0
Region 0: Memory at 388000000000 (64-bit, prefetchable) [size=8M]
Region 3: Memory at 388001800000 (64-bit, prefetchable) [size=32K]
Expansion ROM at b8680000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold-)
Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=1 PME-
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Address: 0000000000000000 Data: 0000
Masking: 00000000 Pending: 00000000
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Vector table: BAR=3 offset=00000000
PBA: BAR=3 offset=00001000
Capabilities: [a0] Express (v2) Endpoint, MSI 00
DevCap: MaxPayload 2048 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
ExtTag+ AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
DevCtl: Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
RlxdOrd+ ExtTag+ PhantFunc- AuxPwr- NoSnoop- FLReset-
MaxPayload 256 bytes, MaxReadReq 512 bytes
DevSta: CorrErr+ UncorrErr- FatalErr- UnsuppReq+ AuxPwr- TransPend-
LnkCap: Port #0, Speed 8GT/s, Width x8, ASPM not supported, Exit Latency L0s <2us, L1 <16us
ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp+
LnkCtl: ASPM Disabled; RCB 64 bytes Disabled- CommClk+
ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
LnkSta: Speed 8GT/s, Width x8, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR-, OBFF Not Supported
DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled
LnkCtl2: Target Link Speed: 2.5GT/s, EnterCompliance- SpeedDis-
Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
Compliance De-emphasis: -6dB
LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete+, EqualizationPhase1+
EqualizationPhase2+, EqualizationPhase3+, LinkEqualizationRequest-
Capabilities: [e0] Vital Product Data
Product Name: Supermicro Network Adapter
Read-only fields:
[PN] Part number: AOC-S40G-i2Q
[V0] Vendor specific: 010C
[V1] Vendor specific: 1.00
[SN] Serial number: VA198S029423
[VA] Vendor specific: 2
[V2] Vendor specific: AC1F6B8BBF16
[V3] Vendor specific: AC1F6B8BBF17
[V4] Vendor specific:
[V5] Vendor specific:
[RV] Reserved: checksum good, 0 byte(s) reserved
Read/write fields:
[VB] Vendor specific: \x00
End
Capabilities: [100 v2] Advanced Error Reporting
UESta: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
UEMsk: DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq+ ACSViol-
UESvrt: DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
CESta: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
CEMsk: RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
AERCap: First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
Capabilities: [140 v1] Device Serial Number 16-bf-8b-ff-ff-6b-1f-ac
Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
ARICap: MFVC- ACS-, Next Function: 1
ARICtl: MFVC- ACS-, Function Group: 0
Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
IOVCap: Migration-, Interrupt Message Number: 000
IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy+
IOVSta: Migration-
Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
VF offset: 16, stride: 1, Device ID: 154c
Supported Page Size: 00000553, System Page Size: 00000001
Region 0: Memory at 0000388001000000 (64-bit, prefetchable)
Region 3: Memory at 0000388001810000 (64-bit, prefetchable)
VF Migration: offset: 00000000, BIR: 0
Capabilities: [1a0 v1] Transaction Processing Hints
Device specific mode supported
No steering table available
Capabilities: [1b0 v1] Access Control Services
ACSCap: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
ACSCtl: SrcValid- TransBlk- ReqRedir- CmpltRedir- UpstreamFwd- EgressCtrl- DirectTrans-
Capabilities: [1d0 v1] #19
Kernel driver in use: i40e
Kernel modules: i40e
00: 86 80 83 15 46 05 10 00 02 00 00 02 08 00 80 00
10: 0c 00 00 00 80 38 00 00 00 00 00 00 0c 00 80 01
20: 80 38 00 00 00 00 00 00 00 00 00 00 d9 15 4a 08
30: 00 00 68 b8 40 00 00 00 00 00 00 00 0b 01 00 00
SThir10
Let me know if you need to run any tool to get more information relevant to the adapter.
Thank you,
Siva
Caguicla_Intel
Hello SThir10,
Thank you for the reply.
Please allow us to check on your request. We will get back to you as soon as possible but no later than 3 business days.
Hoping for your patience.
Crisselle C
Caguicla_Intel
Hello SThir10,
Apologies for the delay on this matter.
Please confirm if the ‘Filters to Direct Traffic to a Specific VF’ on the link below is what you are looking for.
i40e Linux* Base Driver for the Intel(R) Ethernet Controller 700 Series
https://downloadmirror.intel.com/24411/eng/README.txt
Let us know if you have additional questions and clarifications.
In case we don't hear from you, we will follow up after 3 business days.
Crisselle C
SThir10
Hi Crisselle C,
Thank you for the reply. I went thru the Readme.txt file.
What I am looking for is something like a hash function to distribute the traffic to specific VF.
I see the rx-flow-hash setting done using ethtool.
I think it works after the packet is sent to the VF (within the queues of VF). Pls correct me here if I have misunderstood.
But what I am trying to find out is if there is something like rx-flow-hash that could be used to redirect to a particular VF.
Siva
SThir10
In addition to the above, the following is the additional information.
Since I do not know the traffic pattern that comes to the interface, I may not be able to do a match on packet fields to redirect the packet to VF.
I want to use hash to keep the session sticky to a VF and as well achieve load balancing across multiple VF's.
Caguicla_Intel
Hello SThir10,
Please allow us to further check on your request. Rest assured that we will give you an update as soon as there is any findings but no later than 2-4 business days.
Thank you for your kind understanding.
Crisselle C
Caguicla_Intel
Hello SThir10,
Crisselle C
Caguicla_Intel
Hello SThir10,
Good day!
We'd like to check if you have visited the link that we mentioned on our previous post. In case you have additional questions, please do not hesitate to let us know.
We hope to hear from you soon.
In case we don't receive a reply, we will follow up after 3 business days.
Crisselle C
SThir10
Hi Crisselle C,
Thank you for the information provided. That confirms our understanding that the hash distribution is done only after the packet is received on the VF.
Thank you,
Siva
Caguicla_Intel
Hello SThir10,
You are most welcome, glad to be of help.
Since you have confirmed that your question has been answered, please be informed that we will now close this request. Just feel free to post a new question if you may have any other inquiry in the future.
May you have an amazing day ahead!
Crisselle C
