Ethernet Products
5821 Discussions
XL710-Q2 doesn't support QSPF+ configuration modification
ILee10
I updated NVM and used qcu for configuring Intel XL710QDA2 to 4x10 mode.
This adapter has two 40Gb ports.
However the qcu displayed that the adapter doesn't support configuration modification as below.
How can I config to support 4x10 mode with this adapter?
Iris
I'd like to set up Intel XL710
[root@centos12 Linux_x64]# ethtool -i eth8
driver: i40e
version: 1.3.47
firmware-version: 4.42 0x80001932 0.0.0
bus-info: 0000:08:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
[root@centos12 qcu]# ./qcu64e /devices
Intel(R) QSFP+ Configuration Utility
QCU version: v1.24.35.01
Copyright(C) 2015 by Intel Corporation.
Software released under Intel Proprietary License.
NIC B:D Ven-Dev Mode Adapter Name
1) 08:00 8086-1583 N/A Intel(R) Ethernet Converged Network Adapter XL710-Q2
[root@centos12 qcu]# ./qcu64e /nic=1 /info
QSFP+ Configuration modification is not supported by this adapter.
SYeo3
Valued Contributor I
Hi IrisLee,
Thank you for contacting Intel.
The valid configurations for Intel® Ethernet Converged Network Adapters XL710-QDA2 are:
2x40, 2x2x10, 4x10
For 4x10 configuration, use /set=4x10.
Sincerely,
Sandy
ILee10
Hi Sandy,
Thank you for answering.
I understood to use ./qcu64e /nic=1 /set=4x10 command for setting breakout mode.
However my question is that, I couldn't set it to 4x10 mode due to the error message I have as below:
I downloaded Intel® Network Connections Software from below link.
https://downloadcenter.intel.com/download/25432/Intel-Ethernet-Connections-CD Download Intel® Ethernet Connections CD
I tested from 20.0, 20.1, 20.2, 20.3 and 20.4.1 which is the latest version, however when I ran qcu64e, the message shows N/A mode.
I'd like to see 2x40 mode or something like that, so I can program it to 4x10 mode or so.
Could you please let me know why I couldn't see the mode of adapter with valid option?
Please let me know if you need any more information.
Iris
SYeo3
Hi Iris,
Thanks for writing back. Please provide us the serial number of your network adapter.
We would like to verify if your network adapter is an Intel Retail Adapter or manufactured for other systems manufacturers (OEM). Some OEM adapters are customized for certain systems and may not be compatible with our configuration tool.
Photo of Adapter's serial number:
We look forward to your reply,
Sincerely,
Sandy
ILee10
Hi Sandy,
Please see the attached.
Iris
SYeo3
Hi Iris,
I'm sorry for the late reply. Can you also provide the model of module that you are using with the XL710 card? Thanks.
Sincerely,
Sandy
Hello! Is that problem resolved? I have the same issue with card.
