Ethernet Products
4614 Discussions
XL710 VF and loopback
cphil4
I have an XL710 VSI that is running in a VF and uses RSS queuing across multiple queues on input. In fact there are 4 RSS queue sets in the VF. For various reasons I want to put frames on each XMIT queue in the VF and loop them back to the matching RCV queue. I have modified the VSI to set the "Allow destination override" bit in the ADD_VSI command. I've also set the SWTCH field in the context transmit descriptor to 11b and set the TARGET_VSI field to the VSI id. This all then works in that the transmitted frame is looped back to a receive ring. But there is a catch. Frames put on transmit queues 0 thru 3 all end up being looped back to the rcv ring of rcv queue 0, instead of back to the appropriate matching rcv queue eg Xmit 3 to Rcv 3. Can anything be done about this?
SYeo3
Valued Contributor I
Hi clivep,
Thanks for posting. I'll further check on this.
Sincerely,
Sandy
SYeo3
Hi clivep,
Can you provide us your adapter and operating system?
ethtool -i
Operating System:
Kernel:
Adapter Info:
Module Type:
We look forward to your reply.
Sincerely,
Sandy
cphil4
uname –a:
Linux localhost.localdomain 4.1.7-200.fc22.x86_64
ethtool -i enp3s0f0:
driver: i40e
version: 1.3.39.1
firmware-version: 4.53 0x80001dca 0.0.0
bus-info: 0000:03:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
The VF program is running in a guest under QEMU. The guest OS details:
uname –a:
Linux localhost.localdomain 2.6.32-431.56.1.el6.f5.x86
SYeo3
Hi clivep,
Thanks for providing your system details. We are looking into your configuration.
In the meantime, please provide the adapter's details. This is for us to further understand your environment.
Model:
Module Type used on the nic:
Sincerely,
Sandy
cphil4
Not sure if this is what you're requesting, but if not, please tell me how to get what you want...
From lspci:
03:00.1 Ethernet controller: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter XL710-Q2
SYeo3
Hi clivep,
The "allow destination override" bit does not over rule RSS. Try making sure that the RSS rules direct your packets to the correct queues or else try using Flow Director rules to achieve the result you need.
Sincerely,
Sandy
cphil4
You're correct. That is the problem. Thanks you!
