Ethernet Products
5821 Discussions
XL710 can't split in FreeBSD
AEsin
Hello.
Trying to split XL710QDA1 in FreeBSD 12 and get:
[root@host ~]# ./qcu64e /devices [18:42:30]
Intel(R) QSFP+ Configuration Utility
QCU version: v2.27.10.01
Copyright(C) 2016 by Intel Corporation.
Software released under Intel Proprietary License.
NIC Seg:Bus Ven-Dev Mode Adapter Name
zsh: segmentation fault (core dumped) ./qcu64e /devices
[root@host ~]# gdb core qcu64e.core [18:43:21]
GNU gdb 6.1.1 [FreeBSD]
Copyright 2004 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "amd64-marcel-freebsd"...core: No such file or directory.
Core was generated by `./qcu64e /devices'.
Program terminated with signal 11, Segmentation fault.
# 0 0x00000000005051b1 in ?? ()
(gdb)
I tryed fw versions 4.22.26225 and 5.0.40043 . Driver we use 1.6.6.
And I succesfully split it from UEFI.
Hi AlexeyDM,
Thank you for the post. Just to double check:
Are you saying if using fw version 5.05 the split will not work?
https://downloadcenter.intel.com/download/25792/Non-Volatile-Memory-NVM-Update-Utility-for-Intel-Ethernet-Adapters-FreeBSD-?product=83966
wb
AEsin
Hello!
This utility doesnt work in Freebsd with any firmware. And succesfully works in EFI.
Hi AlexeyDM,
Thank you for the clarification. I will check on this.
rgds,
wb
Hi AlexeyDM,
Just to double check are you saying that you only encountered the issue when
using QSFP configuration utilty for Freebsd ( https://downloadcenter.intel.com/download/25852/Intel-QSFP-Configuration-Utility-FreeBSD-), he encountered the zsh: segmentation fault (core dumped) error?
No issue if you use the configuration utility EFI to configure 1x40 to 4x10 on the XL710 which downloaded from
https://downloadcenter.intel.com/download/25854/Intel-QSFP-Configuration-Utility-EFI-
Just to clarify also if you want to report to us there's problem with our program (qcu64e) in Freebsd 12? Is your concern addressed by using the EFI version of the QSFP utility?
We have latest release of Freebsd driver (1.7.11) in download center,
please try download and install https://downloadcenter.intel.com/download/25160/Ethernet-Intel-Network-Adapter-Driver-for-PCIe-40-Gigabit-Ethernet-Network-Connection-under-FreeBSD-
As stated in our documentation, QCU tool requires latest NVMe firmware and driver to be loaded, kindly refer to page 3 of this link http://www.intel.com/content/dam/support/us/en/documents/network/adapter/qsfp-configuration-utility-quick-usage-guide.pdf
Please feel free to update me. Thank you.
Rgds,
wb
Hi AlexeyDM,
Please feel free to update me if you have double check and tried the suggestion.
rgds,
wb
AEsin
Hello. I've installed a newest driver https://svnweb.freebsd.org/base?view=revision&revision=313497 1.7.12 for Freebsd
[root@vla1-1rr2 ~]# sysctl dev.ixl.0.fw_version [12:41:58]
dev.ixl.0.fw_version: fw 5.0.40043 api 1.5 nvm 5.05 etid 800028a2 oem 1.262.0
[root@vla1-1rr2 ~]# sysctl dev.ixl.1.%desc [12:42:10]
dev.ixl.1.%desc: Intel(R) Ethernet Connection XL710/X722 Driver, Version - 1.7.12
[root@vla1-1rr2 ~]# ./qcu64e /devices [12:43:29]
Yep, qcu64e crashed in Freebsd.
Hi AlexeyDM,
Thank you for the update. We will check on this.
rgds,
wb
Hi AlexeyDM,
Good day. Please be informed our engineer team is aware of this reported issue, but there is no timeline for the fix in next release. For the meantime, you can continue to use the EFI version of QCU for your setup. Please let me know if you still have other inquiries. Thank you.
Rgds,
wb
AEsin
I have no questions anymore.
Thank you.
Hi AlexeyDM,
Thank you for the update. Have a great day.
Rgds,
wb
