Ethernet Products
5530 Discussions
XL710 do not work after NVM update
Have the following hardware configuration:
Server 2xIntel Xeon E5-2680 v3 @ 2.50GHz
Six XL-710 adapters (Intel Corporation Ethernet Controller X710 for 10GbE SFP+)
CentOS 7 Linux, kernel 3.10.0-123.el7.x86_64
Driver version i40e-1.2.38.
Firmware of all six adapters has been updated to the latest version available from (https://downloadcenter.intel.com/download/24769 https://downloadcenter.intel.com/download/24769)
Tool used for firmware update
After successful flashing (as reported by NVM update tool) one of the adapters stopped working.
EEPROM Image Version: 4.42 MAP2.66 (after update)
The failed card is visible under lspci, but i40e driver reports errors during device initialization:
[ 2682.320170] i40e 0000:03:00.0: Initial pf_reset failed: -15
[ 2682.320173] i40e 0000:03:00.0: HW reset failed or FW unresponsive, module loaded in debug mode
[ 2684.523590] i40e 0000:03:00.1: Initial pf_reset failed: -15
[ 2684.523593] i40e 0000:03:00.1: HW reset failed or FW unresponsive, module loaded in debug mode
[ 2686.727010] i40e 0000:03:00.2: Initial pf_reset failed: -15
[ 2686.727013] i40e 0000:03:00.2: HW reset failed or FW unresponsive, module loaded in debug mode
[ 2688.930435] i40e 0000:03:00.3: Initial pf_reset failed: -15
[ 2688.930437] i40e 0000:03:00.3: HW reset failed or FW unresponsive, module loaded in debug mode
Update utility refuses to re-update firmware for that device, reporting 'access error'.
Updating NVM using `eeupdate64e` tool also failed.
For failed XL-710:
$> ./eeupdate64e /NIC=5 /EEPROMVER
Unable to initialize adapter 5 code c86a0a00
Admin Queue initialization failed
For normal XL-710:
1: EEPROM Image Version: 4.42 MAP2.66
Thank you in advance.
st4
New Contributor III
Hi AlexeyDyadin,
Thank you for the post. Let me check on this.
rgds,
wb
st4
New Contributor III
Hi AlexeyDyadin,
Good day. Further checking on this, it is recommended to replace the network adapter, you may contact Intel Customer Support to arrange RMA based on your location. Please refer to website below for the contacts:
Network Connectivity — Warranty Replacement Form for Intel® Network Adapters
wb
