Hi, All,
I assign XL710 VF to QEMU, and load modified i40evf driver in QEMU, then I encounter the following error in the qemu:
"Admin queue command never completed"
and get the following error log in host OS system:
[ 7823.295061] pci 0000:03:02.2: enabling device (0000 -> 0002)
[ 7823.295959] i40e 0000:03:00.0: VF 2 assigned LAN VSI index 5, VSI id 8
[ 7823.446495] pci 0000:03:02.2: kvm assign device
[ 7826.579576] i40e 0000:03:00.0: VF 2 assigned LAN VSI index 5, VSI id 8
[ 7827.024165] i40e 0000:03:00.0: VF 2 assigned LAN VSI index 5, VSI id 8
[ 7842.719176] dmar: DRHD: handling fault status reg 102
[ 7842.719188] dmar: DMAR:[DMA Read] Request device [03:02.2] fault addr 6551000
DMAR:[fault reason 06] PTE Read access is not set
[ 7843.628420] i40e 0000:03:00.0: ARQ VF Error detected
[ 7843.628426] i40e 0000:03:00.0: ASQ VF Error detected
[ 7847.424745] i40e 0000:03:00.0: VF 2 assigned LAN VSI index 5, VSI id 8
[ 7847.525135] i40e 0000:03:00.0: VF 2 assigned LAN VSI index 5, VSI id 8
Then I unload and reload i40e driver in host OS system and encouter the following error:
[ 7856.803922] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 0.4.21-k
[ 7856.803925] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[ 7856.812193] i40e 0000:03:00.0: f0.0 a0.0 n04.24 e800013fd
[ 7856.812196] i40e 0000:03:00.0: The driver for the device detected an older version of the NVM image than expected. Please update the NVM image.
[ 7857.034526] i40e 0000:03:00.0: FCoE capability is disabled
[ 7857.034533] i40e 0000:03:00.0: configure_lan_hmc failed: -49
[ 7857.034679] i40e: probe of 0000:03:00.0 failed with error -2
I debug the i40e driver code and found that the driver call i40evf_asq_send_command to get firmware and api version but the firmware did not write back any information (so the firmware and api version in the above message are both 0). After rebooting the host system, it works again. This problem happens from time to time, and I can't reproduce it at will.
Before unload and reload the i40e driver, I give the EMP reset command by execute "echo empr > /sys/kernel/debug/i40e/0000\:03\:00.0/command", but it did not fix the problem.
Dose anyone know why this happen and how to recover from the problem ? Thanks in advance!
I run on ubuntu 14.10 x86-64 with updated kernel 3.17.6-031706-generic.
Hi ChengYuLi,
Thank you for the post, is this an onboard NIC XL710AM? If not,,what is the exact XL710 model -XL710QDA1 or QDA2?
rgds,
wb
Hi ChengYuLi,
Please provide the exact model to better assist you.
thanks,
wb
Hi, wb_intel
Sorry for delayed response, my account was locked so I have to register another accout to login.
Our XL710 model is XL710QDA2, I got the following message by entering: lspci -s 03:00.0 -nnvv
03:00.0 Ethernet controller [0200]: Intel Corporation Ethernet Controller XL710 for 40GbE QSFP+ [8086:1584] (rev 01)
Subsystem: Intel Corporation Ethernet Converged Network Adapter XL710-Q1 [8086:0001]
Thanks and best regards.
- ChengyuLi
Hi ChengyuLi2,
Please try upgrade to the latest driver.
Further, please refer to this site to download the latest NVMUpdatePackage for XL710, the update guide is also included in the website
https://downloadcenter.intel.com/download/24769 Intel® Download Center
Hope this helps.
rgds,
wb
