Ethernet Products
5610 Discussions
XL710 priority queues
cphil4
I have an XL710 VSI that is running in a VF and uses RSS queuing across multiple queues on input. I want to create a separate priority queue that will receive only certain frame types eg LACP. Is the best way to achieve this as follows:
1. create a second VSI on this VF (with the same MAC address) with one receive queue.
2. allocate an L2 filter on the PF as part of that VSI creation that will filter for the desired frames.
Then the desired frames will be received in the 2nd VSI's rcv queue?
st4
New Contributor III
Hi clivep,
Good day. Here is what you can try either of the following:
1) Create an extra queue in the VF and apply an ethertype filter to direct the packets to that queue.
2) Or create a new VSi, same MAC and apply an Ethertype control filter for the VSi and have a single queue there.
To debugfs the interface you can add a ethertype control filter to experiment.
Echo add ethtype filter > command
Echo rem ethtype filter > command
hope this helps.
rgds,
wb
st4
New Contributor III
Hi clivep,
Thank you for the post. I need to check on this. will update you,by the way what is the operatig system used?
rgds,
wb
st4
New Contributor III
Hi clivep,
hope this helps.
rgds,
wb
