Hello!
I have a problem with Intel XL710, after 22 Gbps of traffic some cores of processor loads 100% IRQ and traffic goes down.
There are latast firmware and driver:
# ethtool -i ens2
driver: i40e
version: 2.24.6
firmware-version: 9.40 0x8000ecc0 1.3429.0
expansion-rom-version:
bus-info: 0000:d8:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
I read this guide
And made all possible configurations. But nothing changes
382 set_irq_affinity local ens2
384 set_irq_affinity all ens2
387 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 0 tx-usecs 0
389 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 5000 tx-usecs 20000
391 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 10000 tx-usecs 20000
393 ethtool -g ens2
394 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 84 tx-usecs 84
396 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 62 tx-usecs 62
398 ethtool -S ens2 | grep drop
399 ethtool -S ens2 | grep drop
400 ethtool -S ens2 | grep drop
401 ethtool -S ens2 | grep drop
402 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 336 tx-usecs 84
403 ethtool -S ens2 | grep drop
404 ethtool -S ens2 | grep drop
406 ethtool -S ens2 | grep drop
407 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 672 tx-usecs 84
408 ethtool -S ens2 | grep drop
409 ethtool -S ens2 | grep drop
411 ethtool -S ens2 | grep drop
412 ethtool -S ens2 | grep drop
425 ethtool -S ens2 | grep drop
426 ethtool -S ens2 | grep drop
427 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 8400 tx-usecs 840
428 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 4200 tx-usecs 840
430 ethtool -S ens2 | grep drop
431 ethtool -S ens2 | grep drop
432 ethtool -S ens2 | grep drop
433 ethtool -S ens2 | grep drop
434 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 4200 tx-usecs 1680
435 ethtool -S ens2 | grep drop
436 ethtool -S ens2 | grep drop
439 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 3200 tx-usecs 3200
469 ethtool -a ens2
472 ethtool ens2
473 ethtool -i ens2
475 ethtool -i ens2
476 ethtool ens2
482 ethtool -C ens2 adaptive-rx on
484 ethtool -c ens2
486 ethtool -C ens2 adaptive-tx on
487 ethtool -c ens2
492 history | grep ens2
494 ethtool -m ens2
499 ethtool -C ens2 adaptive-rx off adaptive-tx off rx-usecs 4200 tx-usecs 1600
501 history | grep ens2
Server configuration:
80 cores Intel(R) Xeon(R) Gold 6230 CPU @ 2.10GHz
RAM 960 GB
8 x SAMSUNG MZQLB7T6HMLA-000AZ NVME disks
Ethernet Controller XL710 for 40GbE QSFP+ (rev 02)
What can be done with the settings of this network card to solve the problem?
On another server with a similar configuration, but a different network cards, everything is fine
88 cores Intel(R) Xeon(R) CPU E5-2699 v4 @ 2.20GHz
RAM 512 GB
8 x SAMSUNG MZQLB7T6HMLA-00007 NVME disks
4 x 82599ES 10-Gigabit SFI/SFP+ Network Connection
- « Previous
- 1
- 2
- Next »
Hi Simon!
Sorry for my late answer.
We use a lot of different Intel network cards from 1000Mbit/s on the e1000e and igb drivers to 100Gbit/s on the ice driver.
Nowhere have there been problems with such large IRQ except this server with XL710
For example, a server graph with E810-C:
With 84 Gbps traffic, only 1.16k IRQ.
Immediately with a traffic of 20 Gbit/s there are more than 2k IRQ. Why?
Hello AndriiV,
Greetings!
Thank you for writing to us. Thank you for sharing further information. We are actively working on this case with our level 2 team. We will get back to you again with an update at earliest.
Thank you for your patience.
Subhashish.
Hi AndriiV,
Please let us know if you have try the following tunings that we hadrecommended? If so, have you noticed any differences in the results?
With regards to high IRQ load, Higher-end NICs typically employ more sophisticated interrupt coalescing mechanisms to aggregate multiple network events into a single interrupt. Thereby reducing the frequency of interrupts and mitigating the IRQ load.
Interrupt affinity, interrupt moderation parameters, and CPU scaling governors, can affect how interrupts are handled and distributed across CPU cores.
Along with the tunings we had suggested in the previous email, to please try the steps below to configure CPU governance.
To view the current CPU scaling governor -> #cpupower frequency-info
To change the CPU scaling governor to a specific mode -> #cpupower frequency-set -g performance
Kindly clarify few questions as below:
+ In the link , you had shared the graph for bonding results too. Have
you encountered the same issue with bonding?
+ Does the issue occur across all platforms? Please try the following
scenarios below:
- Test with different XL710 NICs to determine if the issue is with
the card or something else.
- Try inserting the same NIC in another platform to determine if the
issue is platform-specific or not.
Hayat
Intel Customer Support
Hi Hayat!
# cpupower frequency-info
analyzing CPU 0:
driver: intel_pstate
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: Cannot determine or is not supported.
hardware limits: 800 MHz - 3.90 GHz
available cpufreq governors: performance powersave
current policy: frequency should be within 800 MHz and 3.90 GHz.
The governor "performance" may decide which speed to use
within this range.
current CPU frequency: Unable to call hardware
current CPU frequency: 2.80 GHz (asserted by call to kernel)
boost state support:
Supported: yes
Active: yes
# cpupower frequency-set -g performance
Setting cpu: 0
Setting cpu: 1
Setting cpu: 2
Setting cpu: 3
Setting cpu: 4
Setting cpu: 5
Setting cpu: 6
Setting cpu: 7
Setting cpu: 8
Setting cpu: 9
Setting cpu: 10
Setting cpu: 11
Setting cpu: 12
Setting cpu: 13
Setting cpu: 14
Setting cpu: 15
Setting cpu: 16
Setting cpu: 17
Setting cpu: 18
Setting cpu: 19
Setting cpu: 20
Setting cpu: 21
Setting cpu: 22
Setting cpu: 23
Setting cpu: 24
Setting cpu: 25
Setting cpu: 26
Setting cpu: 27
Setting cpu: 28
Setting cpu: 29
Setting cpu: 30
Setting cpu: 31
Setting cpu: 32
Setting cpu: 33
Setting cpu: 34
Setting cpu: 35
Setting cpu: 36
Setting cpu: 37
Setting cpu: 38
Setting cpu: 39
Setting cpu: 40
Setting cpu: 41
Setting cpu: 42
Setting cpu: 43
Setting cpu: 44
Setting cpu: 45
Setting cpu: 46
Setting cpu: 47
Setting cpu: 48
Setting cpu: 49
Setting cpu: 50
Setting cpu: 51
Setting cpu: 52
Setting cpu: 53
Setting cpu: 54
Setting cpu: 55
Setting cpu: 56
Setting cpu: 57
Setting cpu: 58
Setting cpu: 59
Setting cpu: 60
Setting cpu: 61
Setting cpu: 62
Setting cpu: 63
Setting cpu: 64
Setting cpu: 65
Setting cpu: 66
Setting cpu: 67
Setting cpu: 68
Setting cpu: 69
Setting cpu: 70
Setting cpu: 71
Setting cpu: 72
Setting cpu: 73
Setting cpu: 74
Setting cpu: 75
Setting cpu: 76
Setting cpu: 77
Setting cpu: 78
Setting cpu: 79
I already made it by startup-script:
cpucores=`cat /proc/cpuinfo | awk '/^processor/{print $3}' | tail -1`
for i in `seq 0 $cpucores`;
do
echo performance > /sys/devices/system/cpu/cpu$i/cpufreq/scaling_governor
done;
+ In the link , you had shared the graph for bonding results too. Have you encountered the same issue with bonding?
No, as for me, the 82599 cards are the most problem-free.
+ Does the issue occur across all platforms? Please try the following scenarios below:
- Test with different XL710 NICs to determine if the issue is with the card or something else.
- Try inserting the same NIC in another platform to determine if the issue is platform-specific or not.
Unfortunately, we currently do not have a second server with an XL710 card or another such card in this data center. We want to replace it with 4x82599.
Hi AndriiV,
Thank you for your response. Please allow us some time to check this internally. We will get back to you as soon as we have an update.
Simon
Hi AndriiV,
Greetings from Intel.
Hope you are doing great.
We noticed one small mistake in the startup-script which is listed in below email , we hope the highlighted is typo in the email, not in the script.
echo performance ] /sys/devices/system/cpu/cpu$i/cpufreq/scaling_governor
Correct syntax : echo performance > sudo tee /sys/devices/system/cpu/cpu$i/cpufreq/scaling_governor
Ali
Hello, MACM!
I see my message like this:
Hello AndriiV,
Good Day!
Please allow us sometime while we check this internally with our team and will get back to you as soon as we have an update.
Simon
Hello AndriiV,
We have emailed you to request remote access. Please share if there's any way for us to access the system.
Irwan_Intel
Hello Irwan!
I can grant root access via SSH to this server. How can I send you credentials?
Hi AndriiV,
We have emailed you separately for you to share the credential access.
Fikri
Hello all!
We decided to try another network card on this server.
NIC: Intel XXV710-DA2 2x25GbE
Cable: Intel XXV4DACBL2M passive 100GBASE-CR4 QSFP28
to 4x25GBASE-CR SFP28
First of all. Advertised auto-negotiation only 10Gbps on each port.
After 6Mbps of trafic everything hung out.
After
ethtool --set-priv-flags ens1f0 disable-fw-lldp on
ethtool --set-priv-flags ens1f1 disable-fw-lldp on
almost all was fine but traffic did not rise above 9 Gbit/s on each port. Also was disabled DCB on switch.
As it turned out, this cable is not in the compatibility list of Juniper QFX5200-32C
It was replaced by H3C QSFP28-4SFP28-CU-3M Compatible 100G QSFP28 to 4 x 25G SFP28 Passive Direct Attach Copper Breakout Cable.
Advertised auto-negotiation 25Gbps on each port.
But after 20 Gbps on bonding interface (of this two ports) exactly the same problems as with the XL710 were observed.
Judging by the graphs, we rest on some ceiling of 20 Gbps.
We have almost the same server with Intel XXV710-DA2 2x25Gb NIC
72 cores Intel(R) Xeon(R) Gold 6154 CPU @ 3.00GHz
RAM 768 GB
Ethernet Controller Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
It conected to Arista DCS-7060CX-32S switch by Intel® Ethernet QSFP28 to SFP28 Twinaxial Breakout XXV4DACBL2M 952303 NDAQGF-I202 100GbE/4x25GbE/4x10GbE Direct Attach
There no such problem. And there is LLDP enabled (by default):
# ethtool --show-priv-flags ens2f0
Private flags for ens2f0:
MFP : off
total-port-shutdown : off
LinkPolling : off
flow-director-atr : on
veb-stats : off
hw-atr-eviction : off
link-down-on-close : off
legacy-rx : off
disable-source-pruning : off
mac-source-pruning : on
disable-fw-lldp : off
rs-fec : on
base-r-fec : on
multiple-traffic-classes: off
vf-vlan-pruning : off
vf-source-pruning : on
mdd-auto-reset-vf : off
vf-true-promisc-support : off
After all these tests I am increasingly inclined to the conclusion that the problem lies in the incompatibility of Intel and Juniper and there are clearly some problems with LDDP/DCB.
Hello all! A few days ago we connected this server using a new scheme.
NIC: 2 ports X710
2 ports XXV710
Switch: Juniper QFX5200-32C
I used Linux software bonding to set up a 4x 10Gbps connection:
# cat /proc/net/bonding/bond0
Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011)
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer3+4 (1)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 200
Down Delay (ms): 200
802.3ad info
LACP rate: fast
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: 3c:fd:fe:a8:62:04
Active Aggregator Info:
Aggregator ID: 1
Number of ports: 4
Actor Key: 15
Partner Key: 5
Partner Mac Address: 88:e6:4b:6d:d5:24
Slave Interface: ens1f0
MII Status: up
Speed: 10000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: 3c:fd:fe:a8:62:04
Slave queue ID: 0
Aggregator ID: 1
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 1
details actor lacp pdu:
system priority: 65535
system mac address: 3c:fd:fe:a8:62:04
port key: 15
port priority: 255
port number: 1
port state: 63
details partner lacp pdu:
system priority: 127
system mac address: 88:e6:4b:6d:d5:24
oper key: 5
port priority: 127
port number: 41
port state: 63
Slave Interface: ens1f1
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: 3c:fd:fe:a8:62:05
Slave queue ID: 0
Aggregator ID: 1
Actor Churned Count: 1
port key: 15
port priority: 255
port number: 2
port state: 63
oper key: 5
port priority: 127
port number: 40
port state: 63
Slave Interface: eno3
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: ac:1f:6b:59:c9:7e
Slave queue ID: 0
Aggregator ID: 1
port key: 15
port priority: 255
port number: 3
port state: 63
oper key: 5
port priority: 127
port number: 38
port state: 63
Slave Interface: eno4
MII Status: up
Speed: 10000 Mbps
Duplex: full
Permanent HW addr: ac:1f:6b:59:c9:7f
Slave queue ID: 0
Aggregator ID: 1
port key: 15
port priority: 255
port number: 4
port state: 63
oper key: 5
port priority: 127
port number: 39
port state: 63
Also LLDP was disabled:
# ethtool --set-priv-flags ens1f1 disable-fw-lldp on
# ethtool --set-priv-flags ens1f0 disable-fw-lldp on
# ethtool --set-priv-flags eno3 disable-fw-lldp on
# ethtool --set-priv-flags eno4 disable-fw-lldp on
Also set irq affinity:
# set_irq_affinity -x local ens1f0 ens1f1 eno3 eno4
Results:
We've hit a ceiling of 23Gbps.
Interrupts are still eating up the entire CPU
When I tried to enable LLDP on two cards, traffic stopped flowing through them and errors started pouring in:
Aug 9 11:02:49 15224 kernel: [245313.055731] i40e 0000:19:00.1: VSI seid 390 Tx ring 0 disable timeout
Aug 9 11:02:49 15224 kernel: [245313.062170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.070168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.078169] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.086168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.094173] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.102171] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.114168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.122168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.134170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.146189] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.154167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.162170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.174168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.182167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.194183] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.202168] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.210167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.221934] i40e 0000:19:00.1: VSI seid 0 Tx ring 767 disable timeout
Aug 9 11:02:49 15224 kernel: [245313.222170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.230167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.238165] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.246166] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.258167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.270170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.278189] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.284384] i40e 0000:19:00.1: FW LLDP is disabled, attempting SW DCB
Aug 9 11:02:49 15224 kernel: [245313.286167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.294167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.295276] i40e 0000:19:00.1: SW DCB initialization succeeded.
Aug 9 11:02:49 15224 kernel: [245313.302170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.303844] i40e 0000:19:00.1: MAC source pruning enabled on all VFs
Aug 9 11:02:49 15224 kernel: [245313.310167] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.318240] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.330170] bond0: link status down for interface eno4, disabling it in 200 ms
Aug 9 11:02:49 15224 kernel: [245313.333712] i40e 0000:19:00.1: Set default VSI failed, err I40E_ERR_ADMIN_QUEUE_ERROR, aq_err I40E_AQ_RC_EINVAL
Aug 9 11:02:49 15224 kernel: [245313.333715] i40e 0000:19:00.1: Failed to restore promiscuous setting: off, err I40E_ERR_ADMIN_QUEUE_ERROR aq_err I40E_AQ_RC_EINVAL
Aug 9 11:02:49 15224 kernel: [245313.333717] i40e 0000:19:00.1: VF BW shares not restored
Aug 9 11:02:49 15224 kernel: [245313.333772] i40e 0000:19:00.1: FW LLDP is disabled
Aug 9 11:02:54 15224 kernel: [245318.023464] i40e 0000:19:00.0: VSI seid 391 Tx ring 0 disable timeout
Aug 9 11:02:54 15224 kernel: [245318.078151] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.086148] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.089907] i40e 0000:19:00.0: VSI seid 0 Tx ring 767 disable timeout
Aug 9 11:02:54 15224 kernel: [245318.098147] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.106153] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.114146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.122145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.130146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.138144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.146148] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.154154] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.162156] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.174161] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.182145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.190154] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.198146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.206152] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.218154] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.226148] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.234235] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.242286] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.250159] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.262150] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.274212] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.386149] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.394147] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.402150] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.410151] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.418153] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.426144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.434148] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.442160] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.454147] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.462146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.463467] i40e 0000:19:00.0: VSI seid 391 Tx ring 0 disable timeout
Aug 9 11:02:54 15224 kernel: [245318.470149] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.478153] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.486144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.494144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.502143] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.510143] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.522155] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.534344] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.546147] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.554145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.562145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.570154] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.582151] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.590144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.598152] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.606144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.614149] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.619470] i40e 0000:19:00.0: VSI seid 0 Tx ring 767 disable timeout
Aug 9 11:02:54 15224 kernel: [245318.622143] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.630145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.638146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.646144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.654145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.662142] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.670146] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.678147] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.682065] i40e 0000:19:00.0: FW LLDP is disabled, attempting SW DCB
Aug 9 11:02:54 15224 kernel: [245318.686145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.692934] i40e 0000:19:00.0: SW DCB initialization succeeded.
Aug 9 11:02:54 15224 kernel: [245318.698145] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:54 15224 kernel: [245318.701717] i40e 0000:19:00.0: MAC source pruning enabled on all VFs
Aug 9 11:02:55 15224 kernel: [245318.710161] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:55 15224 kernel: [245318.718144] bond0: link status down for interface eno3, disabling it in 200 ms
Aug 9 11:02:55 15224 kernel: [245318.724405] i40e 0000:19:00.0: Set default VSI failed, err I40E_ERR_ADMIN_QUEUE_ERROR, aq_err I40E_AQ_RC_EINVAL
Aug 9 11:02:55 15224 kernel: [245318.724408] i40e 0000:19:00.0: Failed to restore promiscuous setting: off, err I40E_ERR_ADMIN_QUEUE_ERROR aq_err I40E_AQ_RC_EINVAL
Aug 9 11:02:55 15224 kernel: [245318.724410] i40e 0000:19:00.0: VF BW shares not restored
Aug 9 11:02:55 15224 kernel: [245318.724466] i40e 0000:19:00.0: FW LLDP is disabled
Hi Andrii,
Greetings!!
Our performance team has been trying to connect to your system, but they have encountered some difficulties. To resolve this issue, we would appreciate your assistance in troubleshooting the connection.
Vishal
Hello!
We placed that server to other data-centre and connected it to Arista DCS-7060CX-32S switch with 2x25Gbps Intel XXV710
There no problem with LLDP (now it enabled), lower IRQ but too high (3 times) when compared with 4x10Gbps Intel 82599ES
2x25Gbps Intel XXV710:
4x10Gbps Intel 82599ES:
Hello AndriiV,
Thank you for contacting Intel.
This is the first follow-up regarding the issue you reported to us.
We wanted to inquire whether you had the opportunity to review our previous message.
Feel free to reply to this message, and we'll be more than happy to assist you further.
Simon
Intel Server Support
Hello, Simon! Sorry for late answer. I send new IP for this server via e-mail.
Hello Andrii,
Thank you for sharing the credentials. We will get back to you as soon as we have an update.
Simon
- « Previous
- 1
- 2
- Next »
