When i rewrite XL710 VF driver in a polling mode(single process) by porting Linux kernel 3.17.6 i40evf codes, now the VF driver can ping successfully.
And there are problems as following:
1. after transmit be called 4 times that process 4 transmit packets. (solved. we have fixed it to one transmit,one tx packet processing by delete the WB_STRIDE).
2. processing every 4 rx pakets only after every 4 tx packets processing happened. (not solved)
i don't kown what register makes the 4 receive packets be processed together. and is it relative to hardware only?
I look forward to reply about this issues.
Thanks & Best regards!
Animy
Hi Animy,
This is a duplicate post. Please refer to . Thanks.
Sincerely,
Sandy
