Ethernet Products
4874 Discussions
XXV 710 HW timestamp issue
dmikand
I've met with ptp4l timesync issue. Master send SYNC packets without timestamp and client receive these packets without RX timestamp when twoStepFlag set to 1. Such behavior doesn't seem to conform to the standard.  Switching to 1-step ptp is not possible because NIC driver returns "out of range" ioctl result when ptp4l tries to set RX filters up.
Do you know are there misconfigurations, hardware or software issues?
Note:
Two NICs  are connected directly.
Master cmd line:
./ptp4l -i enp2s0f0 -m2EH -f ./default.cfg
Slave cmd line:
    ./ptp4l -i enp2s0f0 -m2sEH -f ./default.cfg
Master default.cfg:
[global]
# Default Data Set
twoStepFlag             1
clientOnly              0
socket_priority         0
priority1               128
priority2               128
domainNumber            0
#utc_offset             37
clockClass              248
clockAccuracy           0xFE
offsetScaledLogVariance 0xFFFF
free_running            0
freq_est_interval       1
dscp_event              0
dscp_general            0
dataset_comparison      ieee1588
G.8275.defaultDS.localPriority  128
maxStepsRemoved         255
# Port Data Set
logAnnounceInterval     1
logSyncInterval         0
operLogSyncInterval     0
logMinDelayReqInterval  0
logMinPdelayReqInterval 0
operLogPdelayReqInterval 0
announceReceiptTimeout  3
syncReceiptTimeout      0
delayAsymmetry          0
fault_reset_interval    4
neighborPropDelayThresh 20000000
serverOnly              0
G.8275.portDS.localPriority     128
asCapable               auto
BMCA                    ptp
inhibit_announce        0
inhibit_delay_req       0
ignore_source_id        0
# Run time options
assume_two_step         0
logging_level           6
path_trace_enabled      0
follow_up_info          0
hybrid_e2e              0
inhibit_multicast_service       0
net_sync_monitor        0
tc_spanning_tree        0
tx_timestamp_timeout    1
unicast_listen          0
unicast_master_table    0
unicast_req_duration    3600
use_syslog              1
verbose                 0
summary_interval        0
kernel_leap             1
check_fup_sync          0
clock_class_threshold   248
# Servo Options
pi_proportional_const   0.0
pi_integral_const       0.0
pi_proportional_scale   0.0
pi_proportional_exponent        -0.3
pi_proportional_norm_max        0.7
pi_integral_scale       0.0
pi_integral_exponent    0.4
pi_integral_norm_max    0.3
step_threshold          0.0
first_step_threshold    0.00002
max_frequency           900000000
clock_servo             pi
sanity_freq_limit       200000000
ntpshm_segment          0
msg_interval_request    0
servo_num_offset_values 10
servo_offset_threshold  0
write_phase_mode        0
# Transport options
transportSpecific       0x0
ptp_dst_mac             01:1B:19:00:00:00
p2p_dst_mac             01:80:C2:00:00:0E
udp_ttl                 1
udp6_scope              0x0E
uds_address             /var/run/ptp4l
uds_ro_address          /var/run/ptp4lro
# Default interface options
clock_type              OC
network_transport       UDPv4
delay_mechanism         E2E
time_stamping           hardware
tsproc_mode             filter
delay_filter            moving_median
delay_filter_length     10
egressLatency           0
ingressLatency          0
boundary_clock_jbod     0
# Clock description
productDescription      ;;
revisionData            ;;
manufacturerIdentity    00:00:00
userDescription         ;
timeSource              0xA0
Slave default.cfg:
[global]
# Default Data Set
twoStepFlag             1
clientOnly              0
socket_priority         0
priority1               128
priority2               128
domainNumber            0
#utc_offset             37
clockClass              248
clockAccuracy           0xFE
free_running            0
freq_est_interval       1
dscp_event              0
dscp_general            0
maxStepsRemoved         255
# Port Data Set
logSyncInterval         0
delayAsymmetry          0
serverOnly              0
asCapable               auto
BMCA                    ptp
inhibit_announce        0
inhibit_delay_req       0
ignore_source_id        0
# Run time options
assume_two_step         0
logging_level           6
follow_up_info          0
hybrid_e2e              0
net_sync_monitor        0
tc_spanning_tree        0
unicast_listen          0
use_syslog              1
verbose                 0
summary_interval        0
kernel_leap             1
check_fup_sync          0
# Servo Options
step_threshold          0.0
clock_servo             pi
ntpshm_segment          0
write_phase_mode        0
# Transport options
udp_ttl                 1
udp6_scope              0x0E
clock_type              OC
delay_mechanism         E2E
tsproc_mode             filter
egressLatency           0
ingressLatency          0
# Clock description
revisionData            ;;
userDescription         ;
timeSource              0xA0
NIC configuration:
Master:
# ip link show dev enp2s0f0
6: enp2s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
    link/ether b4:96:91:a6:33:30 brd ff:ff:ff:ff:ff:ff
Slave:
4: enp2s0f0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
    link/ether b4:96:91:a6:33:c0 brd ff:ff:ff:ff:ff:ff
02:00.0 Ethernet controller: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 (rev 02)
        Subsystem: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28
        Flags: bus master, fast devsel, latency 0, IRQ 16
        Memory at f3000000 (64-bit, prefetchable) [size=16M]
        Memory at f5000000 (64-bit, prefetchable) [size=32K]
        Expansion ROM at f7c80000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
        Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
        Capabilities: [a0] Express Endpoint, MSI 00
        Capabilities: [100] Advanced Error Reporting
        Capabilities: [140] Device Serial Number 30-33-a6-ff-ff-91-96-b4
        Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
        Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
        Capabilities: [1a0] Transaction Processing Hints
        Capabilities: [1b0] Access Control Services
        Capabilities: [1d0] #19
        Kernel driver in use: i40e
        Kernel modules: i40e
Software versions:
# ethtool -i enp2s0f0
    driver: i40e
    version: 2.8.20-k
    firmware-version: 8.30 0x8000a483 1.2926.0
    expansion-rom-version:
    bus-info: 0000:02:00.0
    supports-statistics: yes
    supports-test: yes
    supports-eeprom-access: yes
    supports-register-dump: yes
    supports-priv-flags: yes
Also tried with 4.15.0-142-generic kernel version and this NIC driver version:
    driver: i40e
    version: 2.15.9
    supports-test: yes
# ethtool -T enp2s0f0
Time stamping parameters for enp2s0f0:
Capabilities:
        hardware-transmit     (SOF_TIMESTAMPING_TX_HARDWARE)
        software-transmit     (SOF_TIMESTAMPING_TX_SOFTWARE)
        hardware-receive      (SOF_TIMESTAMPING_RX_HARDWARE)
        software-receive      (SOF_TIMESTAMPING_RX_SOFTWARE)
        software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
        hardware-raw-clock    (SOF_TIMESTAMPING_RAW_HARDWARE)
PTP Hardware Clock: 2
Hardware Transmit Timestamp Modes:
        off                   (HWTSTAMP_TX_OFF)
        on                    (HWTSTAMP_TX_ON)
Hardware Receive Filter Modes:
        none                  (HWTSTAMP_FILTER_NONE)
        ptpv1-l4-sync         (HWTSTAMP_FILTER_PTP_V1_L4_SYNC)
        ptpv1-l4-delay-req    (HWTSTAMP_FILTER_PTP_V1_L4_DELAY_REQ)
        ptpv2-l4-event        (HWTSTAMP_FILTER_PTP_V2_L4_EVENT)
        ptpv2-l4-sync         (HWTSTAMP_FILTER_PTP_V2_L4_SYNC)
        ptpv2-l4-delay-req    (HWTSTAMP_FILTER_PTP_V2_L4_DELAY_REQ)
        ptpv2-l2-event        (HWTSTAMP_FILTER_PTP_V2_L2_EVENT)
        ptpv2-l2-sync         (HWTSTAMP_FILTER_PTP_V2_L2_SYNC)
        ptpv2-l2-delay-req    (HWTSTAMP_FILTER_PTP_V2_L2_DELAY_REQ)
        ptpv2-event           (HWTSTAMP_FILTER_PTP_V2_EVENT)
        ptpv2-sync            (HWTSTAMP_FILTER_PTP_V2_SYNC)
        ptpv2-delay-req       (HWTSTAMP_FILTER_PTP_V2_DELAY_REQ)
linuxptp commit id: f3290eee8567f957b8c61c2d39ee618bc7ccffb1
linux kernel version: 5.4.0-77-generic
linux kernel PTP config:
    # grep "CONFIG_PTP" /boot/config-4.15.0-142-generic
    CONFIG_PTP_1588_CLOCK=m
    CONFIG_PTP_1588_CLOCK_KVM=m
loaded kernel modules:
    # lsmod | grep ptp
    ptp                         20480  2 i40e,igb
    pps_core               20480  1 ptp
linux distrib version:
    # cat /etc/lsb-release
    DISTRIB_ID=Ubuntu
    DISTRIB_RELEASE=18.04
    DISTRIB_CODENAME=bionic
    DISTRIB_DESCRIPTION="Ubuntu 18.04.1 LTS"
cheyert
Have you managed to resolve this?
We're getting a similar issue where our DELAY_REQ messages are not timestamped.
The odd thing is that when we reverse the role of PTP master and slave, that the Rx HW timestamping seems to work for SYNC messages and PDELAY_REQ messages.
Just the DELAY_REQ messages are failing with the messaes "Delay Req received without timestamp" once ptp4l is running.
Configuration is E2E, HW timestamping, L2 transport) and the RX filter is set to
RX timestamp filter mode 12 (HWTSTAMP_FILTER_PTP_V2_EVENT).
and it seems to be the only possible way to configure it.
kharo22
Hello
I met the same issue within E810.
but on my side
ethtool -T  enp8sf0
Time stamping parameters for enp8sf0:
Capabilities:
	hardware-transmit
	software-transmit
	hardware-receive
	software-receive
	hardware-raw-clock
PTP Hardware Clock: 1
	off
	on
	none
	all
and also
Private flags for enp8sf0:
link-down-on-close           : off
fw-lldp-agent                : off
channel-inline-fd-mark       : off
channel-pkt-inspect-optimize : on
channel-pkt-clean-bp-stop    : off
channel-pkt-clean-bp-stop-cfg: off
vf-true-promisc-support      : off
mdd-auto-reset-vf            : off
vf-vlan-pruning              : off
legacy-rx                    : off
cgu_fast_lock                : off
dpll_monitor                 : on
extts_filter                 : on
itu_g8262_filter_used        : off
allow-no-fec-modules-in-auto : off
kernel is currently 6.2, I got same issue within 5.11 and kernel 6.5, last ice drivers 1.12.18
