./ptp4l -i enp2s0f0 -m2EH -f ./default.cfg
# Default Data Set
twoStepFlag 1
clientOnly 0
socket_priority 0
priority1 128
priority2 128
domainNumber 0
#utc_offset 37
clockClass 248
clockAccuracy 0xFE
offsetScaledLogVariance 0xFFFF
free_running 0
freq_est_interval 1
dscp_event 0
dscp_general 0
dataset_comparison ieee1588
G.8275.defaultDS.localPriority 128
maxStepsRemoved 255
# Port Data Set
logAnnounceInterval 1
logSyncInterval 0
operLogSyncInterval 0
logMinDelayReqInterval 0
logMinPdelayReqInterval 0
operLogPdelayReqInterval 0
announceReceiptTimeout 3
syncReceiptTimeout 0
delayAsymmetry 0
fault_reset_interval 4
neighborPropDelayThresh 20000000
serverOnly 0
G.8275.portDS.localPriority 128
asCapable auto
BMCA ptp
inhibit_announce 0
inhibit_delay_req 0
ignore_source_id 0
# Run time options
assume_two_step 0
logging_level 6
path_trace_enabled 0
follow_up_info 0
hybrid_e2e 0
inhibit_multicast_service 0
net_sync_monitor 0
tc_spanning_tree 0
tx_timestamp_timeout 1
unicast_master_table 0
unicast_req_duration 3600
use_syslog 1
verbose 0
summary_interval 0
kernel_leap 1
check_fup_sync 0
clock_class_threshold 248
# Servo Options
pi_proportional_const 0.0
pi_integral_const 0.0
pi_proportional_scale 0.0
pi_proportional_exponent -0.3
pi_proportional_norm_max 0.7
pi_integral_scale 0.0
pi_integral_exponent 0.4
pi_integral_norm_max 0.3
step_threshold 0.0
first_step_threshold 0.00002
max_frequency 900000000
clock_servo pi
sanity_freq_limit 200000000
ntpshm_segment 0
msg_interval_request 0
servo_num_offset_values 10
servo_offset_threshold 0
write_phase_mode 0
# Transport options
transportSpecific 0x0
ptp_dst_mac 01:1B:19:00:00:00
p2p_dst_mac 01:80:C2:00:00:0E
udp_ttl 1
udp6_scope 0x0E
uds_address /var/run/ptp4l
uds_ro_address /var/run/ptp4lro
# Default interface options
clock_type OC
network_transport UDPv4
delay_mechanism E2E
time_stamping hardware
tsproc_mode filter
delay_filter moving_median
delay_filter_length 10
egressLatency 0
ingressLatency 0
boundary_clock_jbod 0
# Clock description
productDescription ;;
revisionData ;;
manufacturerIdentity 00:00:00
userDescription ;
timeSource 0xA0
# Default Data Set
twoStepFlag 1
clientOnly 0
socket_priority 0
priority1 128
priority2 128
domainNumber 0
#utc_offset 37
clockClass 248
clockAccuracy 0xFE
free_running 0
freq_est_interval 1
dscp_event 0
dscp_general 0
maxStepsRemoved 255
# Port Data Set
logSyncInterval 0
delayAsymmetry 0
serverOnly 0
asCapable auto
BMCA ptp
inhibit_announce 0
inhibit_delay_req 0
ignore_source_id 0
# Run time options
assume_two_step 0
logging_level 6
follow_up_info 0
hybrid_e2e 0
net_sync_monitor 0
tc_spanning_tree 0
use_syslog 1
verbose 0
summary_interval 0
kernel_leap 1
check_fup_sync 0
# Servo Options
step_threshold 0.0
clock_servo pi
ntpshm_segment 0
write_phase_mode 0
# Transport options
udp_ttl 1
udp6_scope 0x0E
clock_type OC
delay_mechanism E2E
tsproc_mode filter
egressLatency 0
ingressLatency 0
revisionData ;;
userDescription ;
timeSource 0xA0
6: enp2s0f0: <BROADCAST,MULTICAST,UP,LOWER_
link/ether b4:96:91:a6:33:30 brd ff:ff:ff:ff:ff:ff
4: enp2s0f0: <BROADCAST,MULTICAST,UP,LOWER_
link/ether b4:96:91:a6:33:c0 brd ff:ff:ff:ff:ff:ff
Subsystem: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at f3000000 (64-bit, prefetchable) [size=16M]
Memory at f5000000 (64-bit, prefetchable) [size=32K]
Expansion ROM at f7c80000 [disabled] [size=512K]
Capabilities: [40] Power Management version 3
Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
Capabilities: [70] MSI-X: Enable+ Count=129 Masked-
Capabilities: [a0] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [140] Device Serial Number 30-33-a6-ff-ff-91-96-b4
Capabilities: [150] Alternative Routing-ID Interpretation (ARI)
Capabilities: [160] Single Root I/O Virtualization (SR-IOV)
Capabilities: [1a0] Transaction Processing Hints
Capabilities: [1b0] Access Control Services
Capabilities: [1d0] #19
Kernel driver in use: i40e
Kernel modules: i40e
Software versions:
# ethtool -i enp2s0f0
driver: i40e
version: 2.8.20-k
firmware-version: 8.30 0x8000a483 1.2926.0
expansion-rom-version:
bus-info: 0000:02:00.0
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
Also tried with 4.15.0-142-generic kernel version and this NIC driver version:
driver: i40e
version: 2.15.9
supports-test: yes
# ethtool -T enp2s0f0
Capabilities:
hardware-transmit (SOF_TIMESTAMPING_TX_HARDWARE)
software-transmit (SOF_TIMESTAMPING_TX_SOFTWARE)
hardware-receive (SOF_TIMESTAMPING_RX_
software-receive (SOF_TIMESTAMPING_RX_
software-system-clock (SOF_TIMESTAMPING_SOFTWARE)
hardware-raw-clock (SOF_TIMESTAMPING_RAW_
PTP Hardware Clock: 2
Hardware Transmit Timestamp Modes:
off (HWTSTAMP_TX_OFF)
on (HWTSTAMP_TX_ON)
Hardware Receive Filter Modes:
none (HWTSTAMP_FILTER_NONE)
ptpv1-l4-sync (HWTSTAMP_FILTER_PTP_V1_L4_
ptpv1-l4-delay-req (HWTSTAMP_FILTER_PTP_V1_L4_
ptpv2-l4-event (HWTSTAMP_FILTER_PTP_V2_L4_
ptpv2-l4-sync (HWTSTAMP_FILTER_PTP_V2_L4_
ptpv2-l4-delay-req (HWTSTAMP_FILTER_PTP_V2_L4_
ptpv2-l2-event (HWTSTAMP_FILTER_PTP_V2_L2_
ptpv2-l2-sync (HWTSTAMP_FILTER_PTP_V2_L2_
ptpv2-l2-delay-req (HWTSTAMP_FILTER_PTP_V2_L2_
ptpv2-event (HWTSTAMP_FILTER_PTP_V2_EVENT)
ptpv2-sync (HWTSTAMP_FILTER_PTP_V2_SYNC)
ptpv2-delay-req (HWTSTAMP_FILTER_PTP_V2_DELAY_
CONFIG_PTP_1588_CLOCK=m
CONFIG_PTP_1588_CLOCK_KVM=m
# lsmod | grep ptp
ptp 20480 2 i40e,igb
pps_core 20480 1 ptp
# cat /etc/lsb-release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04.1 LTS"
Have you managed to resolve this?
We're getting a similar issue where our DELAY_REQ messages are not timestamped.
The odd thing is that when we reverse the role of PTP master and slave, that the Rx HW timestamping seems to work for SYNC messages and PDELAY_REQ messages.
Just the DELAY_REQ messages are failing with the messaes "Delay Req received without timestamp" once ptp4l is running.
Configuration is E2E, HW timestamping, L2 transport) and the RX filter is set to
RX timestamp filter mode 12 (HWTSTAMP_FILTER_PTP_V2_EVENT).
and it seems to be the only possible way to configure it.
