Hi, I'm trying to update FW using NVM Update tool version 1.37.28.0 and I'm receiving a status of "Device not found". I'm using HPE Proliant DL360 Gen10 with Ethernet controller [0200]: Intel Corporation Ethernet Controller XXV710 for 25GbE SFP28 [8086:158b] (rev 02)
I tested under three different OS which are:
- SLES 15 SP2
- Ubuntu 16
- Ubuntu 20
Am I using the incorrect NVM Update tool?
Attached the nvmupdate64e screenshot and ethtool.
- Tags:
- XXV710
Issue solved.
Hello, I'm dealing with the same issue. could you please share the solution.
Greetings ElmoA,
We're glad issue is resolved now. therefore shall we proceed to close this ticket.
Looking forward to receiving your reply.
Thank you & Best Regards,
Devi_Intel
Hi ElmoA, can you provide the solution as I'm facing the same issue
Topic Options
