Ethernet Products
5782 Discussions
XXV710 fails to link up due to invalid FEC settings - siituation after ESXi Upgrade.
tmichaeli
Dear Intel,
I am from VMware and we are facing link-down issue with Ethernet Controller XXV710 for 25GbE SFP28  after the upgrade to VCF5.1/vSpheer8.0.2 for few customers.
Updating driver to 2.7.2.0 and firmware to 9.50 based on HCL did not helped. Utilising Windows to boot and change the FEC settings is not effective.
Your intnet plugin in to esxcli doe not work and do not allow me to disable FEC. This particular setup has Intel Server S2600WF, so there is no UI for the card while booting from BIOS.
Is there way to modify setting on UEFI Shell?
Is there way to disable FEC with some other utility from ESXi shell?
You provided utility for esxcli plugin does not work on 8.0.2 ESXi.
See details atachement bellow.
tmichaeli
I have disabled LLDP client on the Card in the BIOS and link is UP again.
Strange, how LLDP agent on a nic is relevant to the link status.....
[root@vcf01-prg-esx01:~] esxcli network nic list
Name PCI Device Driver Admin Status Link Status Speed Duplex MAC Address MTU Description
vmnic0 0000:3d:00.0 i40en Up Up 1000 Full a4:bf:01:83:ba:8f 1500 Intel(R) Ethernet Connection X722 for 10GBASE-T
vmnic1 0000:3d:00.1 i40en Up Up 1000 Full a4:bf:01:83:ba:90 1500 Intel(R) Ethernet Connection X722 for 10GBASE-T
vmnic2 0000:86:00.0 i40en Up Up 25000 Full 40:a6:b7:20:a2:10 9000 Intel(R) Ethernet Controller XXV710 for 25GbE SFP28
vmnic3 0000:86:00.1 i40en Up Up 25000 Full 40:a6:b7:20:a2:11 9000 Intel(R) Ethernet Controller XXV710 for 25GbE SFP28
Devi_Intel
Hello tmichaeli,
Good day to you
Thank you for posting Ethernet Community. I'm here to follow up case as per subject. Appreciate you can check the article link below for more information.
https://www.intel.com/content/www/us/en/support/articles/000056637/ethernet-products/700-series-controllers-up-to-40gbe.html
For further concern please do let us know.
Thank you & Best Regards,
Devi_Intel
Hayat
Hello tmichaeli,
Regarding your thread, we are following up to find out if you were able to complete the actions, we previously recommended.
Please reply here to confirm, so we can continue helping with a resolution. Looking forward to receiving your reply!
Thank You.
Hayat
Intel® Customer Support
Irwan_Intel
Hello tmichaeli,
Kindly note that as we have not received any response from our previous follow-ups, we will be closing this request.
If you have any more questions in the future, please don't hesitate to post a new question, as this thread will no longer be monitored.
Irwan_Intel
