Ethernet Products
5568 Discussions
about WGI210IT
jzhen36
hello,Can i ask what is the drivers and MAC address of "WGI210IT" ,Thanks.
Mike_Intel
Hello jzhen36,
You may use these links to get the MAC address of your card. The markings on the card is for a retail Intel card, if you have an OEM or a third party manufactured card, they may have a different set of markings.
https://www.intel.com/content/www/us/en/support/articles/000032287/network-and-i-o/ethernet-products.html
https://www.intel.com/content/www/us/en/support/articles/000005625/services.html
If you have questions, please let us know. In case we do not hear from you, we will make a follow up after 3 workings days. Thank you.
Michael L.
Intel Customer Support Technicians
jhold7
hi
Device ID and MAC Address Cannot be Changed (Added) ... WGI210IT - Production (Copper and Industrial Temperature Range). 925133 ... This workaround has been implemented in Intel drivers starting from Release 20.2.
jzhen36
hi,Is this "925133 " the MAC Address?
AlHill
@jhold7​  Provide the source for your plagarized answer.
Doc
AlHill
No, it is a "MM" number. Your response came from a user who plagairized text from this document:
https://cdrdv2.intel.com/v1/dl/getcontent/332763?asset=9571
Look on page 6 and you will see the 925133 is the MM number of your device.
One of the Intel support engineers will have to address you question.
Sorry for the trouble,
Doc
jzhen36
Mike_Intel
Hello jzhen36,
I am sorry, are you asking if you can change the MAC address? Can you further explain your exact inquiry for me to assist you.
Michael L.
jzhen36
hi,we dont want to change the MAC address,we want to know the MAC address,because we need the MAC address to access the internet.
Mike_Intel
Hello jzhen36,
Michael L.
jzhen36
Mike_Intel
Hello jzhen36,
Here is another update that you can also follow:
For Intel retail card, the MAC address is indicated the white bar code sticker.  Kindly check the link below for reference:
If you are using a Windows OS, you may can check it via CMD command prompt. In the search box, type CMD then type ipconfig /all then press enter.
MAC address is generally described as physical address.
Once you have the MAC address, check this link to identify if an Intel® Ethernet Adapter is Intel made or an OEM card. If your card is an an OEM card or a third party manufactured card, they may have a different set of markings. kindly check the link below for reference:
If your card is confirmed as an OEM card, you need to contact the OEM manufacturer because they are still the best source of support. They have drivers suited and tailored for his card.
Michael L.
jzhen36
OK,i got it,thank you for you supporting!
Mike_Intel
Hello jzhen36,
Do you still have additional questions or clarifications regarding this inquiry?
Michael L.
jzhen36
Hi,no more additional questions.Thanks.
