Hello!
We are using I350-AM2 with Freescale i.MX6Q, and i have some questions.
1. Can i use I350-AM2 without EEPROM?
2. If i cannot use I350-AM2 without EEPROM, how can i write EEPROM after booting completed?
3. Is there any reference EEPROM data? Or can i dump EEPROM from NIC that used I350, then mod this dumped data, then apply to our board?
Thanks!
- Tags:
- Controllers
- Embedded IOT Solutions & Gateways
- Intel® Ethernet Server Adapter I350
- Other Hardware Products
Hi Heeseob Jung
Referring to Section 3.3.1.4 Software Accesses:
"The I350 provides two different methods for software access to the EEPROM. It can either use the builtin controller to read the EEPROM or access the EEPROM directly using the EEPROM's 4-wire interface…
Software can also directly access the EEPROM's 4-wire interface through the EEPROM/Flash Control
(EEC) register. It can use this for reads, writes, or other EEPROM operations."
To directly access the EEPROM, software should follow these steps:
1. Take ownership of the EEPROM Semaphore bit as described in Section 4.7.1.
2. Write a 1b to the EEPROM Request bit (EEC.EE_REQ).
3. Poll the EEPROM Grant bit (EEC.EE_GNT) until it becomes 1b. It remains 0b as long as the
hardware is accessing the EEPROM.
4. Write or read the EEPROM using the direct access to the 4-wire interface as defined in the EEPROM/
Flash Control and Data (EEC) register. The exact protocol used depends on the EEPROM placed on
the board and can be found in the appropriate datasheet.
5. Write a 0b to the EEPROM Request bit (EEC.EE_REQ) to enable EEPROM access by other drivers.
We are going to upload the document # 474233 Intel® Ethernet Controller I350 [Powerville] – EEPROM Images – Rev. 1.63, and we will let you know as soon as the document is available.
Best Regards.
Josue.
- « Previous
- 1
- 2
- Next »
Hi Gabriel,
Any chance a arm64 / aarch64 version of that tool exists ?
Hello, @MBerg36:
Could you please let us know the part number of the Intel device associated to your request?
We are waiting for your clarification.
Hello, @MBerg36:
Thanks for your update.
Could you please let us know if your request is associated to a technical problem? In case that your answer is affirmative, could you please give all the details of the issue?
By the way, could you please clarify if the devices associated to your thread have been designed by you or it are third-party units? Could you please let us know the name of the manufacturer, model, other important information of they are third-party devices?
We are waiting for your answer.
We have put the I350 on a custom design.
Our main processor is an 64 bit ARMv8
Hello, @MBerg36:
We suggest you use the EEPROM Unlock utility, which removes the write protection on the I350 EEPROM. It can be found at:
https://downloadcenter.intel.com/download/23609/EEPROM-Unlock-utility
As there is no EFI I am not sure how I would use this utility
Hello, @MBerg36:
The EEUpdate EEPROM Update Utility document # 607981 and Intel Ethernet Controller I350 [Powerville] EEPROM Images document # 474233 may help you to solve your problem. These documents can be found when you are logged into your Resource & Design Center (RDC) privileged account at the following websites:
http://www.intel.com/cd/edesign/library/asmo-na/eng/607981.htm
http://www.intel.com/cd/edesign/library/asmo-na/eng/474233.htm
The RDC Account Support form is the channel to process your account update request or any inconvenience related to the provided websites. It can be found at:
https://www.intel.com/content/www/us/en/forms/design/contact-support.html
- « Previous
- 1
- 2
- Next »
